REGISTRATION OPEN!! Summit Point August 4-5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 06-27-2007, 12:34 PM   #1
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
We've had a few fanatics come out to play at Summit Point this year. We need more!!
The Greater Washington Sector of the Mercedes Benz Club is hosting a two day open track event at Summit Point on the Shenandoah Circuit.
Registration is now open and you can sign up and pay your entry fee online.
Visit: http://www.gws-mbca.org/SummitPoint07.html
This is a good event because of the limited number of cars. We expect that there will be no more than 150 cars this year for both days.
There will be 4 run groups that represent driver experience.
Novice
Beginner
Intermediate
Advanced
Each track session is 20 minutes long with an instructor - if you desire at no extra charge (Novice and Beginner are required to have instructors). Most of this event is spent on track. There is a short classroom orientation in the morning, but then it is all track time.
If you have questions, feel free to contact me here or through PM.
We also need additional instructors. If you are interested in supporting the event as an instructor, PM me.
Thanks,
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 06-27-2007, 03:58 PM   #2
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
What I Drive: 2005 Impreza 2.5 RS
FF Reputation: 42 miniboon Great Standing Member
when it talks about the safety inspection, what is that? is proof of my NYS inspection enough?
Originally Posted by viney266 View Post
I think miniboon is right on the money.
miniboon is offline
Old 06-27-2007, 04:05 PM   #3
focusedintentions
focusedintentions's Avatar
Fan#: 7850
What I Drive: 07 Infiniti G35 6mt coupe silver
FF Reputation: 1 focusedintentions Good Standing Member
If only i had the money...i would soo do this...but i'm poor...i am accepting sponsors :)
My SVT is #604 of 1079
One of 104 with EAP
focusedintentions is offline
Old 06-27-2007, 08:31 PM   #4
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
No, you put up to a tech inspections at the track, and a person will look over your car to make sure its in sound running order.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 06-27-2007, 08:51 PM   #5
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
From the site:
All cars must be inspected before the event at a dealer or independent shop, and you must bring the signed or stamped safety inspection form to the event.
I'm just wondering what type of inspection I need
miniboon is offline
Old 06-27-2007, 08:55 PM   #6
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
I wish I could go.
I'm going to be in Cancun from the 3rd to the 9th :(
Algorhythm is offline
Old 06-27-2007, 08:59 PM   #7
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
awww...poor baby....stuck in cancun
miniboon is offline
Old 06-27-2007, 09:08 PM   #8
Algorhythm
Fan#: 20623
I know.. I'm going to be stuck sitting in a pool for 5 days drinking unlimited alcohol.. sucks.
Old 06-27-2007, 09:26 PM   #9
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
From the site:
It is more comprehensive than just a trackside inspection. You must take a copy of the tech inspection form to a qualified (ASE) mechanic and have them look at the car. They look for the following:
ENGINE COMPARTMENT ok fail REAR SUSPENSION ok fail
Accelerator linkage bushings/springs ___ ___ Axle shafts/boots ___ ___
Air filter bracket, mounting ___ ___ Shocks/leakage/rubber bushings ___ ___
Battery frame/hold-down ___ ___ Springs/center spring ___ ___
Battery/cables ___ ___ Stabilizer/bushings ___ ___
Engine clean ___ ___ Subframe/mounts ___ ___
Engine mounts ___ ___ Tire wear – not less than 3/32” ___ ___
Engine oil/fuel leaks ___ ___ Trailing arm bushings ___ ___
Belts ___ ___
Visco clutch ___ ___ DRIVE TRAIN
Water pump/water hoses/clamps ___ ___ Center Support ___ ___
Water leak ___ ___ Flex disc/universal joint ___ ___
Transmission mount ___ ___
FRONT SUSPENSION
Ball joints/bushings ___ ___ BRAKES
Draglink/tie-rods ___ ___ Brake booster ___ ___
Idler arm bushings ___ ___ Brake calipers/cylinders ___ ___
King pins-no play ___ ___ Brake discs/drums ___ ___
Shocks ___ ___ Brake fluid renewed ___ ___
Springs – No spring spacers ___ ___ Brake hoses/brake lines ___ ___
Stabilizer bushings ___ ___ Master brake cylinder ___ ___
Steering box, lines, leaks, play ___ ___ Brake pads/shoes-min. 50% for
Steering shock/coupling ___ ___ 1 driver; 80% for 2 drivers ___ ___
Subframe mounts ___ ___ Brake dust shields removed ___ ___
Tire wear-not less than 3/32” ___ ___
Tires-no cuts, bruises ___ ___ EXHAUST SYSTEM
Wheels-bearing play/damage/Bent/correct lugs ___ ___ Exhaust leaks ___ ___
Exhaust system secure ___ ___
OIL LEAKS UNDER CAR LIGHTS/SEAT BELTS/WINDOWS
Engine/transmission ___ ___ Signals/stoplights/headlights ___ ___
Rear end/differential ___ ___ Seatbelts/windows – operation ___ ___
It's all subjective to a degree. Trackside, they check the lugnuts again and that's about it.
Not really a big deal. The Benz club insurance policy requires the formal inspection.
WeeAsp is offline
Old 06-28-2007, 03:15 AM   #10
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
ok cool....might have to skip a few AX's to save up for this, but it sounds like I'll get sooo much more driving for my money
miniboon is offline
Similar Threads
svtoa at summit point 8/21-22 garyk Mid Atlantic Fanatics 8 07-27-2004 09:54 PM
rain and summit point itsmemorphious SVT Performance (2002-2004) 0 04-02-2004 05:00 PM
nasa at summit point garyk Road Racing & Rally 13 03-08-2004 11:16 AM
pictures of new track at summit point garyk North East Fanatics 9 12-01-2003 10:14 AM
summit point emra races this weekend garyk North East Fanatics 11 11-27-2003 06:38 PM
