Sway bar bushings and end bar links - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 06-12-2007, 09:08 PM   #1
Dago
Dago's Avatar
Fan#: 33842
What I Drive: 2004 comp orange svt
Points 4,462, Level 42
Points: 4,462, Level: 42 Points: 4,462, Level: 42 Points: 4,462, Level: 42
Level Up 56% Completed
FF Reputation: 1 Dago Good Standing Member
I just replaced my swaybar bushings today with polyurethane inserts from energy suspensions and also replaced the links, my car was making a sound when going through speed bumps, I did some research and found out the problem was the end links, so I decided to replace the bushings also with something better, when I removed the links, the sway bar was completely stuck I couldn't move it at all until I removed the bushings, when I installed the new bushings I put a good amount of grease inside the bushing and in the sway bar just to be sure it remains lubed for a while and now I was able to move the sway bar with no effort at all, the car feels good and I got rid of that annoying noise; if you got the same problem try it
JRSC BBK tuned by Tom, 65mm TB, 180 deg thermostat, aem wideband, 9mm ford racing wires, removed lunchbox, CFM hfc, front suspension polyurethane bushings, hella dynabeam headlights, keenwood ddx512
John 3:16
Dago is offline
Old 06-12-2007, 09:18 PM   #2
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: ganjabus
Points 39,337, Level 100
Points: 39,337, Level: 100 Points: 39,337, Level: 100 Points: 39,337, Level: 100
Level Up 0% Completed
FF Reputation: 27 dirtbrown Great Standing Member
yah...i saw these bushings on ebay.....u got the package right????
yah mine clicks and clacks.....just waiting i guess...
dirtbrown is offline
Old 06-12-2007, 09:37 PM   #3
Dago
Dago's Avatar
Fan#: 33842
I just got both bushings from energy suspensions for 15 bucks and 40 for the end links, It is cheap if you are already tired of the noise, the tricky part is to get the bolts that hold the clamps and the bushing, I used a really long socket extension (about 4')
John 3:16
Dago is offline
Old 12-05-2007, 09:46 PM   #4
jbremount
Fan#: 34777
FF Reputation: 1 jbremount Good Standing Member
Hello, My focus is make this noise also! Where are you guys getting the sway bar end links? Why are the bushing from energy suspensions used?
jbremount is offline
Old 12-06-2007, 01:35 PM   #5
Piersurf
Piersurf's Avatar
Fan#: 49987
What I Drive: 07 ZX4 SAP
FF Reputation: 1 Piersurf Good Standing Member
Buy-Sell-Trade Rating: (6)
Will this kit work with the Steeda 21mm rear sway bar kit? (I already ordered it so I hope so)
Prothane Rear Sway bar bushing kit for 21MM sway bar-SVT
http://www.newedgeperformance.com/in...ROD&ProdID=318
Piersurf is offline
Old 12-06-2007, 01:48 PM   #6
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
mine have been installed for months now
Old 12-06-2007, 02:24 PM   #7
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
I'm guessing that the inside diameter of the bushings is too small and when tightened is binding the bar. All the lube in the world won't overcome that. Make sure the bushings have the correct inside diameter for the bar diameter that you are using.
Geezer is offline
Old 12-08-2007, 07:24 PM   #8
Piersurf
Piersurf's Avatar
Fan#: 49987
I just finished reinstalling the 21MM Steeda rear sway bar using the prothane Rear Sway bar bushing kit for 21MM sway bar-SVT.
It fit perfect and best of all the noise is gone!
It looks just like the pic posted above.
Piersurf is offline
Old 01-24-2009, 07:33 AM   #9
annamd
Fan#: 62177
What I Drive: 1999,blue,focus
FF Reputation: 1 annamd Good Standing Member
Smile Thanks guys
I had the same problem around my front wheels and it was not until I read Dago's comments that I was able to fix it. I bought a pair of these bars on ebay for £14 and 1 hr of work and done!...focus is perfect again.
Anna
annamd is offline
Old 08-10-2011, 02:07 PM   #10
alinroiu
Fan#: 74921
What I Drive: 2008 coupe
FF Reputation: 1 alinroiu Good Standing Member
2008 focus
Will this bar bushing kit 21MM fit my 2008 Focus , any ideas?
Thank you
alinroiu is offline
Similar Threads
progress rear sway bar Noodles84 Wheels & Tires - Sponsored By Tire Rack 4 02-20-2007 10:03 PM
Sway bar end links... Sublime Wheels & Tires - Sponsored By Tire Rack 1 10-17-2004 07:42 PM
stock end links vs. prothane end links scironzts Wheels & Tires - Sponsored By Tire Rack 4 06-04-2004 11:15 AM
prothane sway bar bushings scironzts Archive 0 06-04-2004 08:26 AM
