General Specs on the 2.0L Duratec - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 04-18-2007, 11:22 AM   #1
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
As title says...........
Next is the later model Duratec:
General Specifications Item Specification
Engine
Displacement 2.0L
No. of cylinders 4
Bore/stroke 87.5/83.1
Firing order 1-3-4-2
Oil pressure (hot @ 2,000 rpm) 200-268 kPa (29-39 psi)
Belt tension Refer to Section 303-05.
Oil capacity 3.9L + 0.38L (4.1 qt + 0.4 qt) with filter
Cylinder Block
Cylinder bore diameter 87.5-87.53 mm (3.444-3.445 in)
Cylinder bore maximum out-of-round 0.008 mm (0.0003 in)
Main bearing bore diameter 57.020-57.038 mm (2.244-2.245 in)
Head gasket surface flatness 0.1 mm/general 0.05 mm/200 x 200 (0.004 in/general) (0.0019 in/7.87 x 7.87)
Piston
Diameter (1) 87.5-87.51 mm (3.444-3.445 in)
Diameter (2) 87.51-87.52 mm (3.4452-3.4456 in)
Diameter (3) 87.52-87.53 mm (3.444-3.446 in)
Piston-to-bore clearance 0.025-0.045 mm (0.0009-0.0017 in)
Ring groove width top 1.203-1.205 mm (0.0473-0.0474 in)
Ring groove width 2nd 1.17-1.19 mm (0.0.460-0.0468 in)
Ring groove width oil 2.501-2.503 mm (0.0984-0.0985 in)
Piston skirt coating thickness 0.008-0.020 mm (0.0003-0.0007 in)
Piston Pin
Diameter 20.995-21.0 mm (0.8266-0.8268 in)
Length 59.6-60.4 mm (2.346-2.377 in)
Piston-to-pin clearance 0.008-0.016 mm (0.0003-0.0006 in)
Pin-to-rod clearance Press fit
Cylinder Head
Valve lift @ zero lash (exhaust) 7.7 mm (0.30 in)
Valve lift @ zero lash (intake) 8.8 mm (0.35 in)
Valve guide diameter 5.509-5.539 mm (0.216-0.218 in)
Valve seat width intake/exhaust 0.99-1.84 mm (0.038-0.072 in)
Valve seat angle 45 degrees
Valve seat runout 0.075 mm (0.0029 in)
Valve lash adjuster bore diameter 31.00-31.03 mm (1.220-1.221 in)
Cam bore diameter 25.015-25.040 mm (0.984-0.985 in)
Valve
Valve head diameter intake 34.85-35.15 mm (1.372-1.383 in)
Valve head diameter exhaust 29.85-30.15 mm (1.175-1.187 in)
Valve stem diameter intake 5.470-5.485 mm (0.2153-0.2159 in)
Valve stem diameter exhaust 5.465-5.480 mm (0.2151-0.2157 in)
Valve stem-to-guide clearance intake 0.0027 mm (0.0001 in)
Valve stem-to-guide clearance exhaust 0.0029 mm (0.00011 in)
Valve face runout 0.05 mm (0.001 in)
Valve face angle 45 degrees
Valve Spring Compression Pressure
Intake and exhaust (installed) 17.5 kg (38.667 lbs)
Intake (valve open) 8.9 mm (0.35 in) of lift 44 kg (97.032 lbs)
Exhaust (valve open) 7.4 mm (0.29 in) of lift 42 kg (93.338 lbs)
Free length 44.92 mm (1.768 in)
Assembled height 37.9 mm (1.492 in)
Crankshaft
Main bearing journal diameter 51.980-52.000 mm (2.046-2.047 in)
Production repair 51.730-51.750 mm (2.036-2.037 in)
Main bearing clearance 0.019-0.035 mm (0.0007-0.0013 in)
Connecting rod journal diameter 49.980-50.000 mm (1.967-1.968 in)
Production repair 49.730-49.750 mm (1.957-1.958 in)
End play 0.22-0.43 mm (0.008-0.016 in)
Rings
Width top 1.17-1.185 mm (0.0460-0.0466 in)
Width 2nd 1.197-1.199 mm (0.0471-0.0472 in)
Width oil 2.38-2.45 mm (0.093-0.096 in)
Ring gap (in bore) top 0.16-0.31 mm (0.006-0.012 in)
Ring gap (in bore) 2nd 0.33-0.48 mm (0.012-0.018 in)
Ring gap (in bore) oil 0.2-0.7 mm
(0.007-0.027 in)
Valve Tappet
Diameter 30.97-30.98 mm (1.2192-1.2196 in)
Tappet-to-valve clearance intake 0.22- 0.28 mm (0.008-0.011 in)
Tappet-to-valve clearance exhaust 0.27-0.33 mm (0.010-0.013 in)
Tappet-to-bore clearance 0.02-0.06 mm (0.0007-0.0023 in)
Camshaft
Lobe lift intake 8.24999 mm (0.324 in)
Lobe lift exhaust 7.80007 mm (0.307 in)
Runout (1)a 0.03 mm (0.001 in)
Thrust clearance 0.09-0.24 mm (0.003-0.009 in)
Journal diameter 24.96-24.98 mm (0.982-0.983 in)
Journal-to-bore clearance 0.035-0.080 mm (0.001-0.003 in)
Connecting Rod
Bearing clearance 0.027-0.052 mm
(0.001-0.002 in)
Bearing thickness 1.496-1.520 mm (0.058-0.059 in)
Crank bore diameter 53.025-53.045 mm (2.087-2.088 in)
Pin bore diameter 20.965-20.985 mm (0.825-0.826 in)
Length (center to center) 154.8 mm (6.094 in)
Side clearance 1.95-3.05 mm (0.076-0.120 in)
Axial clearance 0.14-0.36 mm (0.005-0.014 in)
a No. 3 Journal Supported by No. 1 and No. 5 journals.
Engine
Displacement 2.3L
No. of cylinders 4
Bore/stroke 87.5/94.0
Cylinder Block
Cylinder bore diameter 87.5-87.53 mm (3.444-3.446 in)
Head gasket surface flatness 0.1 mm/general 0.05 mm/200 x 200 (0.003 in./general) (0.0019 in./7.87 x 7.87)
Piston
Diameter (3) 87.52-87.53 mm (3.4456-3.4460 in)
Ring groove width 2nd 1.17-1.19 mm (0.0460-0.0468 in)
Piston Pin
Diameter 20.995-21.0 mm (0.8265-0.8267 in)
Cylinder Head
Valve lift @ zero lash (exhaust) 7.4 mm (0.30 in)
Valve lift @ zero lash (intake) 7.9 mm (0.31 in)
Valve
Valve stem-to-guide clearance intake 0.0027 mm (0.00010 in)
Valve face runout 0.05 mm (0.0019 in)
Intake and exhaust (installed) 17.5 kg (38.667 lb)
Intake (valve open) 8.9 mm (0.35 in) of lift 44 kg (97.032 lb)
Exhaust (valve open) 7.4 mm (0.29 in) of lift 42 kg (93.338 lb)
Crankshaft
Rings
(0.007-0.027 in)
Valve Tappet
Camshaft
Connecting Rod
(0.001-0.002 in)
Motorcraft Metal Surface Cleaner ZC-21 WSE-M5B392-A
Silicone Gasket Remover ZC-30
Motorcraft Metal Surface Prep ZC-31
Silicone Gasket and Sealant TA-30 WSE-M4G323-A4
Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil XO-5W20-QSP (US); Motorcraft SAE 5W-20 Super Premium Motor Oil CXO-5W20-LSP12 (Canada); or equivalent WSS-M2C930-A
Motorcraft Premium Gold Engine Coolant with Bittering Agent (US only) VC-7-B (US); CVC-7-A (Canada); or equivalent (yellow color) WSS-M97B51-A1
Multi-Purpose Grease XG-4 and/or XL-5 ESB-M1C93-B
Thread Sealant with PTFE TA-24 WSK-M2G350-A2
High Temperature 4x4 Front Axle and Wheel Bearing Grease E8TZ-19590-A ESA-M1C198-A
Silicone Brake Caliper Grease and Dielectic Compound XG-3-A ESE-M1C17-A
Torque Specifications Description Nm lb-ft lb-in
Camshaft bearing capsa
Coolant outlet bolts 10 89
Cylinder head boltsa
Intake manifold bolts 18 13
Flywheel boltsa
Pressure plate bolts 27 20
Flexplate boltsa
Torque converter-to-flexplate nuts 35 26
Crankshaft pulley bolta
Crankshaft position (CKP) sensora
Crankshaft oil seal retainer boltsa
A/C compressor mounting bolts 25 18
A/C manifold tube bolt 21 15
Oil drain plug 28 21
Oil pan boltsa
Oil pan-to-bellhousing boltsa
Oil level indicator tube bolt(s) 10 89
Oil pump screen and cover assembly 10 89
Oil pressure sensor 15 11
Oil filter adapter bolts 25 18
Oil pump-to-engine block boltsa
Oil pump sprocket bolt 25 18
Oil pump chain tensioner bolts 10 89
Oil pump chain guide bolts 10 89
Knock sensor (KS) 20 15
Rear transaxle mounting nut 133 98
Motor mount nuts 90 66
Motor mount bracket bolts 48 35
Transaxle roll-restrictor bolts 48 35
Engine-to-bellhousing bolts 48 35
Starter motor mounting bolts 25 18
Starter B+ cable 12 9
Starter relay 5 44
Coolant pump bolts 10 89
Coolant pump pulley bolts 20 15
Engine front cover boltsa
Camshaft sprocket bolt 72 53
Valve cover boltsa
Engine lifting eye bolts 45 33
Exhaust gas recirculation (EGR) valve assembly bolts 20 15
EGR tube nut 55 41
Valve cover retainers 10 89
Heated oxygen sensor (HO2S) and catalyst monitor sensor wire connector bracket nuts 25 18
Bellhousing-to-engine bolts 48 35
Bellhousing-to-engine stud bolt 48 35
Engine-to-bellhousing stud bolt 48 35
Engine front cover-to-oil pan boltsa
Power distribution harness eyelet nut 10 89
Catalytic converter-to-cylinder head nutsa
Catalytic converter-to-muffler assembly nuts 47 35
Catalytic converter support bracket 47 35
Catalytic converter heat shield bolts 10 89
Generator mounting bolts 25 18
Generator heat shield 18 13
Generator B+ cable 8 71
Generator B+ cable retainer 25 18
Radio interference capacitor bracket 10 89
Radio interference capacitor ground 10 89
Thermostat housing assembly bolts 10 89
Coolant expansion tank bolt 10 89
Block heater (if equipped) 21 15
Power steering pump mounting bolts 25 18
Power steering pressure (PSP) tube nut 65 48
PSP tube bracket nut 11 8
Engine ground cable bolt 48 35
Accelerator control snow shield 10 89
Timing chain guide bolts 10 89
Timing chain tensioner bolts 10 89
Engine plug bolt 20 15
Crankcase ventilation cover assembly bolts 10 89
Air cleaner outlet tube clamps 4 35
Accelerator cable bracket 10 89
Coil-on-plug retaining bolt 10 89
Accessory drive belt tensioner bolt 25 18
Accessory drive belt idler bolt 25 18
Cylinder head temperature (CHT) sensor 12 9
Spark plugs 12 9
Fuel rail bolt 25 18
Stabilizer bar 55 41
Tie-rod end nut 40 30
Front brake caliper 28 21
Upper strut mount nuts 30 22
Suspension arm ball joint bolt 63 46
Intermediate shaft bracket-to-engine bolt 40 30
Intermediate shaft mounting bracket bolt 25 18
Catalytic converter nuts 55 41
Catalytic converter heat shield bolts 11 8
Catalytic converter support bracket bolts 47 35
Catalytic converter-to-exhaust system nuts 47 35
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
    Quick reply to this message
Closed Thread
Similar Threads
Duratec FAQ P0WeRbyDuratec DURATEC Performance (2003-2007) 66 05-17-2008 05:12 PM
2.5" exhaust options for 2.0L Duratec ZX3? geekspeed DURATEC Performance (2003-2007) 31 04-19-2007 09:06 AM
General Specs on the 2.3L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:21 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
For Sale: F2Focus Duratec 2.3L 2.0L Intakes NEW Discounted Prices ouikikazz Archive 5 08-04-2005 06:40 PM
