HOWTO: Peripheral Electronics ipod Interface to 05+ stock headunit w/ AUX - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2007, 10:52 AM   #1
torradan
torradan's Avatar
Fan#: 25031
What I Drive: 2005 ZX4
Points 2,375, Level 29
Points: 2,375, Level: 29 Points: 2,375, Level: 29 Points: 2,375, Level: 29
Level Up 50% Completed
FF Reputation: 7 torradan Good Standing Member
I tried to maximize the number of search words in the title to help people out, because I know its been asked 394 times, mostly with the "get a new headunit" response. That irks me lots.
I got tired of seeing everyone asking what item they'd need, or how to do this, so I tore my installation apart and took a few pictures to share. Takes a whole 10 minutes.
Our best friend here is a Peripheral Electronics PXDP2. I picked it up from Best Buy for $99+tax, but appears they aren't stocking them any longer. The original sticker price was $149. You can enter your ZIP code on PE's site for local dealers in your area. I've seen a couple other products around, but I can't vouch for them. I got this one because it would do exactly what I wanted it to do: I connect it, and I don't have to look at it again.
NOTE: Your headunit must say "MP3" on it, or this will NOT work.
If it doesn't, then "get a new headunit", which irks me, applies to you unfortunately. And FM transmitters suck. :(
So, lets get started here.
Removing the bezel around the stereo. There is already a howto about this, but oh well. I was having fun taking pictures.
Grab the top lip of this guy, and give it a little tug down to remove it:
a little product placement in there.
Now that the little useless tray it out of the way, stick your hand up in there, and GENTLY push the bezel out. There are four prong things that hold it into the plastic. Once you get the bottom out, work your fingers along the edges, and then pop the upper ones out.
NOTE: For automatics, pull the parking brake, and put it into 1st to give yourself some space.
Next, check out your new goodies.
The only thing missing is the cable for the ipod, as I ran it along the console and into the armrest. The sucker is 11ft long, so you can pretty much run it anywhere your little heart desires.
Next up, remove the radio. There are four 7mm bolts holding it in. Be careful not to drop them, or you'll be putting three of them back, because you've dropped one down under the carpet. Not that I know this from personal experience or anything.
Unplug the big connector, and put the PE harness in line with it. Also, the other little connector goes into the empty spot on the radio.
MAKE SURE YOU SET THE DIP SWITCHES ON THE LITTLE INTERFACE BOX, OR ITS NOT GOING TO WORK PROPERLY.
Plug everything into the interface box, and tuck it away.
It sits in there pretty nice. Couldn't find any zip ties, so we'll see what happens.
Now slide everything back in place, and reverse the order of removing the radio.
All set!
Here is where I put my ipod:
Easiest way to do this is to disassemble the arm rest, because you'll have to drill two holes. I put a rubber grommet in there to prevent any rubbing, and its a little more aesthetically pleasing than a boring hole in plastic. ($1 from autozone in the help parts. I believe its a Toyota PCV something-or-other).
Now, the best part: Forget that the iPod is there! The only time you need to touch it is to connect or disconnect it. The headunit and steering controls will control everything. This was the deal maker for me with this item. I don't like to take my eyes off the road to fiddle with things. The menuing system allows you to select playlists/etc.
I hope this helps people out! If you have any questions, drop me a line. I'll probably be quick to answer on weekdays, because this place helps keep my sanity while at work.
EDIT: Adding armrest pictures!
The first thing you want to do here, is remove the plastic bit from behind the armrest.
You should be able to pry it out with your fingers. Start at the top and pop it out.
Next up, remove these two screws! They hold the whole armrest on.
After you've taken the screws out, remove the two plastic circles. They're only held on by a pair of clips. Be a little gentle with them.
This is what happens when you take a header into your car after slipping on ice:
It makes the armrest wobble a little bit, but those plastic circle bits hold things in place. The pivot for the armrest is only plastic.
Next up, remove one screw on each side. This releases part of what holds the black inner plastic part to the rest of the armrest:
After this, remove the 3 screws holding the top of the armrest:
Once you have those screws out and the cover set aside, you'll notice a notch that was hiding. Place anything flat in there, and it will just come loose.
NOW BE CAREFUL because the front of the inner part of the armrest is held in with two clips:
That pretty much disassembles the whole deal. Then you just need a spade bit to cut the holes into the inner and outer pieces. I think I used a 1/2" bit. I just sized one up with the plug that goes into the PE interface box.
The bottom:
The inner part:
This is where the wiring ran down into the whole console:
Now, when you wire this in, it needs to be done BACKWARDS. Because you'll never get the connector for the ipod through these holes.
To remove the whole console, its only held in by 3 screws. One under each cup holder in the front, and then under a plastic plug in the rear cup holder (good luck removing this -- and it will probably be destroyed upon removal). Unplug heated seats/traction control switches, wrestle it out of the way, and run your wiring. You shouldn't have any problems getting the wire up from the bottom and into the cavity where the radio goes.
Reverse the process, and voila, all the wiring is hidden.
BRIEF UPDATE: socalsuzuki sent me a message about this interface causing Mustangs to go haywire (gauges not working, car not starting, etc). I emailed Peripheral Electronics, and got a reply back assuring me that the problem is only with the Mustang, and not the Focus.
Western New York SCCA - Cone Killer #440
torradan is offline
Old 06-05-2007, 10:58 AM   #2
p0sitivevibez
p0sitivevibez's Avatar
Fan#: 11223
What I Drive: SVTF
FF Reputation: 1 p0sitivevibez Good Standing Member
Buy-Sell-Trade Rating: (6)
WOW. That is really cool you got that tucked away in the armrest. I never put anything in there either. Did you run it under the seat or under the carpet or even under the shifter/cupholder housing?
p0sitivevibez is offline
Old 06-05-2007, 11:03 AM   #3
torradan
torradan's Avatar
Fan#: 25031
I pulled out the whole console and ran it back there. Tried to push it up under the edge, but I was afraid of cutting into the cord with any sharp edges.
torradan is offline
Old 06-05-2007, 11:15 AM   #4
TKE_Quailman
FF God of South FL
TKE_Quailman's Avatar
Fan#: 44442
What I Drive: 07 Pitch Black ZX3
FF Reputation: 35 TKE_Quailman Great Standing Member
awsome you should of run a how to on how you put it in your armrest
02 Black ZX5 R.I.P.
07 Black ZX3 Work in progress
Last of the Hatches #1
XBOX LIVE:TKE428
GIVE REP POINTS IF IM HELPFUL
TKE_Quailman is offline
Old 06-05-2007, 09:42 PM   #5
torradan
torradan's Avatar
Fan#: 25031
I'll yank it apart and take a couple pictures after work tomorrow to add to the end. It comes apart pretty easy.
torradan is offline
Old 06-25-2007, 12:52 PM   #6
jumpboy
jumpboy's Avatar
Fan#: 46739
What I Drive: 2006 Black ZX4 w/ SAP
FF Reputation: 1 jumpboy Good Standing Member
Bump, for the armrest part :) Are you still gonna post it?
jumpboy is offline
Old 06-25-2007, 01:03 PM   #7
torradan
torradan's Avatar
Fan#: 25031
Sorry about that! I totally forgot about the pics
Made a note for myself to do it this afternoon!
torradan is offline
Old 06-25-2007, 07:50 PM   #8
torradan
torradan's Avatar
Fan#: 25031
Updated for TKE, positivevibez, & jumpboy's enjoyment!
torradan is offline
Old 06-25-2007, 09:13 PM   #9
BeeFzX3
BeeFzX3's Avatar
Fan#: 46655
What I Drive: 2013 Focus ST
Points 5,963, Level 50
Points: 5,963, Level: 50 Points: 5,963, Level: 50 Points: 5,963, Level: 50
Level Up 7% Completed
FF Reputation: 40 BeeFzX3 Great Standing Member
Buy-Sell-Trade Rating: (8)
Awesome!!!
That is exactly what i wanted to do, except put just a regular AUX in "the little useless tray" so i can plug in there whatever i want.
I was planning to use PIE FRD04-AUX Adapter (http://www.crutchfield.com/S-HzgOhaR...e&i=469FRD4AUX)
Nice job!
BeeFzX3 is offline
Old 06-25-2007, 11:37 PM   #10
Lockdown
Lockdown's Avatar
Fan#: 45876
What I Drive: 2007 CD-Silver ZX3
FF Reputation: 2 Lockdown Good Standing Member
Buy-Sell-Trade Rating: (4)
Nice I will be definitely be doing this soon. My Ipod just died on me but im going to buy a new one next week.
Also were did you run the cable so it would get to the arm rest? What did you have to remove or mod to get the cable their also (mainly to get the cable out of the dash)
Steeda S.R.I, Eibach Pro-Kit Springs, FS Front Stress Bar, ST Grill, Trubendz 2.5 Magnaflow SS, 03 SVT Rims, 215/45/17 tire, Soon: F2 Headers
Team Duratec #59
Lockdown is offline
Similar Threads
WTB: Audiophile Amp... and/or Stock audiophile headunit Malakai Archive 1 04-05-2007 06:02 AM
Bought a new HU & Ipod Interface spydee Car Audio, SYNC, MyFord Touch & Electronics 8 12-29-2005 04:51 PM
Stock HU iPod Dock-Connector Input Adapter for 2000 to 2003 FocusInCali Car Audio, SYNC, MyFord Touch & Electronics 8 09-28-2004 05:38 AM
