Petboys says its my alternator, ford says its my battery...... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-11-2007, 10:52 AM   #1
snowdazze
Fan#: 44382
What I Drive: 2005, Red Rocket ST Focus
FF Reputation: 1 snowdazze Good Standing Member
ok so i have problems with my car dying... i take it to petboys to get the alternator checked they said its that was the problem. than i take it to ford since petboys didnt have one. Ford services it and tells me its my battery. i get a new battery yesterday and i almost getting to work when my abs and TC turn off, also my CD player turnes off. its dead agian. when i put the new battery in the battery light turned on at idle and went away after i was in like 2nd gear. so now i dont have the power i use to have.. . Im so upset. any ideas?
Almost Adventures as my ride_stuck in the daze
ST CREW#64.......HAllelujah Holla Backkk....
snowdazze is offline
Old 05-11-2007, 11:17 AM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Sounds to me like Pep Boys was right.
penguin is offline
Old 05-11-2007, 11:18 AM   #3
Bochet
Fan#: 39091
What I Drive: 2001 Impreza 2.5RS
FF Reputation: 6 Bochet Good Standing Member
ford screwed you into buying a new battery, see if you can return it
Bochet is offline
Old 05-11-2007, 11:22 AM   #4
Impaled
Raise the stakes
Impaled's Avatar
Fan#: 46117
What I Drive: 2001 ZX3, 1998 ZX2
FF Reputation: 4 Impaled Good Standing Member
check all the wiring and the vr plug before you go replacing all of that, they have a tendancy to come loose and are crap to begin with.
Impaled is offline
Old 05-11-2007, 11:38 AM   #5
snowdazze
Fan#: 44382
how should i go about checking that VR plug. and i got the battery from autozone since it was a little bit less in price.
Old 05-11-2007, 11:44 AM   #6
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,931, Level 76
Points: 13,931, Level: 76 Points: 13,931, Level: 76 Points: 13,931, Level: 76
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
if you gave them your old battery for the core i would doubt you would get it back, it might not be your alternator either you could have a short somewhere that is putting a drain on the battery and its not taking a change, maybe thats what the vr plug is for im not sure what that is but the only way to find out is to test it
SkyPilot is online now
Old 05-11-2007, 12:00 PM   #7
cayres
cayres's Avatar
Fan#: 35184
What I Drive: 03 Comp Orange EAP SVT, 06 ZX3 SES
FF Reputation: 8 cayres Good Standing Member
do what impaled said my fried with a zx3 replaced alternator and battery..still had problems then we found it to be the wiring harness that goes into the alternator was bad..soo 300 bucks later a 15 dollar part solved the problem.
cayres is offline
Old 05-11-2007, 12:03 PM   #8
snowdazze
Fan#: 44382
big help...how is the VR tested to see if its bad or not?
Old 05-11-2007, 12:14 PM   #9
Impaled
Raise the stakes
Impaled's Avatar
Fan#: 46117
It's the plug oing into your alternater with the 3 wires, see if it looks like it's in bad shape and make sure it's connected correctly, also spray all your grounds and contacts with an anti corrosive parts cleaner, you can also undo your grounds and sand the contacts.
The VR it's self is in your alternator but the above mentioned plug has problems alot of times.
Impaled is offline
Old 05-11-2007, 06:57 PM   #10
02ZX3inPA
Wrenchin' aussie pos
02ZX3inPA's Avatar
Fan#: 45346
What I Drive: The Blue Devil
FF Reputation: 40 02ZX3inPA Great Standing Member
Quick VR plug test...
Start the car, reach back to the plug (be careful to avoid moving parts) and wiggle those wires while someone watches your battery light. If the battery light situation changes, the plug is toast.
ZC #154..Focus Nation..
02ZX3inPA is offline
Similar Threads
Please HELP - Battery light VR6guy General Technical Chat 11 02-06-2007 08:56 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
2nd battery, asking for helpful advice sc0tty8 Car Audio, SYNC, MyFord Touch & Electronics 0 10-22-2005 10:17 AM
battery issues chad_p71 General Technical Chat 3 05-06-2005 11:10 AM
battery light and ground problems natdog General Technical Chat 0 01-19-2005 11:36 AM
