Front End Clunk - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2007, 11:25 AM   #1
jbird1955
jbird1955's Avatar
Fan#: 48235
What I Drive: 2014 Tuxedo Black Ti Hatch
Points 788, Level 14
Points: 788, Level: 14 Points: 788, Level: 14 Points: 788, Level: 14
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 jbird1955 Good Standing Member
Front End Clunk
I've read some here about this topic and wanted to be sure before I proceed to install the fix.
In a straight line, at any speed, when I go over a bump, railroad tracks or whatever I get this hideous "clunk" from the front end. This noise will go away when I load the sway bar by turning the wheel.
I immediately thought of the sway bar bushings (I do not want to change these unless I have to) but I read more and more of how it is most likely the end links.
Please tell me this is true, it'll make my day!
Joe
jbird1955 is offline
Old 06-22-2007, 11:34 AM   #2
jrpasmo
jrpasmo's Avatar
Fan#: 2866
What I Drive: 02Focus ZTW, 02Focus SVT
Points 2,649, Level 31
Points: 2,649, Level: 31 Points: 2,649, Level: 31 Points: 2,649, Level: 31
Level Up 33% Completed
FF Reputation: 5 jrpasmo Good Standing Member
Hmmm I'm in the same situattion....end links...I think they making sound only at low speed...and bumbs...at least mine did...I replaced them, like one month ago...everything was ok until last week...I think my bushings are gone...have to check over the weekend....
jrpasmo is offline
Old 06-22-2007, 11:41 AM   #3
BlacKnight
BlacKnight's Avatar
Fan#: 23119
What I Drive: 2007 Black F150 STX
FF Reputation: 1 BlacKnight Good Standing Member
Pretty sure it's the end links. Also check out your sub-frame mounts. Mine had somehow worked loose.
Roger
I sell Ford, Lincoln, and Mercury vehicles one piece at a time.
Shadow may be gone, but I am still around from time to time!
BlacKnight is offline
Old 06-22-2007, 12:07 PM   #4
blackSVT04
blackSVT04's Avatar
Fan#: 48184
What I Drive: 2004 Pitch Black SVT ZX3
FF Reputation: 1 blackSVT04 Good Standing Member
yea same here...more obvious on turns....i was thinking front control arms...any thoughts?
SVT Build #1574 of 1978
blackSVT04 is offline
Old 06-22-2007, 12:52 PM   #5
mpcv2000
mpcv2000's Avatar
Fan#: 23629
What I Drive: 01 SE + 1989 RX7
FF Reputation: 19 mpcv2000 Great Standing Member
Mine ( 03 ZX3 ) is doing it too. New top plate , new moog end link , new suspension arm , new AGX , I even got the AGX changed under warranty thinking it was my problem , all bolts of the subframe has been verified , sway bar bushing inspected. I don't know where to look at anymore , it's doing it on the passenger side when cruising or accelerating going over little bumps. Not as bad when I have a passenger with me , I should say it almost never happen with a passenger. I'm running out of idea..
Martin !
mpcv2000 is offline
Old 06-22-2007, 12:55 PM   #6
TimHickey
TimHickey's Avatar
Fan#: 38341
What I Drive: 2006 Black zx5 ses
FF Reputation: 16 TimHickey Great Standing Member
Mine to
Blue Underglow, Clear Corners,Silverstar Turn signals, Shorty antenna,vogtland springs , Rust Module,Trubendz 2.5 ss magnaflow and Fuzion 205/50/16 HRI's
TEAM DURATEC # 99
TimHickey is offline
Old 06-22-2007, 12:57 PM   #7
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Check the subframe bolts too.
Same symptoms for me. Tugged and tightened and rechecked everything mentioned. Ended up taking it to the dealer.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 06-22-2007, 01:57 PM   #8
remusrm
Fan#: 1250
What I Drive: 09 MS3
FF Reputation: 1 remusrm Good Standing Member
its the engine mounts... had similar issues... i just took my car from the dealer and they changed all my engine mount and back to normal just to make sure... i really think the dog bone is since it allows the bottom to move side to side... also that makes the drive engine mount go bad too... the passenger seems to be the less affected... change the bottom one out then the driver if it does not go away... trust me.. i changed the whole car by now... i am broke from all this experimenting... if you want to donate a penny remusrm @ yahoo. com on pay pal if that is ur problem and is solved...
MY FOCUS WAS A POS!!!
BUT NOW I GOT A MS3!!!
294hp/356tq he he:-)
remusrm is offline
Old 06-22-2007, 02:10 PM   #9
mpcv2000
mpcv2000's Avatar
Fan#: 23629
I forgot , dog bone has been replaced too , I'm using uretane bushing ( clunking problem was there before and after the dog bone installation )
Martin !
mpcv2000 is offline
Old 06-22-2007, 05:14 PM   #10
DURATECoftheDesert
Subcompact Fanatic
DURATECoftheDesert's Avatar
Fan#: 43017
What I Drive: 1997 Ford Aspire White
FF Reputation: 9 DURATECoftheDesert Good Standing Member
Experienced that problem, and turned out to be the Tie Rod-Ends were worned to crap! And the clunking would only happen over small or large bumps or entering a parking lot over a concrete bump.
Expect to pay no more than 100 to 150 dollars for both replaced.
Finally peace and quiet...
DURATECoftheDesert is offline
Similar Threads
Front end noise airdenver General Technical Chat 2 11-26-2006 05:28 PM
05 Focus Stock front end/ intake parts Kmadison Archive 0 01-02-2006 07:06 PM
Ideas for new front end Poney MK1 Focus 16 11-02-2005 07:38 PM
2005 front end on a 2000 ZX3 slammedfoci Ford Focus Builds & General Showroom 5 09-26-2004 07:13 PM
what front end???? ZtsFocus MK1 Focus 9 10-11-2003 02:22 PM
