Contour SVT Swap! Proj. Log! - Page 18 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 06-11-2007, 10:06 PM   #171
cfol77
cfol77's Avatar
Fan#: 31668
What I Drive: '00 non-sangria red, ZTS
FF Reputation: 2 cfol77 Good Standing Member
Question
[quote=ryancsvt;1622577]...and I have a slight leak from my rear valve cover thats causing a vacume leak. If that wasnt the case and I hooked I would be in the 14's easy.
quote]
I have said leak, and I want max vac for mpg. What does it take to fix it properly...and what about cheaply & improperly?
(Insert clever remark of choice here)
cfol77 is offline
Old 06-12-2007, 10:47 AM   #172
ryancsvt
ryancsvt's Avatar
Fan#: 12074
What I Drive: 1998 Black SVT Contour #3722
FF Reputation: 1 ryancsvt Good Standing Member
Ok sorry I was wrong its 3,080 pounds curb weight bone stock, thats 380 pounds more than the focus.
Yeah there is NO room in the engine bay, even for the 1 turbo you have to relocate the battery to the trunk, move the fuse box to the front corner behind the headlight and its still a tight squeeze. Only way to ever do a tt would be a sts exhaust turbo type setup. And its even tighter in the focus.
Ryan-1998 Black SVT Contour #3722-172whp~sold~
2000 Silver SVT Contour #1126 3l Turbo-322whp/350tq~PASSTIME CSVT~SOLD~
2005 White Buick Rainier CXL~The new dd~
myspace.com/ryany1976
ryancsvt is offline
Old 06-12-2007, 03:33 PM   #173
ryancsvt
ryancsvt's Avatar
Fan#: 12074
Dont cheaply fix anything cfol77, either do it right or dont do it at all. Remove the valve covers and clean them and get new OEM gaskets.
iantm-I must disagree contour.org is great for info and thats about it. Not good at all for posting cause no matter what you post, if you arent from the northeast and have 10k posts than you will get flamed, not my idea of a good forum. www.fordcontour.org is a much much better forum. I got the 3080 from 1-800-ford-svt themselves for a bone stock 98 csvt. Mine is alot lighter now but thats stock curb weight.
ryancsvt is offline
Old 06-12-2007, 03:47 PM   #174
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
A standard 2.5l swap is a nice setup; it has a nice punch, and a little more grunt than a 2.3l Duratec. Drives really smooth, with no hesitation. But it's not all that powerful. I'd suppose the 3.0l would be a bit quicker.
The tricky thing is getting the suspension dialed in correctly.
Egz is offline
Old 06-12-2007, 05:05 PM   #175
ryancsvt
ryancsvt's Avatar
Fan#: 12074
Yes the 3l on average gains about 30-40 hp and has alot more torque and high end power. Now if you do the msds headers,and y pipe with the 3l then WOW. And yeah the suspension is going to have to be very tight to make you hook in such a light car, I have a problem hooking and I am in a heavier car.
ryancsvt is offline
Old 06-12-2007, 05:27 PM   #176
iantm
iantm's Avatar
Fan#: 4167
What I Drive: 2007 Pitch Black ZX3 SE MTX
FF Reputation: 3 iantm Good Standing Member
Okay, my bad about contour.org. My experiences with it are a bit dated - i.e. the last time I was around was in early 04 when I moved on to the focus. Chances are that most of the good folks moved on to other cars and forums and the site suffered. Pity.
It really was the duratec v6/mtx-75 combo that made the Contour a rewarding drive. The zetec powered Contours were terrible with the automatic, less so (but not great in any sense of the word) with the five speed. As for v6 automatic contours - I don't know - never driven one (anyone who truly appreciated the contour got the v6/mtx-75 combo), though sadly they are all I ever see when I peruse ebay or local used car listings.
If I ever came across a cheap (sub $1k) Contour with the v6 and mtx-75 - I'd do everything possible to talk my wife into letting me buy it - it's the only american car I'd buy to fix up and tweak around with.
- Iantm
07 ZX3 SE MTX - enjoying every minute with it
Cannondale M700
MacBook Pro 15"
iantm is offline
Old 06-13-2007, 10:15 AM   #177
ryancsvt
ryancsvt's Avatar
Fan#: 12074
Yes I agree, but at the same time I hope this guy will do it. The diff is the weakest link in the mtx-75 along with the shift tower. If you are planning on driving the a contour hard or even moderatly, or EVER take it to the track I HIGHLY sudgest getting a torsen atb. I raced mine at the track numerous numerous times before I got my tranny built and was told I was VERY lucky In didnt blow my diff from launching.
The shift tower is a problem cause the tower bolt sheers off. Terry Haines at HMS does the full HMS tranny's with the keyed tower bolt which is a must have. I will get mine done when My car goes under the knife.
ryancsvt is offline
Old 06-13-2007, 12:26 PM   #178
turbovation
all grown up
turbovation's Avatar
Fan#: 29834
What I Drive: 2006 Toyota tacoma work truck
Points 11,191, Level 69
Points: 11,191, Level: 69 Points: 11,191, Level: 69 Points: 11,191, Level: 69
Level Up 86% Completed
FF Reputation: 7 turbovation Good Standing Member
How much could it cost for a keyed tower bolt?
this is bob. bob has bitch tits.
turbovation is offline
Old 06-13-2007, 02:48 PM   #179
ryancsvt
ryancsvt's Avatar
Fan#: 12074
Well its not just the tower bolt, you upgrade to the svtf shift tower and have it keyed and I think its around $225.00 and WELL worth it.
ryancsvt is offline
Old 06-20-2007, 03:59 PM   #180
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,179, Level 67
Points: 10,179, Level: 67 Points: 10,179, Level: 67 Points: 10,179, Level: 67
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
so how is this going? i was talking about this swap with another friend of mine in this focus community and it would make for an easy extra chunk of ponies in a sneaky build i have in mind for my focus in the next 2-5 yrs. my biggest worry is the wiring, but if there is a how-to you guys can expect a v6 twin charged awd focus in the next few years emerging from my garage. ::sneaky::
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Tags
duratec deb , effin awesome build , she lives! , svtc swap
Similar Threads
HOW-TO: SVT IMRC DSI Intake Manifold Upgrade FOR ZETEC!!!! focituner ZETEC Performance (2000-2004) 131 05-31-2012 07:56 AM
SVT contour kill MISVTfocus General Racing Chat 9 05-02-2005 11:15 PM
zx3 vs svt contour??? imprtslyr0223 Ford Focus & General Car Chat 9 02-25-2005 04:59 PM
Whats the value of SVT Focus parts to do a swap? Darth Focus ZETEC Performance (2000-2004) 9 01-27-2005 12:10 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
