Turn Signal wont turn off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2007, 11:51 PM   #1
isaac_in_tx
isaac_in_tx's Avatar
Fan#: 30675
What I Drive: 2003 Comp Orange Svt
FF Reputation: 3 isaac_in_tx Good Standing Member
Buy-Sell-Trade Rating: (11)
Well my friend just informed me that her turn signal if malfunctioning, she says it won't stop blinking after she has already turned. what could be the problem, and how would i go about fixing it? i have a Haynes Repair Manual but i can't find anything related to that problem, so can someone gives us a hand here, and btw i believe she has an '02 2.0zetec. thanks guys.
ATX Faction #25
ZETEC Crew #75
isaac_in_tx is offline
Old 06-11-2007, 11:53 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 135,811, Level 100
Points: 135,811, Level: 100 Points: 135,811, Level: 100 Points: 135,811, Level: 100
Level Up 0% Completed
Forum Activity 55%
could be the hazard swithc going out. Does the turn signal stock get stuck and can be move where it stops or is it stuk on no matter what?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 06-12-2007, 12:27 AM   #3
ryan2l
Fan#: 46512
What I Drive: 2007 Silver ZX3
FF Reputation: 1 ryan2l Good Standing Member
Yes does it just not automatically turn off when she is done with the turn (centers steering wheel) or are they stuck on no matter what position the switch is in?
ryan2l is offline
Old 06-12-2007, 12:55 AM   #4
strawhead
Fan#: 43158
FF Reputation: 1 strawhead Good Standing Member
you need a new airbag clockspring got one for my sisters car for 20 bucks off ebay or i think they are about $45 + shipping from bsir here on the forum
strawhead is offline
Old 06-12-2007, 06:37 AM   #5
torradan
torradan's Avatar
Fan#: 25031
What I Drive: 2005 ZX4
Points 2,375, Level 29
Points: 2,375, Level: 29 Points: 2,375, Level: 29 Points: 2,375, Level: 29
Level Up 50% Completed
FF Reputation: 7 torradan Good Standing Member
Does she have to turn it off manually? Or is it literally stuck blinking even with the signal stalk centered?
Probably just have to replace the turn signal assembly.
Had that problem many many years ago.. replaced the assembly, and it was all better again.
Western New York SCCA - Cone Killer #440
torradan is offline
Old 07-17-2007, 02:09 PM   #6
ncrapster
Fan#: 48835
What I Drive: 2000 blue Ford Focus
FF Reputation: 1 ncrapster Good Standing Member
stuck signal a defective multifunction switch
Isaac,
If my Ford dealer is giving me the right skinny, this problem is caused by a defective or worn out "multifunction" switch that drives the signal. Replacement costs about $160 at a Ford dealer, where my car now sits being repaired. I have had this same problem for years in a 2000 Focus wagon: left signal just starts on spontaneously, does not turn off after turn, often hard to keep off even when the turn signal lever is at neutral position...
NC
ncrapster is offline
Old 07-17-2007, 03:42 PM   #7
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
i will guarantee its the clock spring
those things go out like no other
and its easy to fix yourself as well
i had the same problem about a year ago.. the turn signals wouldnt self cancel...
go to dealer, pay about 50 bucks for a new clock spring
go home, disconnect battery, let sit for about a 1/2 hour
pop the top of the steering column off
pop out the multi function switch, as well as the washer switch
take off the 4 hex screws that hold the air-bag on to the steering wheel, and set the airbag aside
there will be one large nut that holds the steering wheel on the column, remove it, but make sure to either mark, or remember where the wheel was(ive found that its easiest to lock the steering wheel, then remove, so it goes on in the same place)
remove old clock spring
then put everything back, and youre done
should take about an hour to an hour and a half, depending on how mechanically challenged you are
MattZX3 is offline
Old 07-18-2007, 12:11 AM   #8
isaac_in_tx
Fan#: 30675
thanks guys, i appreciate the help
ATX Faction #25
ZETEC Crew #75
Old 05-26-2008, 12:49 PM   #9
Executionerhk
Executionerhk's Avatar
Fan#: 55338
What I Drive: 2000 VW Passat TDI
FF Reputation: 3 Executionerhk Good Standing Member
damn it, my clock spring broke too!!
I took everything apart... and found out the little thing on the steering wheel that push the turn singal back has broken...
other than buying a new clock spring...
anyway I can glue something back on to push the trigger?
Executionerhk is offline
Old 05-26-2008, 06:32 PM   #10
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
please just buy the clockspring
call Mike Trendel at 18008490233. he gets Ford parts at cost
scrammer is offline
Similar Threads
Turn signal cancel mechanism focus777 General Technical Chat 4 07-01-2005 08:51 AM
Turn Signal Mod (Can Anyone Help?) W~Phoenix~{RC} MK1 Focus 2 08-09-2004 09:23 AM
Turn signal problem Dypheron General Technical Chat 6 05-19-2004 09:31 PM
Impossible to have amber turn signal tail lights? JTMac MK1 Focus 9 04-11-2004 02:27 AM
Turn signal problem Iceskates2003 MK1 Interior Mods & Upgrades 4 02-05-2004 02:22 AM
