My A/C fuse keeps blowing! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2007, 08:33 PM   #1
SVTORNG
Fan#: 46851
What I Drive: 2004, Competition Orange, SVT
FF Reputation: 1 SVTORNG Good Standing Member
Question My A/C fuse keeps blowing!
Hey all,
I'm new to the site and I'm hoping I can pick your brains.
The 10amp fuse to my A/C keeps blowing! This is the fuse located in the fuse panel under the hood. All the other A/C fuses are fine.
What's the deal? I've never had this issue before. One day the A/C is working like a champ then the fuse blows. Why?
I've replaced the fuse twice now and the A/C will work until I turn off the engine. Once I fire it up again and press the A/C button there's no cold air and the fuse is blown. I truly hope there isn't a serious electrical issue.
Thanks for your help and suggestions!
Jared
SVTORNG is offline
Old 05-08-2007, 09:47 PM   #2
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
bad ground????
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Old 05-08-2007, 09:59 PM   #3
SVTORNG
Fan#: 46851
Originally Posted by zx32nr View Post
bad ground????
hhmmmmm? I can do some checking. Perhaps a body ground is lose? Battery Ground? My SVT Focus is bone stock and I've never put a wrench to it...yet.
SVTORNG is offline
Old 05-09-2007, 12:28 PM   #4
focusfreak03
focusfreak03's Avatar
Fan#: 20385
What I Drive: OLD:03 ZX3;NEW: SRT-4
FF Reputation: 50 focusfreak03 Excellent Standing Member
yeah, it sounds like you have some current leakage and your a/c unit is pulling more than the fuse can handle. check the whole wire, not just the connections, you could have a skinned or burnt wire that is causing the current leak
Moved on to bigger and better things. the ride: SRT4 with 230 whp stock!!! i loved the focus but this one is just a better car for what i want. not so stock anymore. pushing 307whp/301wtq @ 19 psi.
Midwest Crew #14
focusfreak03 is offline
Old 05-15-2007, 04:43 PM   #5
SVTORNG
Fan#: 46851
It's fixed! I traced the A/C wires from the A/C compressor and about 5 inches into the loom the wires had kinked. This caused the insulation on both wires to wear. So, the wires were touching causing a short. Problem found and solved! So, check your A/C connections/wires because this looks like a factory made weak spot.
Thanks for all your help!
2004 SVT Focus w/ Euro Package
Competition Orange
Moss Beach, CA
Mods - Focus Sport Cold-Air Intake
SVTORNG is offline
Similar Threads
Keep blowing Fuse 32 jhowton General Technical Chat 11 11-29-2007 02:00 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Electric Issues (Fuse 32, 44) Happenedtoyou General Technical Chat 3 08-20-2005 01:24 AM
Arghh! keep blowing fuse # 50! EuroZX3 Car Audio, SYNC, MyFord Touch & Electronics 7 11-16-2004 02:05 PM
Power locks..fuse keeps blowing solkp General Technical Chat 8 07-21-2004 12:20 PM
