Forced Induction Cam Thread - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-16-2007, 02:45 PM   #1
CatMostFeared
FocusXtreme
CatMostFeared's Avatar
Fan#: 20987
What I Drive: Wicked 2000 Turbo Zx3
Points 22,756, Level 93
Points: 22,756, Level: 93 Points: 22,756, Level: 93 Points: 22,756, Level: 93
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 20 CatMostFeared Great Standing Member
Buy-Sell-Trade Rating: (23)
Ok this is everyone chance to talk about ,prove and show what they now about cams.What work best with turbo motor big cam small cam or stock cams.If you have a opinion or knowledge about whats best for FI cams post it here.I know everyone else wants to know.I know Ray at McNews sell some special FI cams and Crower makes some just for FI and Turbo Tom likes them stock.Just to remeber there is no name calling or bashing people
we just wanna know what to use.
2000 Turbo ZX3
CatMostFeared is offline
Old 05-16-2007, 03:14 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
It isnt that i dont like Performance Zetec cams its for the 350.00 that they cost they ,in my opinion for the cost vs the gains they are not worth it and I have tested most of whats out there other then custom grinds
Im sure when you get to 300 or 350+ HP that there will be more gains out of cams but you will need a custom grind then to work with what you are going to do with the Focus
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-16-2007, 03:15 PM   #3
bryfsvt
Fan#: 33542
FF Reputation: 7 bryfsvt Good Standing Member
I was lookin at the Crower cams turbo grind.. theses would be applied to the 2.3 turbo
06-ST: Not your typical focus
-14.2 @ 101.50 on stage1
bryfsvt is offline
Old 05-16-2007, 03:27 PM   #4
CatMostFeared
FocusXtreme
Fan#: 20987
you would say there is no gain in a FR2 cam or its just a 6 - 10 hp more so its not worth the money.
2000 Turbo ZX3
Old 05-16-2007, 03:42 PM   #5
CatMostFeared
FocusXtreme
Fan#: 20987
so lobe lift is the height of the eccentric rise over the radius of the base circle. In this case, the rise is 0.340 inch. This lift is generated over 141 degrees of cam-lobe duration. Since the cam spins at half crankshaft speed, we would double this duration to come up with an advertised duration of 282 degrees.
I'm guessing on the intake side you would want a wide duration and alot of lift
to get as much air into the motr as you can.
On the intake side you would want the the lift to be desend and duration to be short to keep as much pressure on the turbo without have any suck back.
2000 Turbo ZX3
Old 05-16-2007, 04:10 PM   #6
CatMostFeared
FocusXtreme
Fan#: 20987
some more basic info
CAM LIFT:
This is the maximum distance that the cam pushes the follower when the valve is open. This is different from valve lift. See Gross Valve Lift.
DURATION:
The lenth of time that the valve is held off the seat by the cam. This is measured by the degrees that the crankshaft rotates. More degrees of duration will make the engine operate in a higher rpm range.
DURATION AT .050":
The distance measured in degrees of crankshaft rotation from when the valve is open .050" far until it is .050" from closing.
DEGREEING YOUR CAMSHAFT:
Degreeing In Your Camshaft means synchronizing the camshaft's position with the crankshaft. A few degrees of misalignment can affect the engine's operation dramatically.
OVERLAP:
A situation where both the intake and exhaust valves are open at the same time when the piston is at top dead center on the exhaust stroke. The greater the seat duration is on the intake and exhaust lobes, the greater the overlap will be in degrees.
I found this info here http://www.aperaceparts.com/tech/camterminology.html
2000 Turbo ZX3
Old 05-16-2007, 05:57 PM   #7
FOCUS ZTS
FOCUS ZTS's Avatar
Fan#: 5840
What I Drive: Burned 300hp Turboed black 00 ZTS
FF Reputation: 6 FOCUS ZTS Good Standing Member
Buy-Sell-Trade Rating: (4)
I have crower turbo grind cams and they suck balls in low RPMs and kick ass in high rpms.
FOCUS ZTS is offline
Old 05-16-2007, 06:21 PM   #8
CatMostFeared
FocusXtreme
Fan#: 20987
Crower Stage 2
Forced induction special.
Designed specifically for turbo or supercharged applications.
Requires spring kit.
RPM range: 1500-up
276 Lobe 276
252 Valve 252 228 Lobe 228
222 Valve 222 .393 / .393
2000 Turbo ZX3
Old 05-16-2007, 07:00 PM   #9
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I'm going to stick to stock... they make good low power and great high end.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 05-16-2007, 07:07 PM   #10
IslandFocus
Fan#: 22161
What I Drive: 2000 Imperial Blue Focus ZX3
FF Reputation: 3 IslandFocus Good Standing Member
I'm really interested to see how Ray's FI cams turn out, especially on a supercharger setup.
IslandFocus is offline
Similar Threads
3x forced induction? fokuzx3 ZETEC Performance (2000-2004) 41 12-30-2004 11:32 PM
How many forced Induction Zetec's zx2s/r red General Forced Induction 38 12-18-2004 09:24 PM
Hood-scoop tied to Intake = Forced induction (sorta)??? jdecar1 DURATEC Performance (2003-2007) 18 12-16-2004 12:16 PM
How many forced Induction Zetec's zx2s/r red Ford Focus & General Car Chat 5 12-13-2004 05:40 AM
