alternator fusible link lcation? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2007, 04:55 PM   #1
violentone
Fan#: 47807
What I Drive: 2005 focus black zx4
FF Reputation: 1 violentone Good Standing Member
where exactly is the fusible link for the alternator? my check battery light is comming on and my headlights stay on when i start my car now, and i dont have daytime running lights either! this just started a week ago and i changed my battery,? so i want to check fuses before i check alternator
violentone is offline
Old 08-09-2007, 07:00 PM   #2
Poppy360
Fan#: 29537
What I Drive: 2003 Black ZX3
FF Reputation: 1 Poppy360 Good Standing Member
Anybody know this? I'm having a problem with my batt light coming on.
Poppy360 is offline
Old 10-13-2007, 06:31 PM   #3
NintendoSkater
NintendoSkater's Avatar
Fan#: 43536
What I Drive: '07 Scion tc coupe
Points 3,050, Level 33
Points: 3,050, Level: 33 Points: 3,050, Level: 33 Points: 3,050, Level: 33
Level Up 50% Completed
FF Reputation: 1 NintendoSkater Good Standing Member
i think its a foot down along the cord that plugs into the alternator
2007 Scion TC coupe
NintendoSkater is offline
Old 10-13-2007, 08:18 PM   #4
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
I don't think there is one- the wiring diagram doesn't show one. But if there is one in that line somewhere, it's easy to check. Just take a test light or a voltmeter and, with the engine off, test for voltage at the big red wire on the back of the alt. You should have batt voltage there even when the engine is off. If you have nothing there, that wire is open somewhere on its way to the battery.
Since the headlights aren't going out during starting, I'd say there's something else going on there. There's a big junction box behind the battery. I think I'd start by going around in there and whacking each of those relays one with a screwdriver handle. There are some fairly major relays in there, and if one is stuck, it may be the reason the alt light stays on and the heads don't go out for starting. We're safe in assuming those two problems are being caused by the same thing. That's almost always the way it works...
Often wrong but never in doubt.
Blurvfocus is offline
Old 10-13-2007, 10:36 PM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,745, Level 78
Points: 14,745, Level: 78 Points: 14,745, Level: 78 Points: 14,745, Level: 78
Level Up 74% Completed
Forum Activity 10%
FF Reputation: 90 goinloco1 Excellent Standing Member
it's in the wire between the starter and alternator. looks almost like a splice. about 1 1/2" long and will have a flat side to it.
if it's bad, be prepared... ford only sells the positive cable as a set with the negative. through the dealer it's 75 bucks for the set.
oh, and the link is rated at 175 amps.
goinloco1 is online now
Old 02-07-2008, 05:59 AM   #6
sqrly
sqrly's Avatar
Fan#: 22581
What I Drive: 2008 white coupe s
Points 2,869, Level 32
Points: 2,869, Level: 32 Points: 2,869, Level: 32 Points: 2,869, Level: 32
Level Up 80% Completed
FF Reputation: 3 sqrly Good Standing Member
Buy-Sell-Trade Rating: (4)
well I have ran into the same problem with my 01 and what happened was the battery light came on i checked the wire and ended up pulling out the wire from the connector that goes to the alternator. I will try this and hope that it works I just hate screwing with that big black thing that hooks up to the starter. Thanks for the info
Zetec Crew #136
Xbox Live: SqrlyZX3
sqrly is offline
Old 02-10-2008, 10:46 PM   #7
focusmmuter
Fan#: 42492
What I Drive: 2002 Mach Audio Edition
FF Reputation: 1 focusmmuter Good Standing Member
Did this help any for you? I just replaced the pigtail and it ended not being the problem. Battery light still comes on and lights stay on when it dies after excessively low idle.
focusmmuter is offline
Old 02-11-2008, 12:53 AM   #8
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
Its about a foot off the alternator. Had to replace mine twice, I keep a spare with me just in case.
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 02-11-2008, 02:30 PM   #9
focusmmuter
Fan#: 42492
Before you changed the fusible link did you have these issues: while driving the battery light comes on then comes off after a while (usually no longer than 5 mins); when at a stop the idle drops really low and the battery light turns on and sometimes idles so low the car dies but starts back up very easily; when car turns off all accessories such lights, blower fan, dash lights, etc., still have power; sometimes, though very very rarely, a clicking noise is heard under the dash. Again, I changed the pigtail, since for most people it seems as though this fixes the problem, but with my luck I happen to be the exception. I doubt it is the alternator because this has been going on for months; I'm sure it would have fully crapped out by now. Plus, I have had it checked and the battery is fine. I hope it is the fusible link. How much did it cost? I hate electrical issues!
Old 02-12-2008, 08:55 PM   #10
49erRider
Fan#: 50175
What I Drive: 2000 black se
FF Reputation: 1 49erRider Good Standing Member
Hey man let me know through PM if you find anything because your symptoms are identical to mine.
49erRider is offline
Similar Threads
How To: Dash removal - broken link help! jstrunk MK1 Interior Mods & Upgrades 2 03-22-2007 03:28 PM
Link to shop manual? ouikikazz Ford Focus & General Car Chat 2 02-27-2006 09:14 AM
Miscellaneous Exterior Modifcations S2 MK1 Focus 0 01-27-2005 02:48 PM
well my other link didn't update...this is the link to my liquid grey ZX3 withnewpics avengerc4 Ford Focus Builds & General Showroom 6 10-18-2003 03:25 PM
