[How To] Painting your side view mirrow caps. - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > MK1 Focus
Old 04-20-2007, 04:38 PM   #1
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Painting your side view mirror caps
Preparation time needed: 30 minutes.
Working time needed: 2 hours.
Overall drying time needed: 24 hours.
Materials needed:
  • Primer
  • Paint
  • Clear coat
  • Rubbing alcohol
  • Cardboard
  • Sandpaper (I used primer sandpaper in this how-to)
Preparation:
Begin by removing the mirror caps gently. This process takes the longest time as you are working behind the mirror glass. Refer to the pictures to see where the tabs are.
After removing the caps, go inside and wash off the caps thoroughly, removing any dirt, grime, or anything that will ruin the integrity of the paint/primer. After cleaning with soap and water, use rubbing alcohol to prep the surface for priming. Use the sandpaper to roughen up the surface of the plastic for the primer to get properly spread across.
Painting:
After roughening up the surface of both caps, they are ready to be coated with primer. Find a nice outside spot and lay some cardboard down. Shake the can of primer thoroughly for about 2 minutes.
Begin spraying one light coat of primer on each cap, and let dry for 10 minutes or so.
Repeat with a few more layers of primer and let dry for 20 minutes after the last coat. Make sure the surface of each cap is covered completely with primer.
Go inside and wash your hands with soap and water.
After drying the final coat of primer, run the primer sandpaper over each surface again, roughening the primer to allow proper adhesion of the paint.
Run a light coat of paint over each cap, and let dry for 10 to 15 minutes. Be sure not to make heavy coats, otherwise you will be fighting drips and runs.
Continue with very light coats of paint on each cap, making sure not to put the paint on heavily. The end result should look something like mine.
Allow the paint to dry completely for about 30 to 60 minutes. Once dried, shake the can of clear coat for 2 minutes to prepare it for spraying.
Spray one light coat of clear coat on the surface of each cap. Remember to keep it very light as this coat is the base for the next few clear coats.
Once the first coat is set, allow it to dry for 10 to 15 minutes. After this drying period, return and spray 2 to 3 more coats of clear coat, which do not have to be as light as the first one. I gradually made them thicker as I went to my 4th coat, allowing the caps to appear very shiny.
Allow the caps to dry overnight. This will allow proper setting of the many coats you just sprayed on.
After the drying period, re-install the caps by simply pushing them back in place.
Algorhythm is offline
Old 04-20-2007, 04:46 PM   #2
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
This is a great how-to! Its a nice touch
Shame it doesnt have the same effect on a black car, but Im going to do mine anyway lol.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 04-20-2007, 04:46 PM   #3
ford525
Guest
Fan#: 23415
FF Reputation: 7 ford525 Good Standing Member
looks good i like the wite up
ford525 is offline
Old 04-20-2007, 04:47 PM   #4
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Very nice job Frank.
What did you use to pry the caps loose? A small flathead? And I assume the only way to do it is from directly behind the mirror correct?
Tom is offline
Old 04-20-2007, 04:55 PM   #5
Algorhythm
Fan#: 20623
Thanks everyone.. used a small flathead to get behind the caps. Started with the lone one first, then did the top one of the pair, then the bottom.
I didn't decide to do a write-up until afterwards and I wasn't going to put the caps back on to take pictures.
Old 04-20-2007, 07:08 PM   #6
bcskateshop
Fan#: 46058
What I Drive: 2006 Focus ZX3 SE Silver
FF Reputation: 1 bcskateshop Good Standing Member
Hey i have a cd silver foci too and want to do that since they dont make mirrors really for 05 up can youlet me know the kind of spray paint you used thanks
bcskateshop is offline
Old 04-20-2007, 07:10 PM   #7
Algorhythm
Fan#: 20623
No problem, I used Duplicolor auto paint for all 3.. TS is the color code.
Old 04-20-2007, 09:58 PM   #8
CKA
Fan#: 2313
What I Drive: '02 ZTS/'99 Explorer/'13 Fusion
FF Reputation: 74 CKA Excellent Standing Member
Buy-Sell-Trade Rating: (24)
Awesome how to!
Was this added to the How To archive?? It should be. :)
CKA is offline
Old 04-20-2007, 10:08 PM   #9
Algorhythm
Fan#: 20623
I just wrote this today.. haven't asked S2 to add it to the how-to archive.
Old 04-20-2007, 10:15 PM   #10
focusedintentions
focusedintentions's Avatar
Fan#: 7850
What I Drive: 07 Infiniti G35 6mt coupe silver
FF Reputation: 1 focusedintentions Good Standing Member
A lil bit of wet sanding on the caps with a nice buff and wax will really get them shiny!
My SVT is #604 of 1079
One of 104 with EAP
focusedintentions is offline
Similar Threads
side view mirror installation Crakaveli MK1 Focus 3 08-31-2009 03:07 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 11:06 AM
painting black body side moldings? fusor MK1 Focus 7 01-04-2006 06:41 PM
FS-OEM side view mirrors! 0dstrshn Archive 0 08-18-2004 08:34 PM
