ABS limiting at the track/AX? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 05-13-2007, 11:09 PM   #1
eventerke
eventerke's Avatar
Fan#: 41299
What I Drive: 2002 Pitch Black SVT
FF Reputation: 3 eventerke Good Standing Member
Buy-Sell-Trade Rating: (14)
Had a great day at the NASA AX today - without going into a long drawn-out story (yet ), how many of you find the ABS kicking in when you're trying to brake at the limit and screwing you up?
I'm starting to get a good feel for using the weight transfer in heavy braking to get the back end of the car rotating, but I'm finding that at the absolute limit the ABS kicks in and destroys the balance I'm trying to use.
WD40 mentioned pulling the ABS fuse puts the braking system balance in a 50/50 limp mode, and is a *bad* idea.
Do most of you just deal with this? Is the ABS really telling me the truth on the braking limit?
eventerke is offline
Old 05-14-2007, 12:00 AM   #2
tua03332
tua03332's Avatar
Fan#: 37555
What I Drive: 2000 Silver Sedan
FF Reputation: 1 tua03332 Good Standing Member
i ended up upgraded my front discs and then pulling the one fuse and found that the biase is mostly even but does favor locking up the back. Play around with it and use which ever feels better to you
34 STS
Funded By: My Back Pocket
tua03332 is offline
Old 05-14-2007, 12:30 PM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
ABS? What's that?
If its kicking in, I would assume you just exceeded threshold braking.
Egz is offline
Old 05-14-2007, 12:44 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Exactly...you've found the limit.
What tires are you running??
DON'T pull that fuse (46) and expect to stay on track. (or anywhere near on track)
I tried that a month ago at a threshold braking excercise during our test and tune.
While I got out of the hole like a bullet (no TC),
the instant I hit the brakes the car turned 90° sideways since the rears locked up immediately.
Again, I stress...never ever try this on a road course or autocross,
and expect your car not to sustain massive amounts of damage as you leave the course.
The ABS is nothing short of phenomenal on the SVT, especially with the given large rotors.
I'll bet your tires are the limiting factor at the moment, which is why I asked what you were running.
WD40 is offline
Old 05-14-2007, 01:35 PM   #5
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
What I Drive: 03 SVT ZX5
Points 19,067, Level 87
Points: 19,067, Level: 87 Points: 19,067, Level: 87 Points: 19,067, Level: 87
Level Up 44% Completed
FF Reputation: 97 JRODSVT Excellent Standing Member
Buy-Sell-Trade Rating: (6)
neither have I but then again i probably don't push my car as hard as others do.
J-RAWK!!!
FocusFests best of sound 2008
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
Old 05-14-2007, 02:03 PM   #6
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Concur. You found the limit. Tires are also a BIG contributor.
That said. Threshold braking is an art.
Your car demonstrates is highest braking ability right at the point of lock-up or just before the ABS kicks activates.
I am not saying that you do, but most people brake with the ball of their foot. As a result, they are using about 7X the pressure necessary to effectively slow the car.
Try using your toes. They are just as, if not more sensitive, than your finger tips (step on a sharp rock and you jump - put your hand on a sharp rock and you go "OW!"). Using your toes will allow you to be more progressive with your braking and likely not upset the car as much.
A lot of people "heel and toe" using thier toes. Unless you have a lot of time to practice, it takes a while to master. I personally have never been able to get it right.
As for the ABS fuse. WD40 is right. The SVT ABS system is phenomenal. You'll create more problems for yourself by disabling it. Not only from a systems standpoint, but also one of conditioning. Your body (muscle memory) is trained to react when the ABS kicks in. Remove the ABS, not only do you flat spot tires, but your reaction time is slowed as you process how to proceed.
The toes knows.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 05-14-2007, 02:06 PM   #7
eventerke
eventerke's Avatar
Fan#: 41299
OK - thanks for the replies!
I'm running crappy, greasy (when they get hot) Falken Ziex's. They were my "learning set" and now I feel I'm ready to step up to a set of Azenis.
Really helped to learn what it feels like to slide the car around a bit, at least !
I'm hoping to kill them good and dead this Sunday, then I'll *have* to get a new set. They're holding a raffle (AX is a benefit for the JimmyV foundation), and one of the prizes is $500 for tires at Discount Tire - you can guess what I'm hoping for!
Old 05-14-2007, 02:08 PM   #8
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
Can't go wrong with a $500 credit toward tires.
Good luck!
WeeAsp is offline
Old 05-14-2007, 02:34 PM   #9
SpeedOften
SpeedOften's Avatar
Fan#: 2139
What I Drive: E90 335i, 2002 E53 X5 4.4i
FF Reputation: 28 SpeedOften Great Standing Member
If you want to disable TC.. get Tom's tune...
and +2865983698 to not pulling the TC/abs fuse... I tried doing once as well and the rear does become quite happy - almost kicked a few cones b/c of it...
SpeedOften is offline
Old 05-14-2007, 06:32 PM   #10
tua03332
tua03332's Avatar
Fan#: 37555
pulling the fuse as you all noted creates a problem for the less seasoned driver, but for someone who has raced for a while now especially somthing like an MR2, having the rear end "happy" can actually be a benefit if you know how to use it to your advantage and still eliminating the problem with traction control. Since you are switching tires very soon, i recommend on keeping the fuse in and making sure you are 100% comfortable with the car before you try pulling the fuse. It only helps me have more fun around course, not neccessarrily faster since i MAY have only found like .5secs on the leader
34 STS
tua03332 is offline
Similar Threads
ABS Question...basic kwms General Technical Chat 3 02-07-2008 07:23 AM
ABS Light on - No ABS though mikkopel General Technical Chat 9 10-14-2007 12:35 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
ABS Problem CalinC General Technical Chat 0 12-06-2006 04:35 AM
add ABS on a non-ABS ZX3 Timmeh! General Technical Chat 2 09-12-2005 08:30 PM
