Speedometer jumps/bounces and car trembles/shakes - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-02-2007, 11:29 PM   #11
Jeremyy
Fan#: 46580
What I Drive: 2001 Yellow ZX3
FF Reputation: 1 Jeremyy Good Standing Member
I have replaced the spark plug and wires, which has lifetime warranty.
Bosch Platinum 2 spark plugs and Duralast wires. Saved $200 than let mechanic do it.
Now the shaking problem of the car seems gone. We had P0304 error code which means #4 cylinder misfire. It did not go back to normal once we replaced it. But after we fasten/enforced both end of the wires, the problem seems gone so far. I suspect it is contact problem, and replacement of spark plug and wire might not be needed.
The speedometer still jumps, but not as often or bad. I suspect that misfire worsen the speedometer problem, although they seem unrelated.
Jeremyy is offline
Old 05-14-2007, 03:15 PM   #12
StupidZX3
Guest
Fan#:
Posts: n/a
I replaced the plugs and wires also, about a day after that, the car threw a CEL on and started to shake even worse.. Turns out the coil was cracked... Replaced it, and the car runs perfect now, no more jerking of the speedometer or bucking of the car.
Old 05-14-2007, 08:30 PM   #13
fastfocus00
fastfocus00's Avatar
Fan#: 16893
What I Drive: 2000 Autumn Orange ZX3 5-Speed
FF Reputation: 1 fastfocus00 Good Standing Member
i had the same problem. its prolly your speed sensor malfunctioning. my car did the same thing. have someone replace it and it should take care of it. your speedo and tach and trip run off the speed sensor which is part of the tranny so when your speedo jumps around it makes the car feel like its shaking and what not.
fastfocus00 is offline
Old 05-14-2007, 09:30 PM   #14
kndlz28
kndlz28's Avatar
Fan#: 17844
What I Drive: 2005 F150, 2000 ZX3, 2006.5 Optima
FF Reputation: 1 kndlz28 Good Standing Member
Mine did about the exact same thing. Here's my old thread.
http://www.focusfanatics.com/forum/s...ad.php?t=37379
And FWIW, it was the engine grounds. Good luck!
kndlz28 is offline
Old 05-14-2007, 10:08 PM   #15
bryfsvt
Fan#: 33542
FF Reputation: 7 bryfsvt Good Standing Member
x2... I bet its the Trans speed sensor
06-ST: Not your typical focus
-14.2 @ 101.50 on stage1
bryfsvt is offline
Old 12-04-2012, 01:31 AM   #16
rics94svtbird
Fan#: 95825
What I Drive: 2002 Red Focus SE 4door
FF Reputation: 2 rics94svtbird Good Standing Member
Problem solved
I think u might be having a problem with ur Mass Air Flow sensor aka MAF sensor my 94 tbird had the same problem but the only diff was that the rpm and the Speedo would jump I bought 2 cats new wires spark plugs and coil pack and all to find out that the maf was the problem wich was worth on 8 buckaroos at AutoZone vs 400 for the cats and stuff
rics94svtbird is offline
Similar Threads
The Black Box in your Car MrKing Ford Focus & General Car Chat 43 09-01-2006 03:14 PM
My 05 DreamMaster2007 Archive 35 12-18-2005 12:51 AM
Notice: My car wont start. MaximusZTS ZETEC Performance (2000-2004) 7 11-16-2005 07:19 PM
Mustang owner gets screwed over bad by AMP in AZ BIGBADWORM Ford Focus & General Car Chat 17 08-12-2004 02:25 PM
