Another camber plate question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2007, 01:43 PM   #1
eventerke
eventerke's Avatar
Fan#: 41299
What I Drive: 2002 Pitch Black SVT
FF Reputation: 3 eventerke Good Standing Member
Buy-Sell-Trade Rating: (14)
Question Another camber plate question
Still haven't heard from K-Mac about thier camber plates, but let me make sure I'm thinking correctly:
The LCR street camber plates claim -2.2deg - I assume this is from whatever the current "centered" strut position is.
My current alignment has -1.2deg camber with the stock mounting position.
So the LCR plates should give me -3deg without a problem, right? I'm sure that's the max I'd ever run.
eventerke is offline
Old 06-05-2007, 05:10 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
I don't believe that's a correct assumption. The numbers given by the manufacturer are min/max range based on the given mounting position/location of the camber plate.
Geezer is offline
Old 06-05-2007, 06:07 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Affirmative.
Though I've seen claims of as much as -2.5° when using the LCR plates,
you're not going to get any more than that unless you modify (cut) the top center hole in the strut tower.
WD40 is offline
Old 06-06-2007, 04:51 AM   #4
BadIdea
Fan#: 6470
What I Drive: 02 Silver SVT 08 Tundra CrewMax
FF Reputation: 1 BadIdea Good Standing Member
It's nothing to do with the top center hole, it's the spring hitting the strut tower. I have -3.2 with the leo's race plates and the car is lowered maybe 1.5 to 2"'s.
So it really depends on if you use a big or small spring, and how low your car is.
BadIdea is offline
Old 06-06-2007, 01:00 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Yes, I've read that as well, but still understood the center hole to be the limiting factor.
It'd be good to get a diameter measurement of stock springs versus aftermarket.
Do you have a dial caliper available to do that?
I'll also bet an additional 0.5° camber showed up automatically when you dropped the car.
WD40 is offline
Old 06-06-2007, 10:52 PM   #6
eventerke
eventerke's Avatar
Fan#: 41299
Here's K-Mac's email to me:
K-Mac (182516J) design allows the biggest range of
Positive or Negative Camber adjustment ( plus Positive Caster) of any kit on
the market
(we've been manufacturing kits longer than anyone
else with the worlds largest range Audit to VW)
24mm of Pos or 24MM of Neg which equates to
2 degrees either direction ( see instruction sheet
attached.)
Also the unique K-Mac patented design allows the
fastest adjustment - just 30 seconds to change from
street to race settings ( time taken to loosen the
3 top strut nuts)
Note: K-Mac also manufacture a rear Camber Kit-
replaces the upper inner arm bush providing up to 2 degrees Positive or
Negative ( with outer bush also
doubles this range to 4 degres!) #182526
Old 06-06-2007, 11:44 PM   #7
Impaled
Raise the stakes
Impaled's Avatar
Fan#: 46117
What I Drive: 2001 ZX3, 1998 ZX2
FF Reputation: 4 Impaled Good Standing Member
looks like they copy and pasted that from somewhere lol.
Impaled is offline
Old 06-07-2007, 08:59 AM   #8
BadIdea
Fan#: 6470
3 top strut nuts)
They are simply ignorant. Any small change in camber makes a big change in toe so there is no such thing as a 30 second street to race adjustment. You align the car on the rack and then leave it alone, just like ride height.
Stock springs have around a 5" I.D., and most coilovers have 2.25 or 2.5" I.D. Yeah nothing to do with the center hole.
BadIdea is offline
Similar Threads
suspension/ camber kit question gump1114 General Technical Chat 2 03-13-2006 06:10 PM
Questions about camber kit/if i need it/ is my suspension ok? sexy2002svt Brakes, Suspension & Body Chassis 7 10-05-2005 11:33 AM
Camber correction control arms Geezer Brakes, Suspension & Body Chassis 5 08-22-2005 10:12 AM
*Increasing* camber on non-lowered Focus Jason C SBB Brakes, Suspension & Body Chassis 1 04-03-2005 05:18 PM
