Rear Camber Bolt Install - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 06-11-2007, 12:02 PM   #1
eurotrashvrt
Fan#: 31074
What I Drive: 2002 Silver SVT
FF Reputation: 1 eurotrashvrt Good Standing Member
Alright, have been lazy to do this, and I paid dearly with my rear tires being eaten away at an extremely fast pace. My rear camber is at the -2.3 mark and basically the limit, but its not acceptable at all.
What I would like to know is what is a good setting to put the rear camber at, and the same with the front as I have front and rear kits.
Second question would, is there a write up on the install for these rear bolts, because I havent found anything definitive searching. The instructions I remember said something about cutting going on, dont know what that is about, but would just like to take care of the issue before I slap another set of rear tires.
My front camber I believe is at -1.8 or so and was wondering the same questions as with the rear.
Also what would be a good mark to have for autocross application as I could switch between the street and track settings. Thanks for your help.
Ill make sure to make a picture post on the install so we can put it in the "How To"
greg
It makes even the Enzo and the Porsche Carrera GT feel slow and pointless. It is a triumph for lunacy over common sense, a triumph for man over nature and a triumph for Volkswagen over absolutely every other car maker in the world.
Sincerely Yours,
Bugatti
eurotrashvrt is offline
Old 06-11-2007, 12:08 PM   #2
outafocus03
outafocus03's Avatar
Fan#: 17425
What I Drive: 2003 Black ZX5
FF Reputation: 1 outafocus03 Good Standing Member
pretty easy install. (working from memory about 3 years ago) The bolt that you remove to replace with the camber bolt has a nut on the back side of it. The nut is welded to the suspension. You will need to cut the welds with a cut off wheel or die grinder then you can smack the nut with a hammer to break it off the rest of the way. Grind down any residual welds left on the suspension then replace the new bolt in the hole. Setting the camber with the new bolts is pretty much guess work if you're doing it yourself. There is a lobe on the bolt that controls the camber adjustment.
JRSC BBK, full exhaust, progress springs and AGX dampers custom system install etc..... SOLD
Spring Into Focus 06' Best Engine Winner
outafocus03 is offline
Old 06-11-2007, 12:19 PM   #3
GaryS
GaryS's Avatar
Fan#: 32600
What I Drive: 2005 Yellow ZX3, 1990 Mazda Miata (
FF Reputation: 4 GaryS Good Standing Member
Huh? You must have given up too soon if you didn't find this.
GaryS is offline
Old 06-11-2007, 02:30 PM   #4
eurotrashvrt
Fan#: 31074
I guess I did, you are the equivilant of god, thanks.
Sincerely Yours,
Bugatti
Old 06-11-2007, 02:45 PM   #5
eurotrashvrt
Fan#: 31074
dpin;re
Sincerely Yours,
Bugatti
Old 06-11-2007, 03:00 PM   #6
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
While every car will be different, turn the camber bolts toward the center of the car. There is an arrow on the bolt head. Set it at about a 45 degree angle pointing upward. (1:30 or 10:30 poistion depending whether you inserted the bolt from the front or rear of the upper control arm bolt hole). This was the position that gave us about 1.3 degrees of negative chamber. Then get over to the alignment rack and make sure to tell them you installed the bolts. I went out and actually showed them where they were. I also painted the arrows bright yellow so they couldn't miss them. I recommend not more than -1.5 degrees of camber and keeping rear toe to the minimum allowable.
Geezer is offline
Similar Threads
Post Up! Did you need camber plates / rear camber bolts? DFv2 Brakes, Suspension & Body Chassis 1 06-10-2007 02:08 PM
Having issue with rear SPC adjustable camber arms ! mpcv2000 Brakes, Suspension & Body Chassis 27 03-31-2007 12:54 PM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 03:40 AM
00' Wagon rear camber Dave U General Technical Chat 3 07-15-2004 08:39 AM
rear camber bolt install Q's whiteboyslo Brakes, Suspension & Body Chassis 0 09-25-2003 01:25 PM
