Rough Idle - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-13-2007, 11:37 PM   #11
aquanetkill
Fan#: 48737
What I Drive: 2002, Red, Sedan
FF Reputation: 1 aquanetkill Good Standing Member
Angry How hard?
I think you may have solved my problem as well. I have the EXACT same problem with my 2002 focus. I will go to autozone tomorrow to see if i get the same code as you but i did just hear a hiss just like you described tonite. How hard was this hose to replace? What tools and how long did it take you? Instructions somewhere. I am not too car savy but i have a technical mind and can normally figure stuff out with a little help. please let me know as this problem is really starting to aggrivate me! Also what is the technical name for the hose?
aquanetkill is offline
Old 07-14-2007, 12:29 AM   #12
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
hmm. is that why my idle is at around 700 or so?. it's kinda cool but the car seems like it'll die out. mine is an 03 with the zetec. maybe i should replace this seeing as though i have around 50 k on it (i did the tune up myself and didn't forget anything. it was cheaper this way anyhow).
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 07-16-2007, 01:55 PM   #13
ChaosWarlord26
Fan#: 48372
What I Drive: 2006 Dodge Ram 1500
FF Reputation: 3 ChaosWarlord26 Good Standing Member
I actually had 2 bad hoses. Has anyone heard of crank case ventalation? Well this was the real bad hose. It goes the crank case on the top of the motor to the back of the intake mani. It has a hard plastic core with rubber elbows one on each end. One of my rubber elbows was in real bad shape So I replace it with High temp Silicone tubing. and has been runing great ever since. Hope this helps out a lot of people.
ChaosWarlord26 is offline
Old 08-13-2007, 08:37 PM   #14
ChaosWarlord26
Fan#: 48372
Pictures
I have just taken photos for those who want to see......
First Pic dirty motor and CAI
Next is a side view
Next is the crank case vaccuum hose.
Finallay is the part of the hose that I replaced from the Vaccuum hose to the Intake
I hope this helps everyone with the problem I had with future problems that everyone else may have.
Old 09-27-2007, 12:27 PM   #15
aquanetkill
Fan#: 48737
this fixed my problem in less than 5 minutes! my guess is that this hose has been bad for a long time and just recently turned my check engine light on. my car idles like its brand new now and hasn't done that in a long time. So if your looking for the cause of a rough idle check the elbow of this hose even if your check engine light isn't on.
Old 10-26-2008, 06:31 AM   #16
afro_ken
Fan#: 60090
What I Drive: 2000 Silver
FF Reputation: 1 afro_ken Good Standing Member
Aloha!! This post is fantastic!!! My check engine light came on! I tested with a OBD2 which gave me a code of p0171= too lean (bank 1). I didn't know where to begin. O2 sensor, fuel filter, etc... BUT no the hose in this post was the culprit to my problem. thanks!!!
afro_ken is offline
Old 10-26-2008, 07:04 AM   #17
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Nice to find an older post where the problem was solved and explained thoroughly.
First off.....I don't think a rough idle is "normal" on any stock Focus. Of course when you modify the engine in any way, all bets are off.
Finding most vacuum leaks is fairly easy. If you suspect one (rough idle is one symptom), with the engine idling, lightly spray around the intake manifold and all the vacuum hoses.....with carb cleaner. If there's a leak anywhere, the engine will speed up. Avoid spraying the spark plugs and wires, as well as the exhaust manifold area.
You can pinpoint the exact leak with this method.....carb cleaner is flammable, so be careful.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 10-26-2008, 07:19 AM   #18
Benporat
Fan#: 59927
What I Drive: Focus 2012 Silver
FF Reputation: 1 Benporat Good Standing Member
this thread from 2004 would have given you a short cut to finding the problem
http://www.focusfanatics.com/forum/s...ad.php?t=28249
thats how I found my problem:
http://www.focusfanatics.com/forum/s...&postcount=107
this looks like a very common, overlooked, and underdiagnosed problem
and some mechanics will run you up a big bill replacing perfectly good engine components before they get it right
Benporat is offline
Old 10-27-2008, 03:01 AM   #19
sunyfoci
sunyfoci's Avatar
Fan#: 38913
What I Drive: 2001 red zx3 2.0L DOHC
Points 3,150, Level 34
Points: 3,150, Level: 34 Points: 3,150, Level: 34 Points: 3,150, Level: 34
Level Up 67% Completed
FF Reputation: 1 sunyfoci Good Standing Member
i replaced the hose behind the engine below the tb but im not seeing the second hose you posted pics of whereabout on the zetec engine is that located assuming it is on the dohc
current mods: 2.5 borla catback, debadged, AEM cai, H&R coilovers, SVT frontlip, SCT Xcal, kenwood deck, gutted interior, shortened antenna, and a big ass dent on the passenger side
sunyfoci is offline
Old 04-06-2011, 07:33 PM   #20
happy42
Fan#: 84698
What I Drive: 2001 red ZX3
FF Reputation: 1 happy42 Good Standing Member
Unhappy funky idle
Okay so i bought my first Ford and it was my 2001 focus ZX3 5 speed.Love it !!!!!!Lots of fun to drive then last week i did the "stupid" and ran it almost out of gas since then it has had a rough idle but also noticed about a couple days before that there was like a hissing/sssshhhhh noise.So i did some research and put gas treatment in then that didn't work so i got some trottle cleaner and cleaned the throttle body.That massde it run a little smoother now back to a rough idle at stop lights,like it's gonna die and rpms go down to about 750.
Engine light came on so went to the autozone and some 19001 code came about oxygen sensor.
I love my focus and of course the gas mileage and the zoom zoom of it.
so this weekend my son and i will try the z hose thing.But if any other clues plz let me know.
happy42 is offline
Similar Threads
Rough Idle and SES Codes chkpnt General Technical Chat 3 08-25-2007 01:14 AM
Rough Idle - 2002 ZX5 Zetec bajadog General Technical Chat 4 06-08-2007 12:30 PM
Rough Idle with AC on tminer250 General Technical Chat 1 06-05-2007 12:33 PM
JRSC rough idle with FC TB? dBlast General Forced Induction 5 04-18-2005 02:11 AM
rough idle CowsGoMoo ZETEC Performance (2000-2004) 9 10-16-2003 04:11 PM
