Rough Idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-28-2007, 09:19 PM   #1
ChaosWarlord26
Fan#: 48372
What I Drive: 2006 Dodge Ram 1500
FF Reputation: 3 ChaosWarlord26 Good Standing Member
Rough Idle
Ok I know the title says it all...oh know not another one of these. I am a new member to the forum but I have been search everyone's post for about 3 weeks now trying to figure out my problem. With no luck thus far here goes the thread.
The actual symptoms are that at idle is idling really rough almost like loping. It tries to die then comes back. It will do this in Park, Reverse, nuetral, or Drive only at stop. When driving the car runs great. good acceleration. But when I come to a stop light and just let it idle it messes up. I have noticed though that when it is idling rough if I turn on the AC the rpm's change and it quits temporarily.
Ok so I am driving a 2001 Focus Se. 2.0 SOHC. I have installed a Cold Air Intake (Short Ram) on it. I have taken it apart multiple time and made sure the was no leaks. I keep getting this code from the CEL with an OBD-II reader. (PO171) I know, System Fuel to Lean Bank 1. I have had the intake on it for more than 3 months prior to it acting this way.
What I have done so far is change the fuel filter, changed the Spark Plugs, Changed the O2 Sensor before the Cat. Tried different grades of fuel and fuel treatments. I have cleaned the MAF 3 times in the last week with CRC MAF cleaner.
My next steps are checking the fuel pressure at Idle. Does anyone know what the pressure is supposed to be at idle? Also does anyone else have any thoughts of what it could be? I am thinking that it could be a bad MAF, EGR Valve, IACV, or bad fuel Pump. Any help would be greatly appreciated. Thanks
ChaosWarlord26 is offline
Old 06-28-2007, 09:56 PM   #2
maggot515
maggot515's Avatar
Fan#: 40886
What I Drive: 2003 pitch black zx3
FF Reputation: 1 maggot515 Good Standing Member
well all focuses have a kind of lopey idle theres nothing you can do about it
maggot515 is offline
Old 06-29-2007, 09:10 AM   #3
ChaosWarlord26
Fan#: 48372
Anyone else have any clues?
Old 06-29-2007, 09:55 AM   #4
HyBalz
HyBalz's Avatar
Fan#: 18573
What I Drive: 2000 Silver ZX3
FF Reputation: 49 HyBalz Great Standing Member
Buy-Sell-Trade Rating: (14)
Have you tried disconnecting the battery to reset the computer? BTW,Welcome to FF!
"I aim to misbehave"-Malcolm Reynolds
HyBalz is offline
Old 06-29-2007, 10:45 AM   #5
mighty_mouse
mighty_mouse's Avatar
Fan#: 28775
What I Drive: 2005, White, ZX3
FF Reputation: 17 mighty_mouse Great Standing Member
Welcome to FF.com. I have noticed the same symptom in my car, but also in many of foci that I have ridden in. So I would believe the rough idle to be normal.
Mouse
1/4 mile is what now?
[Team Duratec #86] [L.O.T.H #7]
Like MAC products for your Mustang or Focus? Come talk to me, I'll help you out
mighty_mouse is offline
Old 06-29-2007, 10:58 AM   #6
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Welcome to FF.
You have done well, and checked or fixxed most of what I would say to look at. I would say to check the plug wires and make sure they are tight to the plugs and the coil. You can also pop the hood at night, use a spray mister and mist under the hood around all the electrical wires and plugs IN THE DARK. Watch for arcing of any kind and listen for a miss.
Also, pull the plug on the cylinder the code is for. Does it look any different than the other plugs? Let us know.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 06-29-2007, 11:43 AM   #7
rebelyouth
rebelyouth's Avatar
Fan#: 37477
What I Drive: 01 ghia zetec se sadan
FF Reputation: 1 rebelyouth Good Standing Member
Son i have been trying to smooth out my idle for long time now, i am thinking that just a feature of the focus zetec, i own the same year as u do also, with K&N sri.
Everyday I autocross, God damn I love my FOCUS!
Sadan Revolution #28
rebelyouth is offline
Old 06-29-2007, 01:51 PM   #8
ChaosWarlord26
Fan#: 48372
Thanks for all the welcomes, Like I said I have been here for a while now just didn't become a member until yesterday. I find it easier and more respectful to search and dig for the solution first before posting a thread that so many people have already posted....
I have disconnected the batterymultiple time to reset it, and I have also reset the CEl by usin the OBD-II reader.
I have checked all the plug wires when I replace the plugs. As for wich cylinder the code is for I have no clue, because the OBD-II does not tell me that much detail. But thanks.
I guess my next steps are to check and clean the EGR valve and lines. Then check and clean the throttle body, and the IACV at the same time.
Now it is becoming a matter of money since all the rest of the parts that are next in line are starting to get pricey.....
Does anyone know what the fuel pressure should be at Idle? That is the next thing I am going to check.
Old 06-30-2007, 11:44 AM   #9
ChaosWarlord26
Fan#: 48372
to the top
Old 07-13-2007, 12:55 PM   #10
ChaosWarlord26
Fan#: 48372
Not trying to bring back a dead thread but I have found the problem. After many hours of pulling off pieces, EGR, IACV, Throttle Body, etc. I got it all back together and at the end when I was getting ready to give up I heard a louder hissing noise that wasn't there before. Come to find out it was a vaccuum line. This one was made of a hard plastic in a Z-shape. It was located on the back of the intake manifold and it was the center of the 3 that connected to it. I goes from the intake mani. to the (I believe) Evap for gas fumes to return. Or something like that. I took the hose to ford and it was about 40 bucks for s new one. Just wanted to let everyone know and thanks for all the help.
Similar Threads
Rough Idle and SES Codes chkpnt General Technical Chat 3 08-25-2007 01:14 AM
Rough Idle - 2002 ZX5 Zetec bajadog General Technical Chat 4 06-08-2007 12:30 PM
Rough Idle with AC on tminer250 General Technical Chat 1 06-05-2007 12:33 PM
JRSC rough idle with FC TB? dBlast General Forced Induction 5 04-18-2005 02:11 AM
rough idle CowsGoMoo ZETEC Performance (2000-2004) 9 10-16-2003 04:11 PM
