Car stalls when making a turn... - Page 2 - Focus Fanatics
Old 05-02-2007, 10:15 AM   #11
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 267 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
yes, the inertia switch can be replaced.. and I have no idea why the mechanics wouldn't have done that already unless that is not the electrical system that is being affected.
It's so much harder to figure out what is wrong- especially with things that only happen on winter solstice, or happen if I drive down the street, and take a left instead of a right to get to work, or something that only happens every 3rd Tuesday of the month if it falls on an even number.
You can go out there and start yanking on the wires that go to the coil and the voltage regulator in the alternator. Those are fairly common for problems with wires just coming loose over time. The coil wire would kill the engine, the alternator wire would make the battery light come on and go off- but not kill the engine until you ran out of power.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 05-04-2007, 12:21 PM   #12
hoppy82
Fan#: 46693
What I Drive: V reg 1.8 Zetec
FF Reputation: 1 hoppy82 Good Standing Member
My focus - v-reg 1.8 zetec was stalling when I was putting the clutch down when turning corners etc. My friend had a look and said that the 'tick-over' for the revs wasn't high enough and therefore when the clutch was going down the engine would cut out. He did something inside the engine to raise the idling revs slightly and it hasn't happened since. Just a thought :)
hoppy82 is offline
Old 05-15-2007, 09:20 PM   #13
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing MemberSquillyB Excellent Standing Member
I have had a similar problem with my current vehicle. I took my focus to the dealership I bought it at, to the service center and told them I wanted to personally speak to the guy who would be working on my car. An hour later they brought me Alan, nice guy, little confussed to be up in the front with a customer but oh well. I described the problem and he said "fuel pump" no problem. I said "I got a full tank and the receipt from ten minutes before I got here to prove it, lets go for a ride." We hit the industrial park behind the dealership where I showed Alan why I buy new tires every other month. I also stalled my "automatic" focus 4 times in fifteen minutes of smoke and g forces. Back at the garage, they replaced my... you guessed it, inertia switch. Has it helped? Stalled yesterday making a left while entering a freeway at about 50-55 mph. And that has been the only time.
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 05-31-2007, 08:21 PM   #14
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
^^^^^^^^^^^^^ Little Update for ya!!^^^^^^^^^^^^^^
My car went back to ford 2 days ago for the same thing as before, and we have a new plan this time. Replaced fuel pump and fuel pump module due to faulty wiring harness between module and pump.
6s4z-9h307-a = sensor amd pump $166.23
4s4z-9d372-aa = module $71.70
tech #112223/360 $240.00
all covered under warranty, no recall but $50.00 deductable isn't that bad. Hope this new info helps. the work was done @ Bell Ford in AZ.
MECP 1ST CLASS
SquillyB is offline
Old 06-01-2007, 12:27 AM   #15
DFv2
WWTPD?
DFv2's Avatar
Fan#: 42684
What I Drive: 2008 Lightning Red STi
FF Reputation: 31 DFv2 Great Standing Member
Buy-Sell-Trade Rating: (12)
My 03 does this every few weeks, along with MANY other svtf's. Its just a commonly known issue that really doesnt have a resolution. You can catch it if you feel the RPM's dip. I dont know your exact issue, but it sounds an aweful lot like the common RPM dip - stall issue.
DFv2 is offline
Old 06-01-2007, 08:41 AM   #16
LenMinNJ
Fan#: 37138
What I Drive: 2004 SVT ZX5 EAP
FF Reputation: 1 LenMinNJ Good Standing Member
Check for this problem:
There are three wires going into a plug on the distributor. We had one that had been crimped badly into its connector and it started going intermittent. When it opened, the car stalled. Eventually, when I pulled lightly on the wires the connection broke entirely.
Best of luck!
Len M.
LenMinNJ is offline
Old 08-27-2007, 10:06 PM   #17
LenMinNJ
Fan#: 37138
Another possibility: in my old 2000 ZTS the factory assembly techs nicked a wire when stripping it for insertion into the connector in the distributor. Eventually, the wire fatigued from flexing and broke *inside* the insulation (completely invisible) at the entry to the connector. When making turns at certain rates, the engine would shift on its mounts and the wire would electrically open inside the insulation. The car would sputter and sometimes stop dead.
LenMinNJ is offline
Old 08-27-2007, 10:22 PM   #18
higgszx3se
higgszx3se's Avatar
Fan#: 48193
What I Drive: 2007, Pitch Black, Focus ZX3 SE
FF Reputation: 1 higgszx3se Good Standing Member
my bros svt had the fuel pump and ignition switch changed at the dealer
2007 Manual Black Ford Focus SE, Apexi N1 after cat custom, Lightweight 15'' American Racing Wheels. Performance Hankook rear tires and Low profile Futura front tires. AEM custom Short Ram Intake with suction valve. MOMO racing petals and shifter.
higgszx3se is offline
Similar Threads
You're doing it wrong! AKA Rice Reports(Post autofails here!) mattsstang87 Ford Focus & General Car Chat 12184 Yesterday 09:12 AM
Worst car owner EVER! azflyboy Ford Focus & General Car Chat 16 05-21-2005 09:03 AM
April 2005 U.S. Auto Sales Scorecard Kneel Ford Focus & General Car Chat 3 05-04-2005 03:56 PM
[:)][:)][:)][:)][:)][:)]Suspension FAQ's (Answered!)[:)][:)][:)][:)][:)][:)] Dr. Design Wheels & Tires - Sponsored By Tire Rack 7 09-23-2004 03:05 PM
Prospective Buyer: Basic Newb Questions Hamada Ford Focus & General Car Chat 14 12-01-2003 02:43 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
