JRSC parts list and manual - where? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-02-2007, 11:40 PM   #1
ButtonPuncher
Fan#: 18887
What I Drive: '96 Tan Contour GL
FF Reputation: 1 ButtonPuncher Good Standing Member
Buy-Sell-Trade Rating: (6)
Hi,
I'm looking for a parts list and installation manual for a regular JRSC (not the SVT). I've searched through the forums and all of the links are dead now that Moss Motors has taken stuff over.
Thanks,
Ben
---'96 Contour GL * Zetec MTX * Tan on Black steelies---
2006 Mazda6s * 3.0L Duratec * 6-speed ATX * Lapis Blue
ButtonPuncher is offline
Old 05-02-2007, 11:56 PM   #2
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
You can try and email Oscar Jackson over on Focal Jet and see if he can send you a list, he was very repsonsive when I had some issues with mine. BTW, your intercooler M62 setup...got any pics of the progress? The one downfall of the JRSC is that it has no intercooler so heaving all that hot air in is never good.
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 05-03-2007, 12:13 AM   #3
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
If you call moss they still have that info, and can send it too you. There is a PDF of the instructions out there as well.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 05-03-2007, 11:27 AM   #4
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,994, Level 91
Points: 20,994, Level: 91 Points: 20,994, Level: 91 Points: 20,994, Level: 91
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 9%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
i have the instructions too. the book mark for that is saved on my computer at the house i will have to get that to you when i get home.
Here is the list of parts with the part numbers .
Item No. Description Quantity
995-000 SUPERCHARGER SYSTEM 1.00
988-042 S/C SUPPORT BRACKET KIT 3 1.00
051-081 WASHER, FLAT, M10 2.00
051-084 BOLT, HEX, M10-1.50 X 50 G8.8 2.00
051-186 NUT,FLANGED,8X1.25,12AF 1.00
051-505 BOLT FLANGED M8X25X1.25 12 AF 1.00
051-506 BOLT, HEX FLANGE M8-1.25 X 30 1.00
051-657 BRACKET, S/C SUPPORT STRAP 1.00
051-658 BRACKET, S/C SUPPORT LOWER 1.00
772-316 ALUMINUM, 2.7X4.7X1.125 1.00
772-217 BLACK, ANODIZE 0.56
988-105 ALT/BELT DRIVE BRACKET - FOCUS 1.00
051-081 WASHER, FLAT, M10 1.00
051-505 BOLT, HEX FLANGE M8-1.25 X 25 2.00
051-627 PULLEY, 2.0IN IDLER, PLASTIC 1.00
051-762 BOLT,HEX FLANGE,M10 X1.25 X 30 1.00
052-170 BRACKET, ALTERNATOR - GEN. 2 1.00
988-211 INTAKE MANIFOLD ASSY - FOCUS 1.00
051-098 BYPASS VALVE 1.00
051-121 SCREW, SHCS, M6 X 1.0 X 16 4.00
051-142 HOSE BARB, 5/32 VACUUM 2.00
051-144 HOSE, SILICONE, 1.5 ID X 1.25 1.00
051-189 CLAMP, HOSE, MINI, 2INCH 2.00
051-364 PLUG, PIPE, AH, 1/4 NPT 1.00
051-503 BOLT M8 X 0.75 X 10 WI PLUG 1.00
051-529 GASKET, JR BYPASS-MANIFOLD 1.00
051-553 CLIP RETAINING 7/32 VACUUM 1.00
051-660 INTAKE MANIFOLD - FOCUS 1.00
051-794 GASKET, INTAKE MANIFOLD 1.00
051-796 HOSE, VACUUM, 7/32 X 14 IN 1.00
051-551 HOSE, VACUUM, 7/32 ID, BULK 14.00
051-797 HOSE BARB,1/4NPT X 1/2 X 45DEG 1.00
988-307 SUPERCHARGER ASSEMBLY - FOCUS 1.00
051-122 STUD, M8 X 1.25 X 40 1.00
051-142 HOSE BARB, 5/32 VACUUM 1.00
051-207 AHCS M8X1.25X25 2.00
051-528 GASKET,GEN3 S/C-TB ADAPTOR 1.00
051-656 S/C GEN3 M45 CW 3.0-6R 1.00
051-662 TB ADAPTER FOCUS 1.00
051-680 HOSE BARB, 3/8 VACUUM 1.00
051-783 AHCS, M8 X 1.25 X 55 1.00
051-938 NUT, FLANGE, M8X1.25, 10MM A/F 1.00
988-423 HOSE BAG 1.00
051-134 VACUUM TEE 3/8 1.00
051-235 CLAMP, HOSE, SAE NO. 44 2.00
051-259 HOSE, VACUUM, 5/32 IN., BULK 35.00
051-389 TEE, VACUUM, 3/16 1.00
051-513 CLAMP, HOSE, NO 8 2.00
051-665 HOSE, PCV, 1/2IN BULK 2.00
051-669 HOSE, FLEX LOPRENE 1.00
051-758 HOSE, SILICONE, 7MM ID, BLACK 32.00
052-201 TEE, VACUUM, 3/8 X 1/4 X 3/8 1.00
052-211 HOSE, VACUUM, 1/4, BULK 6.00
770-268 LOOM SLIT, CONVOLUDED, 1/2 DIA 36.00
051-320 ELBOW,VACUUM, 1/8X11/64X90 DEG 1.00
051-372 SLIT LOOM.1/4 INCH 12.00
163-655 HOSE, VACUUM, BLACK PLASTIC 3.00
988-703 GASKETS - LOCTITE - ZIP TIES 1.00
051-016 CABLE TIE 8.00
220-136 REMOVABLE THREADLOCKER 1.00
051-525 GASKET, M45 S/C MANIFOLD 1.00
051-395 SPADE CON, MALE, 18-22 GA 1.00
051-387 SPADE CON, FEMALE, 22-18 GA 1.00
988-812 INSTRUCTIONS AND STICKERS 1.00
051-473 JR WARRANTY CARD 1.00
051-676 INSTRUCTIONS FOR FOCUS 1.00
052-010 STICKER, PREMIUM FUEL REQUIRED 1.00
052-282 CARB E.O. STICKER 1.00
988-913 HARDWARE BAG 1.00
051-004 BOLT,HEX FLANGE,M6 X 1.00 X 15 4.00
051-074 WASHER, FLAT, M8 4.00
051-075 WASHER, LOCK, M8 4.00
051-119 BOLT, HEX FLANGE M6-1.0 X 10 1.00
051-125 STUD, FULL THREAD 8 X 50 X1.25 9.00
051-127 BOLT, HEX FLANGE M8-1.25 X 20 1.00
051-135 BOLT, HEX FLANGE M8-1.25 X 40 1.00
051-186 NUT, HEX FLANGE M8-1.25 9.00
051-663 SCREW, SET, M8 X 1.25 X 50 2.00
051-677 STUD, M10 X 1.5 X 50 1.00
051-678 NUT, FLANGE, M10 X 1.5, 15 AF 1.00
051-714 BRACKET, SC - ALTERNATOR 1.00
051-717 SPACER, .33 ID X .63 OD X .33 1.00
770-137 ALUMINUM, ROD, 0.625 0.53
051-718 SPACER, .33 ID X .63 OD X 1.80 1.00
770-137 ALUMINUM, ROD, 0.625 2.03
051-754 ALLEN WRENCH, 4MM 1.00
051-761 BOLT,HEX, M8 X 1.25 X 90 4.00
051-788 BOLT, HEX FLANGE M10-1.5 X 40 2.00
052-911 BELT, 6PK2655 1.00
988-915 HARDWARE BAG 1.00
051-003 BOLT, HEX FLANGE,M6 X 1.0 X 12 4.00
051-728 BRACKET, MOUNTING, P/S 1.00
051-729 BRACKET, ADAPTER, P. STEERING 1.00
051-787 NUT, FLANGE, M6 X 1.0, 10 AF 4.00
051-789 SCREW, TAPPING, M6.3-1.81 X 20 1.00
051-696 BADGE, JACKSON RACING 2.00
052-404 DFMM - FOCUS ZX3 1.00
052-405 FUEL CONTROLLER ZX3 1.00
052-071 LICENSE PLATE FRAME, JR 1.00
051-381 BOX, 30 X 15 X 15 350LB TEST 1.00
051-889 BOX, 15 X 15 X 5 1.00
051-942 BOX, 24 X 14 X 14, 275LB TEST 1.00
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 05-03-2007, 01:29 PM   #5
dannyc
Fan#: 36734
What I Drive: 00 state blue mondeo 2ltr zetec-s
FF Reputation: 1 dannyc Good Standing Member
you have a pt on CEG and a reply on the jet
Blown by Jackson Racing
dannyc is offline
Old 05-03-2007, 02:01 PM   #6
ButtonPuncher
Fan#: 18887
Thanks everybody! :)
I've had a change of plans. The intercooled JRSC isn't going on my '96 ATX. It was totalled in a car accident in November. It is now going on a '00 Contour SE that already had a JRSC M45 supercharger. The previous owner overspun the blower and the motor ate the epoxy coating off of the JRSC's rotors. Not good.
I'm working on dropping a '00 Focus Zetec in as a replacement. I still need to get down to Massive to have them modify my SVT JRSC manifold. I need to get the Contour engine swap done first. Hopefully I'll get down to Massive sometime this month.
Yeah, even at 7psi, your intake temps can hit 200-240 degrees depending on ambient air temp. I want to run 10psi and I don't want to do water/meth injection. I'm going to get a nice water/air intercooler to hook up to the SVT JRSC. Massive should be able to do the modification to any JRSC intake manifold (M45 or M62).
Later,
BP
Similar Threads
Complete Acronym/Abbreviaton and Forum Terminology List WD40 Member FAQ's & How-To Information Archive 0 02-10-2006 02:45 PM
Parts List Comment Please Iggmasta General Forced Induction 2 01-30-2006 10:35 PM
Parts list for the Powerworks FocusForce Manual? vagabondsoul General Forced Induction 6 01-14-2006 04:07 PM
New top 10 list, check out number 2 sidney61199 Ford Focus & General Car Chat 15 01-06-2005 10:33 PM
Rank these Cars.... shellshock Ford Focus & General Car Chat 30 01-02-2004 07:18 PM
