Rear Wheel Bearing Replacement --> How-to - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2013, 04:27 PM   #81
razzledazzle
Fan#: 120438
What I Drive: Silver 2007 Hatchback
FF Reputation: 1 razzledazzle Good Standing Member
I purchased a 2007 Hatchback earlier this summer, and on a long road trip to Michigan's UP I started hearing the tell tale noise. I narrowed it down to the back driver side, and decided to replace both while I'm doing it, since I have access to a press at work.
My only question is after looking at the bearings I bought at napa, they don't look completely symmetric. Is there a right or wrong way to press them in, or does it not matter?
razzledazzle is offline
Old 11-03-2013, 05:07 PM   #82
mickeyaaaa
Fan#: 111009
What I Drive: 2006 Blood Red ZXW SES Wagon
FF Reputation: 1 mickeyaaaa Good Standing Member
fed up with rear wheel related problems.
Ok left rear bearing noise again, this is the 3rd or 4th one since buying the car in march....did everything right last time - torque specs & all...
suspect thehub & or spindle are possibly damaged due to difficult removal last go-around, they're all rusty anyways so i ordered:
-2 new hubs with bearings already pressed in
-2 new rear spindles.
after these go in if i have another rear bearing go i'm selling it and getting a Matrix...this is my 2nd focus wagon and have had nothing but rear bearing/tire wear/camber out of spec issues..
mickeyaaaa is offline
Old 11-03-2013, 06:44 PM   #83
SuperFlea
Illegal Alien
SuperFlea's Avatar
Fan#: 28261
What I Drive: One Of Teh Hottest Wagons on FF!
Points 20,402, Level 90
Points: 20,402, Level: 90 Points: 20,402, Level: 90 Points: 20,402, Level: 90
Level Up 11% Completed
FF Reputation: 44 SuperFlea Great Standing Member
Buy-Sell-Trade Rating: (46)
Sounds like you might have an alignment problem. How is you rear tire ware?
Also, what brand bearings are you getting. There's really nothing better the FORD parts. At one point, I had a rear bearing go out on me after a month of daily driving. Took it back to the parts store, bought OEM fords and never had an issue since. Only deal is that they're pricey. I can buy two cheaper brand bearings for under the price of just one ford bearing.
<--Jonathan-->
I'm back, Itchbes!
SuperFlea is offline
Old 11-03-2013, 07:15 PM   #84
mickeyaaaa
Fan#: 111009
I've only had it since march this year so too early to tell on tire wear. I could visibly see the camber was way off so i installed Moog shim plates early this summer...no wear on outside tire edges so far so it should be within spec (the camber only i mean)..
bearings: all except last time were high quality $50 from auto parts store - brand i believe. got them to honor the lifetime warranty and got one free. Last ones were cheaper off ebay.
I also notice a bit of a shake around 100KPH - that is why i thought maybe hub is damaged..
Old 11-03-2013, 07:20 PM   #85
SuperFlea
Illegal Alien
SuperFlea's Avatar
Fan#: 28261
Yes, unbalanced tires also cause the bearings to go bad from to much vibration. Look into the alignment, not for camber ware, look for tie ware.
<--Jonathan-->
I'm back, Itchbes!
Old 11-05-2013, 03:24 PM   #86
razzledazzle
Fan#: 120438
As I mentioned earlier, I don't want to install the bearings til I'm sure I've got it right. As the pictures show, the bearing doesn't look exactly symmetric, so is their a correct way and an incorrect way to install??
Old 11-06-2013, 03:26 AM   #87
SuperFlea
Illegal Alien
SuperFlea's Avatar
Fan#: 28261
Nope, no right or wrong way. The install either way/side.
<--Jonathan-->
I'm back, Itchbes!
Old 11-22-2013, 10:10 AM   #88
ApriliaRyan
Fan#: 123897
What I Drive: 2003 SVT ZX5
FF Reputation: 1 ApriliaRyan Good Standing Member
SUre Im late to the table but wanted to add you wont need to pull off the caliper bracket, the rotor will slide right out once you tip it. I just picked up an SVT and did my rear bearings using this write up.....awesome job with the pics, details, and tools needed, saved me a ton of time.
ApriliaRyan is offline
Old 12-10-2013, 12:53 PM   #89
mickeyaaaa
Fan#: 111009
ok its been just over a month, new hub, spindle & seal on the offending (shake) rear left, new bearing, new tires & balance...still needs an alignment with slight pull to the right but the bearing seems to be holding up so far....
REAR ABS SENSOR RINGS faulty - anyone got spares they wanna part with?
Old 05-14-2014, 03:56 PM   #90
omarfathel
Fan#: 163370
What I Drive: ford focus 2002 white
FF Reputation: 1 omarfathel Good Standing Member
ford focus 2002 rear wheel abs sensor problem
Hello every one , I see your replacment of front wheel, years ago and I would like to ask some questions
First I want to know if there is complete rear wheel set (I mean abs sensor and water seal carrier .... etc)
Any one can help me please
Thanks
omarfathel is offline
Similar Threads
spi=pos now its a wheel bearing FellowsDrake SPI Performance (2000-2004) 10 12-08-2006 02:36 AM
Wheel Bearing Problems AZIANGUY General Technical Chat 0 05-28-2004 01:59 AM
Bad real wheel bearing? focuszx3r General Technical Chat 7 05-27-2004 01:36 PM
Rear wheel bearings in 2000 FOCUS VITO Ford Focus & General Car Chat 6 04-03-2004 08:25 AM
Rear Wheel Disc? g0o53 ZETEC Performance (2000-2004) 11 09-13-2003 03:39 AM
