remove front strut - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2007, 01:25 AM   #11
rnrbldrlvr24
Fan#: 42614
What I Drive: 2005 flame red srt-4
FF Reputation: 1 rnrbldrlvr24 Good Standing Member
thanks for everyones help. we found out that the spring wasnt compressed far enough to let the knuckle come all the way off but we got it compressed more and now everything is smooth as butter. But thanks again for everyone who helped
2005 red srt4
rnrbldrlvr24 is offline
Old 04-13-2007, 01:25 AM   #12
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing Member Peregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
No prob.
Peregrine is offline
Old 02-04-2012, 09:14 PM   #13
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
perpetual problem...update on old post
Here's a tip for anyone faced with removing stubborn struts from older Focii...
I just installed new struts - but only after battling through a decade of rust & winter salt corrosion that had cemented the old ones to the car!
The passenger side went okay, but the drivers side was impossible - the strut was rusted into the lower mount. With the pinch bolt removed and the entire front end submerged in WD40, I beat the steering knuckle like a red-headed stepchild, but it barely budged.
Then I got one of those once-a-year inspirations: I inserted a "key" (any piece of thin, hard steel) into the knuckle gap so that it covered the pinch bolt hole. While holding the key in place with one hand, I threaded the pinch bolt into the wrong side of the knuckle, until they met. I continued threading-in the bolt with a drive ratchet until the knuckle expanded and separated from the strut.
Here's a photo (after the strut was removed) of the drivers side knuckle showing the trick:
Some suggestions:
  • Prior to embarking on this procedure, wire-brush the pinch bolt and clean/lube the threads inside of the knuckle. This will prevent unnecessary thread damage, as well as allow you to hand-thread the bolt.
  • Expand the knuckle gap no more than necessary. Ie., don't overtorque the pinch bolt, so as to not deform the knuckle. In fact, after removing the strut, verify that both sides of the knuckle remain on-axis by fully threading the pinch bolt into the correct side of the knuckle and ensuring that it grabs the threads cleanly; this will provide some reassurance that no unpleasant surprises await you when installing the new strut.
  • Insert the key into the knuckle gap prior to threading the pinch bolt, so that you can use a mirror to peer down the bolt hole and determine when the key is fully covering it. The heart of this trick is the key blocking the pinch bolt's progression.
Some notes on the "key":
  • Key must be hard steel (ideally, hardened) otherwise the pinch bolt will simply deform it. A nickel, quarter, or your ex's house key won't work!
  • Key thickness should match your knuckle gap - about the thickness of the strut hook (a little thicker than a quarter).
  • In a normal strut installation, the strut hook points to the engine and occupies most of the knuckle gap, engaging the pinch bolt there from the top, side (engine-side), and part of the bottom. That leaves a small opening in the bottom of the knuckle gap, so your key must be long & narrow enough to squeeze in there - but not too narrow because it must be wide enuf to cover the bolt hole. (If you are able to leverage/bang the strut out of the knuckle by at least 1/4", then the hook will no longer block access to the side & bottom of the gap, giving you a wider choice of key geometries.)
  • For my key: I used bolt cutters to snip the hook off of the other old strut I had removed earlier. Its hook-shape allowed me to fish it up into the gap and cover the bolt hole, as shown in the photo above.
Good luck!!
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-04-2012, 10:50 PM   #14
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
thats a great idea..
today i used a crow-bar to get ball joint out.. i guess your thing works the same way..lol
fhh02a is offline
Old 04-10-2013, 06:48 PM   #15
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
Forum Activity 8%
FF Reputation: 1 finalfantasy Good Standing Member
I just got my passenger strut off only removing the sway link bolt and strut pinch bolt (and 13mm nuts on top of course too). I tapped the knuckle w a copper hammer to finally clear it from the knuckle.
All these howtos show removing the control arm bolt and tierod end in addition, but I can't afford an alignment right now :(
This method wouldn't affect my drive axle or CV joint, would it?
finalfantasy is offline
Old 04-11-2013, 03:16 AM   #16
finalfantasy
Fan#: 86774
Forum Activity 8%
anybody?
Old 04-11-2013, 03:57 AM   #17
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 30%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
That's all you do. Except we usually use a rubber mallet when the strut wants to be difficult coming out or going in. Sometimes have to wack the crap out of the strut and or knuckle a lot along with some wd40 to get it out if its sticking. Then a jack underneath can help to raise the knuckle/rotor assembly to more easile seat the new strut. Shouldn't have to touch anything to do with tie rods or cv axles. At least we didn't on the 7-8 different suspension swaps I've done. And we had no alignemnt issues either.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is offline
Similar Threads
Front Strut Brace Question saves th3 day Wheels & Tires 10 01-02-2007 08:58 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
How to completely remove front fenders gthang MK1 Focus 6 12-19-2004 12:29 PM
WTB: FS Front and Rear strut bars 03ChromeZX5 Archive 2 08-07-2004 09:57 PM
Front Strut Bar, WOW!!!! AuthentiCustomz Wheels & Tires 8 07-26-2004 01:53 PM
