ZX3 Trailer Lights Wiring Tips - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-26-2007, 03:19 PM   #1
ajohn505
Fan#: 19178
What I Drive: 2005 Liquid Grey ZX3
FF Reputation: 1 ajohn505 Good Standing Member
Ford Focus ZX3 trailer wiring information is hard to come by for some reason. People here are quick to say "buy the Haynes manual, look at the wiring diagram" which is certainly good advice, but not what you're looking for on an online forum.
Here's how I wired my 2005 Ford Focus ZX3 for trailer lights using a 72" 4-wire hardwire kit from eTrailer.com:
1. Remove the carpet covering the spare tire.
2. Loosen the left side interior molding on the trunk area. There are 4 metal screws (and 1 plastic screw + fastener near the seatbelt area). Note that I left the side towards the front of the car still attached.
3. Remove the plastic molding along the bottom rear of the trunk. There are 4 plastic screws + fasteners.
4. Remove the fastener holding down the left side carpet that's located near the rear.
6. Pull back the carpeting and interior molding, exposing the wiring. You will see 2 push-in connectors. One of the connectors will have a Y connection about 3 inches away from it - one of the bundles will travel along the bottom of the rear of the trunk to the right side taillight and the other bundle will head up the rear of the car to the left taillight
After the Y splits off, you splice the wires as follows:
Use a razor to carefully cut into the black electrical tape around the bundle of wires. Be careful not to damage the wires themselves
7. Using the tap splices that came with your hardwire kit, connect the Left turn signal lead to the predominately light blue wire leading to the left taillight. Connect the Taillight lead to the predominately orange wire leading to the left taillight. Connect the Ground lead to the black wire leading to the left taillight. For the Turn signal, be careful that you're tapping into the light blue wire going to the tail light and not the one going to the trunk light. When you're looking at everything back there it will make sense.
8. Using a tap splice, connect the Right turn signal lead to the predominately light blue wire leading to the right taillight. You can splice it right after the Y splits off towards the right taillight and not have to remove any molding or anything on the right side.
Be sure you completely (but gently) press the tap splice closed with pliers. The metal part of the tap should be flush with the plastic housing.
That's it. I ran the wires under the carpeting in the spare tire area and plan to just leave it hanging out the back of the hatch when I tow my motorcycle. Just put all the carpeting and molding back in place and you're all set.
I don't get it - There is a push-in connector on the Left side of the car - why doesn't someone make a T-connector for it?
The Curt trailer from e-trailer.com went on perfect as well, the drilling of the frame on the right side being the only annoying part. Be sure to torque everything down to 75 lbs. with a torque wrench. It's a lot of torque, and not an amount you can put on with a short-handled wrench.
ajohn505 is offline
Old 05-26-2007, 03:36 PM   #2
auto
Made In The USA
auto's Avatar
Fan#: 42455
What I Drive: Pitch Black 07 ST w/S.A.P.
FF Reputation: 89 auto Excellent Standing Member
Great post! I don't tow with my car but I know some here do and this will probably come in handy!
You should snap some pics of the process to go along with each step......
But either way great post!
Thats it Mr.! You just lost your brain privileges!
auto is offline
Old 05-26-2007, 04:09 PM   #3
ajohn505
Fan#: 19178
I was thinking about pics, but I had to get everything done before the rain started... either way I figured that someone that's going to tackle a trailer hitch install and trailer wiring would find this to be enough info.
I'm not going to tear it apart now for pics :)
ajohn505 is offline
Old 05-27-2007, 01:01 AM   #4
ajohn505
Fan#: 19178
I forgot to note -
Be sure that when you loosen the side molding on the left side that you reach around behind the trunk light and remove the light from its holder - just turn the whole bulb assembly (don't touch the bulb itself) counterclockwise and it will slide rearwards.
ajohn505 is offline
Old 06-26-2007, 11:10 AM   #5
paul-WI
Fan#: 48289
What I Drive: 2007 black 3 door SE
FF Reputation: 1 paul-WI Good Standing Member
I joined this forum to find this specific information. It was very helpful. I have an 07 3 door and installed a Kurt hitch. That was a piece of cake. I needed the color codes for taillight/turn signals and found them here. The only thing I did different was I tapped in before the wires seperate to each tail light. I used a pick at the plug to determine which wire goes where. Here is what I found:
Orange - tail lights
blue/red - right turn
blue - left turn
black - ground
Yours may be different, but I doubt it. Just use a pick at the connector.
Thanks for the info
paul-WI is offline
Old 08-04-2007, 04:08 PM   #6
carcrash
Fan#: 46015
What I Drive: 2004 Silver Focus LX
FF Reputation: 1 carcrash Good Standing Member
I can confirm the wiring colors are the same for the 2004 Focus Sedan LE. I also tapped in before the wires separated, it is much easier and cleaner IMHO.
One more addition to paul-WI's instructions though:
Green with black stripe - brakes
(it is the wire that is spliced into two already, one wire to each side)
carcrash is offline
Old 02-27-2009, 06:09 PM   #7
mwalsh
mwalsh's Avatar
Fan#: 56630
What I Drive: 2003 Focus ZTS | 2005 Focus ZX3
FF Reputation: 2 mwalsh Good Standing Member
Anyone know if the wiring for the '03 will be the same?
Got my hitch installed already and am just waiting for a Euro 50mm ball (no a 2" ball won't work!) before I get stuck into the lighting connections.
mwalsh is offline
Old 02-27-2009, 09:05 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
I'd probe the connector to double check.
... and how is it you need a euro spec ball for a US spec car/trailer? That shouldn't be.
OH, you're not playing dumb ...
iminhell is online now
Old 02-28-2009, 11:24 AM   #9
mwalsh
mwalsh's Avatar
Fan#: 56630
Ah, but my trailer coupling is Euro spec too, you see.
mwalsh is offline
Old 03-06-2009, 04:33 PM   #10
mwalsh
mwalsh's Avatar
Fan#: 56630
Well, I got my Euro ball in the mail this morning. Still haven't done the wiring for light yet, but those parts I can pick up pretty easily:
mwalsh is offline
Similar Threads
FS - Tinted Zx3 Tail Lights 01MalibuBlueZx3 Archive 11 04-30-2007 02:10 PM
tail lights for zx3 BLKfoc18 Archive 8 04-14-2004 01:58 PM
ZX3 fog lights faba_2005 General Technical Chat 5 02-29-2004 09:39 PM
ZX3 and ZX5 Tailight Wiring Focusedat50 Ford Focus & General Car Chat 0 02-13-2004 03:09 PM
Tail Lights on zx3 beat3rfocus MK1 Focus 1 02-08-2004 04:50 PM
