What sorts of problems has your Focus experienced? - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Official Polls & Surveys
Official Polls & Surveys Please take a moment and participate in our online polls and surveys.
View Poll Results: How serious have problems with your Focus been?
Nothing wrong with it! Really pleased with my decision to buy. 407 28.24%
Nothing too serious, minor work here and there. Hasn't broken the bank account yet! 787 54.61%
A number of costly and/or irritating deficiences with the car. Spent a fair bit of change fixing them, and would seriously reconsider buying again! 207 14.37%
So many problems that I will never buy a Ford again. Nearly went bankrupt due to repair shop bills! 40 2.78%
Voters: 1441. You may not vote on this poll
Old 07-07-2008, 08:46 PM   #101
lauzon
Fan#: 49048
What I Drive: 2003 zx3 pzev
FF Reputation: 1 lauzon Good Standing Member
very reliable car so far
lauzon is offline
Old 07-08-2008, 07:33 PM   #102
venomfocus
venomfocus's Avatar
Fan#: 907
What I Drive: A fast 2001 Pitch Black ZX3
FF Reputation: 1 venomfocus Good Standing Member
alternator went out, stablizer bent, some hoses sprang a leak or busted on me, (over 100k miles) other than that if i left the engine unmodded i wouldnt have any trouble out of it.
Doing Operation Restoring Hope to my Focus. Trying to get it back on the road around the same power level.
venomfocus is offline
Old 07-14-2008, 05:59 PM   #103
Brindfan
Infidel
Brindfan's Avatar
Fan#: 48126
What I Drive: 2013 Ford Focus SE Hatch - Race Red
Points 3,799, Level 38
Points: 3,799, Level: 38 Points: 3,799, Level: 38 Points: 3,799, Level: 38
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 3%
FF Reputation: 25 Brindfan Great Standing Member
26,500 miles and all is well.
"The only thing worse than a knee-jerk liberal is a knee-pad conservative." - Edward Abbey (1927-1989)
Hatch Nation#61 B.T.T.C.#3 ATX Faction#37 Rocky Mtn. Crew#3
Brindfan is offline
Old 07-18-2008, 05:15 PM   #104
chessjack061
Fan#: 56941
What I Drive: 2002 met gray
FF Reputation: 1 chessjack061 Good Standing Member
rear passenger bearing on wagon. Plus an irretating speedometer that has a mind of its own. now it works now it doesent.
Anyone got a suggestion?
chessjack061 is offline
Old 07-23-2008, 04:31 PM   #105
danielj24k07
Fan#: 54277
What I Drive: 2003,red,se duratec
FF Reputation: 1 danielj24k07 Good Standing Member
one thing ford really has to do is recall these stupid ignition cylinders. i just keep hitting it cause im not about to pay 200 for a new cylinder 2 new keys and it programmed and cut. ford should take responsibility.
danielj24k07 is offline
Old 07-24-2008, 10:33 PM   #106
elpibe7777
elpibe7777's Avatar
Fan#: 43698
What I Drive: 2012 FoFo SE Hatchback
FF Reputation: 1 elpibe7777 Good Standing Member
Cylinder 1 spark plug wire crapped out
Broken driver side mount. (Damn parking lot bumps, and drinking bad combo) as well as both 02 sensors.
Rear catalytic converter bracket broke. (Excuse to get a HFC)
Grounding problem. Fixed with $6 cables from local parts store.
Tires are getting worn in the inside.
Need to replace shocks and struts.
elpibe7777 is offline
Old 08-01-2008, 02:40 AM   #107
JiuceBox
JiuceBox's Avatar
Fan#: 56779
What I Drive: 03 Red ZX5/ 87 Mustang 5.0
FF Reputation: 2 JiuceBox Good Standing Member
The usual 67K woes.
replaced valve cover gasket
and fixed the thermo housing( i used a $0.99 generic gasket)
ford service station couldnt even figure it out after i told them wich part was bad.
ground cleaning
to be addressed soon:
cylinder lock
and alt(just to be safe)
JiuceBox is offline
Old 08-05-2008, 08:55 PM   #108
captcurt_18
captcurt_18's Avatar
Fan#: 49565
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 26 captcurt_18 Great Standing Member
had to have the wiring for the right side windows replaced cause it went out. other than that, just normal upkeep.
2005 Light Tundra ZX4 2002 BMW 325xi
Sedan Revolution Member #120
University of Montana
Photoshop Guru! PM me if you need something chopped up
Give me rep if im helpful!
captcurt_18 is offline
Old 08-14-2008, 10:52 AM   #109
nklaeger
Fan#: 58448
What I Drive: 2002 Ford Focus
Points 48, Level 1
Points: 48, Level: 1 Points: 48, Level: 1 Points: 48, Level: 1
Level Up 96% Completed
FF Reputation: 1 nklaeger Good Standing Member
My 2002 Ford Focus has had many problems shortly after it was purchased in 2002. Here is the list...
LF window regulator....repaired/replaced 3 times
RF window regulator....repaired/replaced 2 times
RR window regulator...repaired/replaced 2 times
Thermostat Housing...replaced 2 times
Thermostat...replaced 1 time
Thermostat Housing "O" ring...replaced 3 times
Valve Cover Gasket...replaced 2 times
Coolant Bypass Hose...replaced 1 time
Brakes...ongoing problems
Electric Door Locks...repaired two times
Shift Solenoid A...replaced two times
Oil Pan Leak...replaced new gasket
LF Axle Oil Seal...replaced one time
LF Half Shaft...replaced one time
LF Ball Joint...replaced one time
Wiper Motor Relay...replaced one time
Ignition Switch...replaced one time
Lower Transmission Cooler Line....repaired leak coming out of transmission
Brake Lights...repaired electrical shorts
The 2002 Focus SE w/Zetec only has 85,000 miles on it and I have been the only driver since day one. Fortunately, I have done most of the repairs myself so the actual dollars spent has been somewhat reduced...not paying a repair shop. If I had to pay a repair shop, I would have been bankrupt by now. I will never buy another FORD product again. By the way, I also own a relatively new Ford Expedition (Eddie Bauer) and this vehicle has ongoing quality issues.
nklaeger is offline
Old 08-14-2008, 07:40 PM   #110
DOliver84
DOliver84's Avatar
Fan#: 58495
What I Drive: 2004 Titanium Gray Rx-8
FF Reputation: 1 DOliver84 Good Standing Member
I have the usual Key Cylinder problem and a noisy Steering Linkage, nothing major
DOliver84 is offline
Similar Threads
Focus Problems Mrderwrtr General Technical Chat 6 07-14-2009 07:30 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Will the REAL Focus ST please stand up? flat 4 Ford Focus & General Car Chat 11 02-28-2005 06:40 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
NEW: Autoweek test of '04 Focus PZEV firemanfrank DURATEC Performance (2003-2007) 3 04-03-2004 10:24 PM
