"back to stock" question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-08-2007, 01:10 AM   #1
UtahSVT
UtahSVT's Avatar
Fan#: 12785
What I Drive: '04 Black P-chrgd SVT ZX3
Points 4,526, Level 42
Points: 4,526, Level: 42 Points: 4,526, Level: 42 Points: 4,526, Level: 42
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 UtahSVT Good Standing Member
Buy-Sell-Trade Rating: (23)
I had a quick question, wondering if someone could point me in the right direction. As some of you know, I just recently sold my Procharger and changed my car back to stock, got some used SVT injectors from "CDSilver5doorSVT" (they have a blue top on them??) and reflashed back to stock. The car starts and ran ok at first. Took her for a little spin, I still have my narrow band A/F gauge hooked up and it usually just scans back an forth but when I was cruising in about 4th gear it seem to be stuck on RICH and the car kind of sputterd and jerked a couple times. Took it back home, checked the MAF -- looks good, intake looks good, injectors look good. Started the car up again in the driveway, ran rich for about 1 minute then slowly went back to lean then sputtered and died.???? No CEL's. I'm probably gonna be getting a tune from Tom within the next couple days, so hopefully that will clear some things up but suggestions for now would be appreciated. Thanks, Derek
July 2006 Ride of the Month
UtahSVT is offline
Old 04-08-2007, 01:38 AM   #2
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Do you have a wideband O2 sensor? If not I would take anything the AFR gauge is telling you with a grain of salt, without a wideband those things are just a light show. When you ran it in the driveway, did the exhaust have a gas smell to it, or was it coming out with a lot of soot in it? It could just be the ECU is learning everything for the first time...since flashing it back to stock, how many miles have you put on it?
SkaAddict is offline
Old 04-08-2007, 03:14 AM   #3
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
Having thought about going back to N/A before. I have worried how the car would react if any different. Cause I'm contemplating selling the blower after my milage gets higher (at 91K now), I kinda wondered if it would run worse after replacing the stock MAF, injectors, intake mani ect. I would think if done right, shouldn't be a problem. I'm with ^^^ on the ECU relearning the N/A stock tune, or did you forget how awful they run stock?
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 04-08-2007, 03:12 PM   #4
UtahSVT
UtahSVT's Avatar
Fan#: 12785
Yeah when I was running in the driveway it did smell a little "gassy". Since reflashing it back to stock I've probably driven it 5 miles. It seems to do ok from 1st to 3rd but 4th is where I kind of noticed it acting funny. I do have a wideband but I only have the narrow hooked up right now -- waiting until I decide if I'm gonna keep my car and try to go turbo before I install it. It could be that I have remnents of 6 month old gas from sitting so long too. I'm gonna get a tune from Tom so hopefully that will make things a little better and yes going back to stock from 10psi of boost is sooooo very disappointing!!
UtahSVT is offline
Old 04-09-2007, 12:16 AM   #5
UtahSVT
UtahSVT's Avatar
Fan#: 12785
Ok, so I went and started the car up again today, planning on taking it out to let the ECU re-learn the stock tune.... started it up, let it run for about 30 seconds and then my gauges go blank -- all dashes???????
UtahSVT is offline
Old 04-09-2007, 01:11 AM   #6
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
?????? That's really wierd. Sounds like an issue with reloading the factory tune properly?
SOLD
Old 04-09-2007, 06:55 AM   #7
v8focus1
v8focus1's Avatar
Fan#: 2562
What I Drive: 2002 PW Focus SVT Malibu Blue
FF Reputation: 20 v8focus1 Great Standing Member
Check the wires at the battery cables, you may have a loose wire there causing the problems.
Ian Saville-Modification Specialist/teacher
2000 Zx3 SHOcus(Yolk)(3.0L DOHC SHO swap)
2002 Zx3 PW BBK SVT engine/trans swap(Malibu Blue)
260hp, 213tq thanks to McNews
v8focus1 is offline
Old 04-09-2007, 06:22 PM   #8
UtahSVT
UtahSVT's Avatar
Fan#: 12785
Disconnected the battery today, started again, and got numbers back on my gauges BUT now I'm throwing P1000, and B1681???????? Suggestions? I've looked up the codes but they aren't really helpful as far as what to fix.
UtahSVT is offline
Old 04-09-2007, 08:38 PM   #9
mboren
Fan#: 31799
What I Drive: 03 Red SVT Focus
FF Reputation: 0 mboren Newbie
Speaking of that gas smell, does that mean that you are running rich?? Because my car has had a pretty strong gas smell when starting up and idling, also my car has been idling very rough and not firing up correctly. THen it's sputtering and spitting, could it be because I live in Michigan and the weather is changing all the time? Also it has been harder to take off when sitting still like I'm flooding the engine and I haven't changed anything. Maybe you guys can help me out?
mboren is offline
Old 04-09-2007, 08:41 PM   #10
jstuver
I'M BACK!!!!
jstuver's Avatar
Fan#: 10693
What I Drive: 2003 SVT EAP / 2004 Jetta GLI 1.8t
FF Reputation: 6 jstuver Good Standing Member
i had my gauges go to dashes when my fuel pump was bad- dont know if that helps but there it is
155.4 whp / 139.9 lbsft tq - custom tuned by Tom!!
jstuver is offline
Similar Threads
Cam Gear question (Not the regular question) seraphim SVT Performance (2002-2004) 13 10-12-2005 12:48 PM
Question about upgrading Audiophile package in 2005 ST Nevyr28 Car Audio, SYNC, MyFord Touch & Electronics 0 09-22-2005 07:29 PM
Hard Drive Based Decks Question FreeAgent Car Audio, SYNC, MyFord Touch & Electronics 4 05-04-2004 11:40 PM
