Body roll question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-01-2007, 08:30 PM   #1
roughrider1988
roughrider1988's Avatar
Fan#: 47412
What I Drive: 2002, blue, zx3
FF Reputation: 1 roughrider1988 Good Standing Member
Body roll question
What is the easiest and least expensive way to cut down the body roll when taking curves at high speed? (65-70mph)
roughrider1988 is offline
Old 06-01-2007, 08:37 PM   #2
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
new suspension w/ swaybars, and a rear strut tower brace
MattZX3 is offline
Old 06-01-2007, 08:44 PM   #3
EvilGenius
EvilGenius's Avatar
Fan#: 38939
What I Drive: 2001 Silver ZX3 5spd
FF Reputation: 4 EvilGenius Good Standing Member
I would think bigger sway bars, but if you're doing it at high speed you need to go over everything like matthewstetz said.
EvilGenius is offline
Old 06-01-2007, 10:06 PM   #4
roughrider1988
Fan#: 47412
so what kind of suspension do i look for?
Old 06-01-2007, 10:25 PM   #5
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
well, you could do the svt suspension.. its about 275 bucks through steedafocus.com
you can also do an eibach suspension... will cost more, but will help out a LOT more
you can order that through massivespeedsystem.com
MattZX3 is offline
Old 06-01-2007, 10:30 PM   #6
roughrider1988
Fan#: 47412
if i'm gonna go through all of that installation, should i look into new rims and tires also? mine look like stock 5-spoke rims.
Old 06-01-2007, 10:40 PM   #7
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
you dont have to, but with a 17 inch rim, you can get a nice set of 215's on there, and the wider the tire, the better dry traction you get... so it couldnt hurt
also, if you do get a new set of rims and tires, use the new rims for the summer, and get summer tires put on them
then use the stockers for the winter
MattZX3 is offline
Old 06-02-2007, 09:01 AM   #8
guitarseth
Fan#: 7887
What I Drive: 2003 French Blue Metallic ZX3
FF Reputation: 3 guitarseth Good Standing Member
Body roll is not something that you want to eliminate completely. Not only is it pretty much impossible, its also rather dangerous to have zero suspension compliance. You'll lose traction over uneven pavement and probably knock your fillings out in the process.
Suspension-wise, if you're looking to nearly eliminate body roll, you'll want to look at something with a high spring rate. The SVT springs are good, but their still OEM, so their only marginally stiffer than stock. My recommendation is a set of H&R race springs with KYB AGX adjustable shocks. Those springs give about a 2" drop and I want to say they're about 3 times more spring rate than stock. The adjustable shocks will allow you to stiffen up the bounce setting, which should keep the car a bit more level through the corners.
Swaybars are generally something that you want to dial in last. However, on a street car, they are generally used as a crutch to avoid super high spring rates (which dimish ride quality immensely). My philosophy is that you really shouldn't need a rear swaybar bigger than 24mm. I don't really see any reason to upgrade the front swaybar, as its a PITA to replace and I've never had any trouble with the front end of the car.
I've got FK 60/40 springs coupled with Spax adjustable shocks/struts and a Progress 22mm rear swaybar. Its a setup that I cobbled together on the cheap, so its obviously not ideal, but I think I've got it tweaked pretty well. I'm scheduled for an alignment on Tuesday, so hopefully that will take care of my remaining issues, such as my bad rear toe-in, which has lead to a nearly bald tire (which results in a scary ride in the rain).
guitarseth is offline
Old 06-02-2007, 03:18 PM   #9
roughrider1988
Fan#: 47412
This is really to help the car in those nice curvy country roads where the cops are absent and you can use the accelerator more liberally. I just don't want the car to lean so much in those curves.
Old 06-02-2007, 03:30 PM   #10
FleaWannaBe
WHITE ON BLACK :)
FleaWannaBe's Avatar
Fan#: 45837
What I Drive: 2005 White ZX3
FF Reputation: 2 FleaWannaBe Good Standing Member
i would hold out on rims and get coilovers. i wishi would have.
FleaWannaBe is offline
Similar Threads
Body Kit Question!!!! usefulidiotzx5 MK1 Focus 4 03-13-2006 06:28 PM
Throttle body question justfocus ZETEC Performance (2000-2004) 13 03-09-2006 11:52 PM
65mm Throttle body serious question Enkidu SVT Performance (2002-2004) 17 11-22-2004 07:08 AM
Where to buy Wings West Avenger Body Kit radicalblu MK1 Focus 3 11-14-2004 04:27 AM
Throttle body question Toptech ZETEC Performance (2000-2004) 18 02-03-2004 12:37 AM
