Cams, Gears, Timing Set Installed w/ Pics!! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 06-24-2007, 12:23 AM   #1
AcIdBuRn02ZTS
Fan#: 42027
What I Drive: 2002 Twilight Blue ZTS Sedan
FF Reputation: 5 AcIdBuRn02ZTS Good Standing Member
Well... we tore into the foci this morning to replace the timing belt, tensioner... idler... water pump... Comp stage 2 cams.... UR cam gears.... starting out with somethin like this...
After tearing out the reservoirs... acc. belt... motor mount... valve cover... and a few other nic nacs....
dirty old cam....
Exhaust cam lubed up & installed...
Both cams installed.. ready for gears & timing components...
Gears hand tight... belt in place... waiting for buddies to pick up correct idler pulley
Timing components in place... ready for gears to be torqued to spec....
Gears torqued... motor mount re-installed... other components put back in place... and ready for clearances to be checked...
After turning the motor over a few times by hand... checking clearances... surprisingly enough... none of the buckets even had to be moved.... some how or another... they were within spec... none were under .005... most on the intake had a light drag at .006... and the exhaust was slightly looser... all within spec.
Fired it up for the first time.... sounded great... minimal valve train noise.. the same if not less then what it was factory... and a decent lope at low idle...
Anyways... it runs nice... has a decent top end... but kinda laggy in the low-mid sections of the rpm range... so i believe i may have one of the cams a tooth off... not quite sure yet... gonna pull the vc back off within the next couple days.. get a degree wheel on it and get the cams properly setup...
only one question... what is the best way to find true TDC on the zetec? should i just use the pin? I got the tool kit from OTC.. so not sure how accurate that is...
Anyways... thats all I got for now...
Currently trying to get the initial start-up vid uploaded... but for now.. thats all i got...
-AcId-
2002 - Twilight Blue ZTS Sedan
Built Motor, Getrag w/ Quaife, Eibach Suspension, GT3071R Turbo.. Destroying Tires thru 3rd @ 10psi = Priceless. 20+psi soon to come.
1987 MKIII Supra Targa
AcIdBuRn02ZTS is offline
Old 06-24-2007, 01:30 AM   #2
SilverZX3Bullet
Fan#: 38470
What I Drive: '00 Urban Camo ZX3
FF Reputation: 1 SilverZX3Bullet Good Standing Member
Very nice!
The pin & degree wheel will get you set.
-Edit- Reminiscent of my own post actually... Crane 2's & Adj Cam Gear Install Picture Fest (56k No)-Edit-
Zetec Crew #132
SilverZX3Bullet is offline
Old 06-24-2007, 08:53 AM   #3
liquid01
Fan#: 252
What I Drive: ZX3 S2 modded--Just a touch
FF Reputation: 3 liquid01 Good Standing Member
Always good to see a do it yourselfer get it done..... Looks good
liquid01 is offline
Old 06-24-2007, 09:06 AM   #4
hardk0re
hardk0re's Avatar
Fan#: 15059
What I Drive: 2001 Ford Focus ZX3
FF Reputation: 1 hardk0re Good Standing Member
wow that some serious sludge on there!, how many miles on that engine?
hardk0re is offline
Old 06-24-2007, 11:38 AM   #5
AcIdBuRn02ZTS
Fan#: 42027
just rolled over 90k... i bought it at around 80k... and the person was a pharmacy sales rep... so who knows how long it went inbetween oil changes and what he used...
i run mobil 1 now... and am planning on running sum seafoam and a little bit of ford ATF through it on my next oil change to hopefully clean things up a bit....
the more i drive it... the better it seems to get... but i still believe i may be a few degrees off... when you get on it... it seems like the exhaust gets a lot louder... but the car doesnt pick up and take off.... so hopefully getting them dialed in will help...
-AcId-
Old 06-24-2007, 04:03 PM   #6
SVT-SAGE
Fan#: 43249
What I Drive: 2003 Pitch Black SVTF
FF Reputation: 15 SVT-SAGE Great Standing Member
Buy-Sell-Trade Rating: (17)
Nice Work man-
Yeah it sounds like your timing is off-
SVT-SAGE is offline
Old 06-24-2007, 04:07 PM   #7
NikiterZTS
NikiterZTS's Avatar
Fan#: 28234
What I Drive: 2002 Gun Grey ZTS
FF Reputation: 5 NikiterZTS Good Standing Member
good job man
hey for your next oil change do engine flush....thats way kinda dirty
oh and don't forget to jump on the dyno soon enough
I'm here to raise that BS flag.Ford Focus ZTS 125whp/129wtq
Subaru Impreza WRX Stage 2 Protuned On Mustang Dyno 207whp/273wtq
I have 5 points on this site :-/
NikiterZTS is offline
Old 06-24-2007, 05:27 PM   #8
AcIdBuRn02ZTS
Fan#: 42027
where can i pick up a degree wheel kit that will work w/ the zetec? any where i can rent one? this cam job pretty well drained my fundage....
its kinda wierd... but if im light on the pedal... it definately has a noticeable difference in power... but if im hard on it... it struggles to pick up and take off....
i think it may be my exhaust holding it wwwaaayyy back. i know its a no no... but it was time to change the timing belt and everything anyways... and i didnt wanna take it all back apart... so currently... all my mods are piped through factory exhaust (exept the header that is)
anyways... gonna get them degreed in next week if i can... and go from there...
still workin on the vid... havin trouble w/ my computer at the moment...
-AcId-
Old 06-24-2007, 05:38 PM   #9
bigchad112288
Fan#: 14323
What I Drive: blue zx3 2002 5speed
FF Reputation: 1 bigchad112288 Good Standing Member
how long did that take you to get it all on. did you do it in your own garage..
The SVT blasted through our 600-foot slalom at 68.2 mph. Not only was it faster than the Civic and New Beetle, its slalom speed was higher than that of cars like the Chevy Corvette Z06, BMW M3 and Subaru Impreza WRX.
bigchad112288 is offline
Old 06-24-2007, 06:16 PM   #10
SVT-SAGE
Fan#: 43249
Have you messed around with the cam gears try advancing your exhaust gear and retarding your intake for some low end.
Also set the gears at max advance or retard and see how it feels. Make sure you give the crank a rotation by hand first though.
SVT-SAGE is offline
Similar Threads
4.06 gears and Quaife installed... SkaAddict ZETEC Performance (2000-2004) 11 05-18-2005 06:36 PM
Pics of custom sub set up? somainevent Car Audio, SYNC, MyFord Touch & Electronics 8 03-18-2005 10:11 PM
Its time! Cams and Cam Gears mconrada ZETEC Performance (2000-2004) 16 05-06-2004 03:52 PM
engine parts richiejerzee4lfe ZETEC Performance (2000-2004) 8 02-28-2004 11:59 AM
Adjusting cams and taking off cam gears. pitchblackab Ford Focus & General Car Chat 7 09-30-2003 10:02 PM
