Replacing wheel bearing how to remove lower control arm - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 06-03-2007, 06:26 PM   #1
sffish
Fan#: 47718
What I Drive: 2000 Ford Focus SE Wagon
FF Reputation: 1 sffish Good Standing Member
I'm replacing the driver's side front wheel bearing on my 2000 Ford Focus SE Wagon. How do I remove lower control arm from the spindle containing the wheel bearing? The Ford shop manual says to use a special tool to remove the lower control arm (separate the ball joint?) but doesn't say what this tool is. Also after you separate the spindle and lower control arm, how do you reassemble it? There is a pinch bolt that I removed, but I'm still not sure how to reassemble the part. I think you're supposed to use these pickle fork like tools to separate the lower control arm, just stick the fork between the arm and the spindle and hit it with a hammer? Thanks.
sffish is offline
Old 06-03-2007, 08:58 PM   #2
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
un screw the nut from on top of the ball joint and hit it out with a hammer, and when u want to put it back it, make sure u have an air compressor with an air gun to zap it back on. to do the wheel bearing u need to pull the hub off cause it is a pressed bearing and have a shop press the new one in
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 10:54 PM
Rear wheel bearing dust cap Syl General Technical Chat 1 07-14-2005 05:34 PM
Front wheel bearing replacement quicksilver General Technical Chat 15 05-25-2005 02:17 PM
Wheel bearing bad and tire stuck reamkeeper General Technical Chat 20 03-28-2005 07:16 AM
