P0401 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 05-21-2007, 10:03 AM   #1
BrokenWings-Tears
Fan#: 20783
What I Drive: 2001 Green ZX3
FF Reputation: 1 BrokenWings-Tears Good Standing Member
P0401
So the check engine light keeps comming on: P0401. I've replaced the EGR valve and EGR solenoid (sp?) twice and it still keeps "missing". Anything below 40mph or 3500 rmp and it feels like you are running out of gas. I read there is the EGR sensor on some models, but I haven't been able to locate it. Any help would be greatly appreciated.
BrokenWings-Tears is offline
Old 05-21-2007, 10:41 AM   #2
raulfsa11
raulfsa11's Avatar
Fan#: 45601
What I Drive: 2000 Focus ZX3 White
FF Reputation: 11 raulfsa11 Great Standing Member
FUEL RAIL PRESSURE SENSOR... same problem cured...
_______________________________
My ZX3 RULEZZZ!
raulfsa11 is offline
Old 05-21-2007, 10:48 AM   #3
lildisco
RespectMyAuthoritah!
lildisco's Avatar
Fan#: 5761
What I Drive: 06 Mazda6i, 08 Mazda CX7 GT AWD
Points 30,278, Level 100
Points: 30,278, Level: 100 Points: 30,278, Level: 100 Points: 30,278, Level: 100
Level Up 0% Completed
FF Reputation: 47 lildisco Great Standing Member
Buy-Sell-Trade Rating: (8)
P0401 - EGR Flow Insufficient Detected The EGR system is monitored during steady state driving conditions while the EGR is commanded on. The test fails when the signal from the DPF EGR sensor indicates that EGR flow is less than the desired minimum. Vacuum supply
EGR valve stuck closed
EGR valve leaks vacuum
EGR flow path restricted
EGRVR circuit shorted to PWR
VREF open to D.P.F. EGR sensor
D.P.F. EGR sensor downstream hose off or plugged
EGRVR circuit open to PCM
VPWR open to EGRVR solenoid
D.P.F. EGR sensor hoses both off
D.P.F. EGR sensor hoses reversed
Damaged EGR orifice tube
Damaged EGRVR solenoid
Damaged PCM
Perform KOER self-test and look for DTC P1408 as an indication of a hard fault. If P1408 is not present, look for contamination, restrictions, leaks, and intermittents.
P1408 - EGR Flow Out of Self-Test Range (Non MIL) This test is performed during the KOER on demand self-test only. The EGR system is commanded ON at a fixed engine speed. The test fails and the DTC is output when the measured EGR flow falls above or below the required calibration . For vacuum activated systems see Possible Causes for DTC P0401.For electric motor system see Possible Causes DTC P0400. For Electric EGR, use the output state control function of the scan tool and monitor the MAP PID (MAP) and the EEGR PID (EGRMDSD) while commanding the EEGR on. If EGR is introduced into the engine at idle, the rpm will drop or stall out. For vacuum systems see Diagnostic Aids for P0401.
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat."
06 Spring Into Focus Best Sedan/Wagon Winner
03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT
lildisco is offline
Similar Threads
P0401 - EGR Flow Insufficient Detected Error Code (Help) Chelica General Technical Chat 14 06-21-2004 12:20 PM
P0401 / EGR press low / Help? fieldcar Ford Focus & General Car Chat 4 06-11-2004 03:42 PM
