#1 | ||||
Focused Focus
General specs on the SPI
I am going to list about all the specs that you guys may need. This is being done mainly because of all the questions that I get from time to time and Doug (WD-40) was talking to me about doing a sticky for you guys, so here you go:
First is the SPi cars: General Specifications Item Specification Displacement 2.0 Liters (121 CD) Number of cylinders 4 Bore and stroke 84.8 mm x 88 mm Firing order 1-3-4-2 Oil pressure (hot 2000 rpm) 240 kPa -450 kPa Drive belt tension 178 N-311 N Compression ratio 9.35:±0.25 Coolant capacity 5.0-5.8 Liters Cylinder Head and Valve Train Item Specification (mm) Valve guide inner diameter (I.D) 8.063-8.094 Intake and exhaust 8.063-8.094 Valve seats width — intake and exhaust 1.75-2.32 Angle 45 degrees Runout (total indicated runout [T.I.R.]) 0.064 MAX Bore diameter (insert counterbore diameter) intake 39.940 MIN. 39.965 MAX. Bore diameter (insert counterbore diameter) exhaust 34.940 MIN. 39.965 MAX. Gaskets surface flatness 0.04/26 0.08/156 0.15 Total Head face surface finish 0.2/2.5 0.8 Valve stem to guide clearance intake 0.020-0.069 Valve stem to guide clearance exhaust 0.049-0.095 Valve head diameter intake 41.9-42.1 Valve head diameter exhaust 34.9-35.1 Valve face runout limit intake and exhaust 0.005 Valve face angle 45.5 degrees Valve stem diameter standard (std.) intake 8.025-8.043 Valve stem diameter standard (std.) exhaust 8.006-8.017 Valve springs 4.3 turns Compression pressure — loaded 83.0 N @ 29.27 Compression pressure — unloaded 350 N @ 39.53 Free length (approximate) 52.4 Installed spring height 39.53 Valve springs assembled height 39.53 Service limit, pressure lost @ specified height % 5 Rocker Arm Item Specification (mm) Ratio 1.65 Valve tappet, hydraulic diameter (std.) 22.200-22.212 Clearance to bore 0.023-0.065 Roundness 0.013 Finish micro 0.2 Service limit 0.127 Collapsed tappet gap 0-4.5 Tappet bore diameter 22.25 ± 0.15 Camshaft bore inside diameter no. 1, 2, 3, 4, 5 45.796-45.821 Camshaft Item Specification (mm) Lobe lift intake 6.23 Lobe lift exhaust 6.23 Allowable lobe lift loss 0.127 Theoretical valve maximum lift intake 10.28 Theoretical valve maximum lift exhaust 10.28 End play 0.02-0.20 Service limit 0.20 Journal to cylinder head bearing surface clearance 0.03335-0.0835 Journal diameter standard 45.7375-45.7625 Runout limit 0.127 (runout of center bearing relative to bearing nos. 1 and 5) Out-of-round limit 0.08 Camshaft drive assembled gear face runout crankshaft 0.65 Camshaft drive assembled gear face runout camshaft 0.275 Cylinder Block Item Specification (mm) Head gasket surface finish roughness height (CLA) 3.8-2.0 Head gasket surface finish roughness height cut-off 0.8 Dowel height chamfer 0.8x30° Dowel height chamfer total 12.5 Cylinder bore diameter 84.8 Piston to cylinder bore clearance 0.020-0.040 Surface finish (RA) each bore min. 15-38 Average of all bores of a cylinder block (Ra) min. 20-30 Out-of-round limit 0.025 Tappet limit 0.013 Main bearing bore diameter @ ± 30° PF Bearing Cap P/L 62.2835-62.3145 Main bearing bore diameter other than above 62.2935 ± .0100 Crankshaft Item Specification (mm) Main bearing journal diameter 57.98-58.0 Out-of-round limit 0.008 Taper limit 0.008 per 25.4 (l) Journal runout limit (runout of bearing 2, 3, and 4) 0.05 Crankshaft end play 0.100-0.300 Surface finish (RMS) micro 0.3 Clearance to crankshaft 0.020-0.065 Thrust bearing journal length 28.825-28.854 Connecting rod journal length 28.825-28.854 Out-of-round limit 0.008 Taper limit 0.008 per 25.4 (l) Surface limit (RMS) micro 0.6 rear Surface limit (RMS) micro 0.9 front Main bearing thrust face surface finish (RMS) micro 0.6 Main bearing thrust face surface finish (RMS) rear micro 0.9 Main bearing thrust face surface finish (RMS) front runout limit 0.025 Runout limit (T.I.R.) 0.180 Flywheel ring (gear lateral runout (T.I.R.) manual transmission 1.5 Crankshaft end play 0.100-0.300 Connecting Rod Item Specification (mm) Connecting rod bearings clearance to crankshaft 0.020-0.065 Bearing wall thickness (std.) 1.476-1.488 Clearance of crankshaft without cylinder head desired — 0.0457-0.0660 Clearance of crankshaft without cylinder head allowable — 0.0461-0.0859 Clearance of crankshaft with cylinder head desired — 0.0279-0.0483 Clearance of crankshaft with cylinder head allowable — 0.0276-0.0674 Bearing wall thickness 2.117-2.129 Connecting rod piston pin bore diameter 20.570-20.610 Crankshaft bearing bore diameter 46.89-46.91 Out-of-round limit — piston pin bore .008 Taper limit piston pin bore 0.0038/25.4 Length (center to center) 131.905-131.975 Out-of-round-limit — bearing bore 0.010 Taper limit — bearing bore 0.010 Alignment bore-to-bore (max. differential) twist 0.05 Alignment bore-to-bore (max. differential) bend 0.038 Side clearance (assembled to crank) standard 0.092-0.268 Side clearance (assembled to crank) service limit 0.356 Pistons Item Specification (mm) Piston-to-bore clearance rebuild 0.020-0.040 Piston-to-bore clearance service 0.020-0.070 Piston diameter 84.77-84.80 Pin bore diameter 20.632-20.641 Ring groove width compression (top) 1.53-1.55 Ring groove width compression (bottom) 1.53-1.55 Ring groove width oil 4.008-4.032 Ring groove width compression ring (top) to ring groove clearance 0.04-0.08 Ring groove width compression ring (bottom) to ring groove clearance 0.06-0.09 Squish height 0.908-1.858 Piston pin length 66.2-67.0 Diameter standard 20.622-20.631 Pin to piston clearance 0.007-0.013 Pin to rod clearance press fit — 8 KN Pistons rings Item Specification (mm) Piston ring width compression (top) 1.47-1.49 Ring width compression (bottom) 1.46-1.49 Ring width oil ring service limit (Side clearance) 0.15 MAX. Ring gap compression (top) 0.25-0.28 Ring gap compression (bottom) 0.25-0.28 Ring gap oil ring (steel rail) 0.04-1.68 Side clearance 1st ring 0.04-0.08 Side clearance 2nd ring 0.04-0.09 Lubrication System Item Specification (mm) Oil pump relief valve spring tension 41.4-45.8 N @ 28.1 Relief valve-to-bore clearance 0.02-0.08 Oil pump type Gerotor Rotor clearance outer gear to housing clearance 0.074-0.161 Rotor clearance inner and outer gear to cover clearance (end play) 0.013-0.089 Rotor clearance inner to outer gear tip clearance 0.05-0.18 Oil capacity with filter 3.76 Liters Lubricants Specification Super premium 5W20 SAE engine oil XO-5W20-QSP WSS-M2C153-H Silicone gasket and sealant F7AZ-19554-EA WSK-M2G343-A4 Crankcase conditioner B7A-19579-C ESR-M99C80-A Torque Specifications Description Nm lb-ft lb-in Intake manifold nuts 10+90 degrees 10+90 degrees 89+90 degrees Intake manifold bracket nuts and bolts 10 — 89 Front engine accessory drive bracket bolts 47 35 — Front engine accessory drive bracket nuts 47 35 — A/C compressor bolts 25 18 — Upper generator bolts 48 35 — Lower generator bolt 48 35 — EGR valve to intake manifold 25 18 — EGR valve to EGR manifold tube 24 18 — EGR manifold tube to exhaust manifold 6 — 53 Flexible exhaust pipe 47 35 — Exhaust manifold nuts 27 20 — Catalytic converter to exhaust manifold bolts 40 30 — Oil control plug, iB5 transmission 35 26 — Thermostat housing 13 10 — Starter motor to transaxle 35 26 — Lower transaxle flange bolts 47 35 — Upper transaxle flange bolts 47 35 — Left-hand transaxle flange bolts 47 35 — Engine roll restrictor to transaxle 48 35 — Engine roll restrictor to subframe 48 35 — Rear engine mounting to body 48 35 — Rear engine mounting (nut on transmission mounting bracket) 133 98 — Front engine mounting to engine 80 59 — Front engine mounting to body 48 35 — Wheel nuts 128 94 — Suspension strut to body 48 35 — Lower suspension arm ball joint to spindle carrier 47 35 — Power steering pump 23 17 — Power steering pump pulley 47 35 — Cylinder head boltsa — — — Timing belt tensioner 25 18 — Spark plugs 15 11 — Oil level indicator tube 10 — 89 Valve cover bolts 9 — 80 Ignition coil (EI) bracket to cylinder head 10 — 89 Rocker arms 25 18 — Camshaft thrust plate bolts 10 — 89 Camshaft pulley bolt 105 77 — Camshaft position sensor (CMP) 25 18 — Oil pressure switch 13 10 — Oil pump 13 10 — Oil pump tube 10 — 89 Coolant pump 25 18 — Oil intake pipe to oil pump 10 — 89 Main bearing bolts 99 73 — Rear crankshaft oil seal retainer 25 18 — Big end bearing cap nuts (stage 1) 38 28 — Intermediate shaft bracket 48 35 — Oil pan to crankcase 25 18 — Oil pan baffle 25 18 — Upper timing belt cover 48 35 — Lower timing belt cover 10 — 89 Upper strut mount nuts 30 22 — Engine oil drain plug 25 18 — Knock sensor 20 15 — Flywheel 82 60 — Crankshaft position sensor 6 — 53 Crankshaft pulley 120 89 — Battery tray 25 18 — a refer to the procedure in this section Second is the Zetec cars: Engine Data Description 2.0L DOHC 16V Engine management EEC V/SEFI Emission standard 96 EEC Fuel 91 RON unleaded Identification code CAA Firing order 1-3-4-2 Bore 84.8 mm Stroke 88.0 mm Cubic capacity 1,988 cm3 Compression ratio 9.6:1 Maximum engine performance at 5,300 rpm 130 hp Maximum engine torque at 4,000 rpm 130 lb ft Idle speed rpm 800 rpm Speed limitation (rev/min) 7,100 rpm Engine Oil Viscosity/ambient temperature Description Specification Recommended engine oils — — SAE 5W-20/below -30°C to over +40°C SAE 5W-20 Engine Oil certified for gasoline engines by the American Petroleum Institute ILSAC GF-3 and WSS-M2C153-H SAE 5W-20/below -30°C to over +40°C Ford Formula E Economy Engine Oil ACEA A1/B1 and WSS-M2C914-A If engine oils of this specification are not available, engine oils of specification API SH/EC, ACEA A2/B2 or ACEA A3/B3 may also be used. Capacities Description Liters Engine oil, initial fill including filter 4.35 Engine oil, oil change including filter 4.25 Engine oil, oil change excluding filter 3.75 Lubricants, Fluids, Sealers and Adhesives Item Specification Sealant, camshaft bearing caps WSK-M2G348-A5 Sealant, cylinder block mating faces (Hylosil 502) WSK-M4G320-A Sealant, cylinder block mating faces (Loctite Ultrablack) (alternative) WSE-M4G320-A2 Sealant, crankshaft position sensor ESW-1C155-A Sealant, crankshaft position sensor (alternative) WSD-M1C-226-A Sealant, oil pan WSE-M4G323-A6 Thread locking compound SDM-M4G9107-A Spark plug thread lubricant (Never Seeze) WSD-M13P8-A1 Lubricant, injection nozzle O-rings WSEM-2C903-A1 Silicone grease for spark plug connector seal A696-M1C171-AA High-temperature grease for clutch disc engagement splines ESD-M1C220-A Cylinder Block Description mm Cylinder bore diameter, class 1 84.800-84.810 Cylinder bore diameter, class 2 84.810-84.820 Cylinder bore diameter, class 3 84.820-84.830 Inner diameter, main bearing shells installed 58.011-58.038 Inner diameter, main bearing shells installed (main bearing shells with stepped sizes) 58.008-58.031 Main bearing radial clearance 0.011-0.058 Main bearing radial clearance (main bearing shells with stepped sizes) 0.020-0.042 Main bearing parent bore 62.287-62.300 Pistons Description mm Piston diameter, class 1. 84.770-84.780 Piston diameter, class 2. 84.780-84.790 Piston diameter, class 3. 84.790-84.800 Piston clearance in cylinder 0.010-0.030 Piston ring gaps (installed) a Upper compression ring 0.30-0.50 Lower compression ring 0.30-0.50 Oil scraper ring 0.40-1.40 a The piston ring gaps must be distributed evenly around the circumference of the piston This also applies to the oil scraper ring elements. Align the ring gaps at 120 degrees to each other. Crankshaft Description mm Main bearing journal diameter 57.980-58.000 Crankshaft end play 0.09-0.26 Connecting rod bearing journal diameter 46.89-46.91 Lower Crankshaft Spacer Description mm Required spacer washer thickness if there is a gap between the cylinder block and the lower crankcase of: 0.26 mm-0.50 mm 0.25 0.51 mm-0.75 mm 0.50 Connecting Rod Description mm Big end bore diameter 49.89-49.91 Small end bore diameter 19.951- 19.981 Inner diameter, connecting rod bearing shells installed 46.926- 46.960 Radial connecting rod bearing clearance 0.016-0.070 Axial connecting rod bearing clearance 0.090-0.320 Piston Pin Description mm Piston pin length 55.800- 56.200 Piston pin diameter, white 19.997- 20.000 Piston pin diameter, red 20.625- 20.628 Piston pin clearance in piston 0.016-0.049 Camshaft Description mm Bearing journal diameter 25.960- 25.980 Camshaft bearing radial clearance 0.020-0.070 Camshaft end float 0.080-0.220 Lobe lift intake 8.90 Lobe lift exhaust 8.70 Theoretical valve maximum lift intake 8.90 Theoretical valve maximum lift exhaust 8.70 Valves Description mm Valve clearance in the valve guide Intake valve 0.017-0.064 Exhaust valve 0.017-0.064 Intake valve clearance (at 20°C ± 5°C) 0.11-0.18 Exhaust valve clearance (at 20°C ± 5°C) 0.27-0.34 Cylinder Head Description Specification Maximum distortion (mating surface) 0.1 mm Height of mating surface 1.76 mm-2.12 mm Peak-to-valley height of mating surface (reference length 2.5 mm vertical to groove direction) R 3z = 6.0 μm Oil pressure at 800-850 rpm 1.3 bar-2.5 bar Oil pressure at 4000 rpm 3.7 bar-5.5 bar Torque Specifications Description Nm lb-ft lb-in Hose clamps 4 — 35 Intake manifold studs 5 — 44 Intake manifold bolts and nuts 18 13 — EGR tube assembly to EGR valve 40 30 — EGR pipe to ignition coil bracket 6 — 53 EGR tube assembly to catalyst 40 30 — Heat shield to exhaust manifold 10 — 89 Exhaust manifold studs 5 — 44 Exhaust manifold nuts 16 12 — Catalytic converter to exhaust manifold 48 35 — Catalytic converter to exhaust 47 35 — Right-hand driveshaft center bearing 25 18 — Generator to bracket 25 18 — Generator bracket to upper cylinder block bolts 25 18 — Generator bracket to lower cylinder block bolts 65 48 — Transmission flange bolts 47 35 — Starter motor to transmission 35 26 — Oil drain plug, MTX transmission 45 33 — Oil control plug, MTX transmission 45 33 — Flywheel bolts 112 83 — Clutch pressure plate 29 21 — Engine roll restrictor to transmission 48 35 — Engine roll restrictor to subframe 48 35 — Engine rear mount to body 48 35 — Engine rear mount (nut on transmission mounting bracket) 133 98 — Engine front mount to engine 80 59 — Engine front mount to body 48 35 — Power steering pump to bracket 24 18 — Power steering pump bracket 48 35 — Cylinder head bolts a — — — Camshaft bearing cap boltsa — — — Cylinder head covera — — — Spark plugs 15 11 — Timing belt tensioner 25 18 — Camshaft timing belt pulleys 68 50 — Upper timing belt cover 10 — 89 Ignition coil (EI) bracket to cylinder head 21 15 — Thermostat housing 20 15 — Fuel rail 10 — 89 Engine rear lifting eye 16 12 — Engine rear lifting eye studs 6 — 53 Engine front lifting eye 47 35 — Cylinder blocka — — — Engine oil drain plug 25 18 — Oil pressure switch 27 20 — Cylinder block oil gallery blanking plugs 23 17 — Heater pipe bracket to oil pan 10 — 89 Oil pan to lower crankcasea — — — Lower crankcase to cylinder block 22 16 — Oil pump 11 8 — Oil intake pipe to oil pump 10 — 89 Main bearing boltsa — — — Connecting rod bearing cap boltsa — — — Coolant pump 18 13 — Crankshaft rear oil seal carrier 20 15 — Drive belt idler pulley 40 30 — Crankcase ventilation pipe bracket 23 17 — Crankcase ventilation 10 — 89 Coolant pump pulley 24 18 — Crankshaft belt pulley 115 85 — Crankshaft position sensor bracket 21 15 — Crankshaft position sensor to bracket 8 — 71 Idler pulley 23 17 — Knock sensor 20 15 — I am continuing on another thread for the rest.........
"The right driver can work magic" Oct 2005 Ride of the month. SVT Squad #25 Call me Mike...... Give rep points and feedback when you appreciate someone on here! |
Remove Advertisements |
Fan#: 1
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Show Some Pride For The Spi !!! | FocusOnMySpi | SPI Performance (2000-2004) | 65 | 12-28-2008 02:55 PM |
| General Motors Death Watch 58: Supply Side Economics | Kneel | Ford Focus & General Car Chat | 21 | 02-28-2006 07:32 PM |
| Zetec swap for an SPI! | tfdmissmatch | Engine & Transmission Swap | 104 | 10-27-2005 10:33 PM |
| torque specs | madddogg | General Technical Chat | 11 | 06-21-2004 09:51 PM |
