code P2258 on XCAL? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2007, 01:19 AM   #1
UncommonCustoms
UncommonCustoms's Avatar
Fan#: 2100
What I Drive: 03 ZX3 5-SPD PZEV / F250 superduty
FF Reputation: -3 UncommonCustoms Poor Behavior Needs Improvement
code P2258 on XCAL?
I am throwing a check on a code p2258 when I scanned it with my xcal2 ,,... also I just finnished putting my car together and it moves. I am going to post the build shortly but I am having some probs with my camera... it kinda died and I lost allot of good pics
UncommonCustoms is offline
Old 05-25-2007, 12:49 PM   #2
UncommonCustoms
Fan#: 2100
2258 anyone????? anyway back out to the garage I am putting my sparco corsa's in today
Old 05-25-2007, 01:50 PM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Looks like a problem with the secondary air pump.
P2258 Secondary Air Injection System Control A Circuit High
http://www.motorcraftservice.com/vdi...f/OBDSM505.pdf
Secondary air systems typically utilize an electric air pump as well as one or two electrically controlled check valves to deliver air into the exhaust manifold.
The only vehicle which uses secondary air is the 2.3L PZEV Focus. The Focus uses a system with ported air. This means that airflow is delivered to each individual exhaust port. The secondary air pump is energized soon after start-up while the fuel system is in open loop and icing conditions are not likely. After the O2 sensors warm up, the secondary air pump continues to be energized while the fuel system goes into closed loop fuel. The secondary air system continues to run in closed loop fuel until the air pump is de-energized. The typical time period in which the AIR pump is energized is approximately 12 seconds.
The AIR pump flow check monitors the HO2S signal at idle to determine if secondary air is being delivered into the exhaust system. The air/fuel ratio is commanded open-loop rich, the AIR pump is turned on and the time required for the HO2S signal to go lean is monitored. If the HO2S signal does not go lean within the allowable time limit, a low/no flow malfunction is indicated. (P0411)
The electric air pump draws high current and must be energized through a separate relay. Both the primary and secondary circuits are checked for opens and shorts. First, the output driver within the PCM (primary circuit) is checked for circuit continuity (P0412). This circuit energizes the relay and the vacuum-operated check and control valve(s). Next, a feedback circuit from the secondary side of the relay to the PCM is used to check secondary circuit continuity (P2257, P2258).
Egz is offline
Old 05-25-2007, 05:08 PM   #4
UncommonCustoms
Fan#: 2100
thanks egz
Old 05-25-2007, 05:27 PM   #5
strung
PIMP'N AINT EASY
strung's Avatar
Fan#: 44516
What I Drive: 06 RED ST/SAP1
FF Reputation: 34 strung Great Standing Member
egz always comes thru....that guy must have more rep points than i have money.
ST CREW #62
put your motor where your mouth is.
strung is offline
Similar Threads
SVT Header swap. Help me Troubleshoot a DTC P2195 Code starfuryt550 General Technical Chat 11 05-03-2007 10:09 PM
P1132 Code? HitTheNutz General Technical Chat 7 11-20-2006 09:28 PM
Xcal 2 And ECU Code djmtrain SVT Performance (2002-2004) 3 03-08-2006 07:10 PM
Code 171 System too lean? ispy General Technical Chat 11 08-31-2004 09:35 PM
throwing low fuel pressure code? 00si General Technical Chat 1 08-01-2004 10:09 PM
