Remote release rear hatch doesn't work - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-26-2007, 04:42 PM   #1
shargue
Fan#: 3712
FF Reputation: 1 shargue Good Standing Member
The remote release both on the dash and my key fob stopped working a couple weeks ago on my 2003 SVTF. I hear a double click sound from the passenger side behind the glove box when I hit the release on the dash.
I've checked the motor in the hatch release and both the ground and green and white wire (power wire to the motor) from the junction box behind the driver's side kick panel and that's all OK. Does anyone have an idea what might be causing this problem?
shargue is offline
Old 05-26-2007, 04:52 PM   #2
roughrider1988
roughrider1988's Avatar
Fan#: 47412
What I Drive: 2002, blue, zx3
FF Reputation: 1 roughrider1988 Good Standing Member
My dash release doesn't work either. Be interested to see if anyone has the answer.
roughrider1988 is offline
Old 05-26-2007, 04:53 PM   #3
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
well, i know there was a recall for rusting latch hinges for the hatches
it could be a relay... or a burnt fuse
does the key still open it?
MattZX3 is offline
Old 05-26-2007, 05:09 PM   #4
roughrider1988
Fan#: 47412
The key still works on my hatch release
Old 05-26-2007, 05:14 PM   #5
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
its got to be either a relay, fuse, or the locking mechanism itself(inside the hatch)
thats the only thing that makes sense to me
MattZX3 is offline
Old 05-26-2007, 09:32 PM   #6
shargue
Fan#: 3712
Maybe the problem is in the GEM
My key works fine. In fact, I've taken the latch out and checked the motor which operates fine. The sound I hear when I hit the hatch release button sounds like a relay located in the Generic Electronic Module (GEM). It's literally a black box hidden behind the glove box and next to the ECU.
There are some other pics of the GEM at this thread: http://www.focusfanatics.com/forum/s...ght=gem+module
This thread describes some of how the GEM controls the remote hatch release through a relay: http://www.focusfanatics.com/forum/s...ght=gem+module
Pin 87 is supposed to be part of the trunk release relay and so I'm wondering if this relay is malfunctioning. If I get brave I'll try taking the GEM out and take a peek inside.
shargue is offline
Old 05-26-2007, 11:47 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I don't think it's supposed to work if the key is in the ignition. I noticed this recently when I wanted to pop my hatch- as soon as I pulled the key out, it worked.
I hope that's all that your problem is.
Roughrider1988--- what's up brother? L.U. 474 here. You IW or OW? PM me sometime if you want any advice on tramping.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 05-26-2007, 11:54 PM   #8
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
yea, like i said, its probably either a relay or a fuse
but, does it sound like its unlatching from the hatch too? or is it just making noise inside the car
MattZX3 is offline
Old 05-27-2007, 03:54 PM   #9
shargue
Fan#: 3712
Opened up the GEM
Well I got brave, disconnected the negative on the battery and pulled out the GEM. It's a printed circuit board (PCB) and I see two relays soldered to the PCB. Now that I'm really intimidated, I put it all back together and at least everything worked as well as it did before.
I know that this is not a problem with the hatch latch. I've taken that apart and tested the motor which works fine. While I was at it, I fixed the common problem with the latch sticking when it's released. I posted the fix for this problem here: http://www.focusfanatics.com/forum/s...ighlight=latch
and here: http://www.focusfanatics.com/forum/s...ighlight=latch
I'm going to have to ask an electrical engineer friend of mine if he thinks it's possible to replace the relay on the PCB.
shargue is offline
Similar Threads
Upper grill and rear hatch trim schneller ZX3 Archive 0 08-20-2005 07:13 PM
Ok tried searching Rear hatch trim Knuckles899 MK1 Focus 2 04-27-2005 10:30 PM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
hatch release button doesn't work bigeasysvt General Technical Chat 3 09-15-2004 04:34 PM
power locks/power hatch release help slick761 General Technical Chat 3 03-23-2004 05:28 PM
