Car won't start only making clicking sound - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2007, 03:36 AM   #1
hail
hail's Avatar
Fan#: 20730
What I Drive: 2003, Sangria Red ZX5
FF Reputation: 1 hail Good Standing Member
Question Car won't start only making clicking sound
I was driving home with my music on and the HID's were all on and all of a sudden the radio turned off and the lights started to dim and the car loss accelaration.
I parked and the car died, I took the key out but the lights still worked. The dome light and blinkers would still turn on. I put the key back in and the car tried to turn on but all the lights went out and it didn't start. I took the key out again and when I put it back in it just clicked nothing else. Lights still work but the car won't start. I don't know what it could be, the battery is fine cause the windows go down and the lights work. The car has fuel and the dashbaord didn't display any lights, it just died without warning.
Does anyone know what it could be?? I need help.
hail is offline
Old 03-30-2007, 03:40 AM   #2
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
What I Drive: 2010 Scion XB RS7
Points 10,155, Level 67
Points: 10,155, Level: 67 Points: 10,155, Level: 67 Points: 10,155, Level: 67
Level Up 27% Completed
FF Reputation: 44 zx505focus Great Standing Member
Buy-Sell-Trade Rating: (19)
it is you altenator, even with no altenator your battery still work trust me it happen to me too, your car will light up but you wont have power to start your car.
zx505focus is offline
Old 03-30-2007, 03:41 AM   #3
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 86,010, Level 100
Points: 86,010, Level: 100 Points: 86,010, Level: 100 Points: 86,010, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Moving to technical discussion.
First check your battery cable connection and make sure its not loose. From the clicking noise, its very likely that your battery is bad. I would start there first before moving to the alternator.
Tom is offline
Old 03-30-2007, 04:02 AM   #4
jmotank
"Party Pic WHORE"
jmotank's Avatar
Fan#: 10320
What I Drive: 2005 pitch black zx4 st
FF Reputation: 1 jmotank Good Standing Member
Buy-Sell-Trade Rating: (15)
yup, check the battery, then the alternator. i had the same thing happen on my mustang. it was just a loose battery terminal that had a bit of corosion. but it is also possible for your battery to have enought power for your lights to come on and windows work but not quite enough to crank your car. with it dying sudenly like that i would bet it's the alternator, but check all your battery possibilities first. check your cable conections. i've had sound systems in my cars loud enough to shake conections loose before. process of elimination my friend. good luck.
ST crew #29
team DURATEC #53
MBRP exhaust, SRI, BFG G-Force sports, Steeda STS, painted stock rims, 1 12" diamond audio D6 sub, 3201T audiobahn amp, JVC headunit, Kicker 6X8's, 2 Farad cole cap, FC front strut bar, under body LED kit
jmotank is offline
Old 03-30-2007, 04:21 AM   #5
hail
hail's Avatar
Fan#: 20730
Since the car won't start, wouldn't that have something to do with the starter?? My battery is an optimal battery which supposedly has the strength of 3 or so batteries. The check battery light never came on but neither did any other, it just turned off. The alternator was already replaced once on june of last year and they gave me a 1 year warranty.
hail is offline
Old 03-30-2007, 07:52 AM   #6
02ZX3inPA
Wrenchin' aussie pos
02ZX3inPA's Avatar
Fan#: 45346
What I Drive: The Blue Devil
FF Reputation: 40 02ZX3inPA Great Standing Member
When they replaced the alternator, did they replace the 3-prong plug at the top of the alt? Mine went bad(one wire got just a LITTLE bit loose) and fried my alternator. There were literally droplets of plastic on the fins of the alternator housing. I agree w/ the others though, battery connections first. Then charge the battery and see if it will start when fully charged. If so, go to alternator and that crappy plug!
ZC #154..Focus Nation..
02ZX3inPA is offline
Old 03-30-2007, 07:57 AM   #7
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
It can be a variety of things: starter, battery, altenator, connections, cables. Just because you have power to your windows doesn't mean the battery is good; windows draw very little power compared to a starter.
Egz is offline
Old 03-30-2007, 01:36 PM   #8
hail
hail's Avatar
Fan#: 20730
Well, they charged the battery and the car turned on but soon after it died. It was the alternator, I had warranty on it so I was only charged for the labor which was $117. My car is back up and running. I don't want this thing to die out on me again so should I get a capacitor or an extra battery for my sound system?? I have a 2000 watt system.
hail is offline
Old 03-30-2007, 02:06 PM   #9
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
2,000 Watts? I realize that this is only a peak rating, but if it is putting out 2,000 watts, even momentarily, this would be a current flow of more than 150 amps, or the equivalent of switching roughly 35 headlights on and off going from max output to silence.
That cannot be good for the battery/charging system.
I would think an extra battery or capacitor to dampen the current demand and smooth out the fluctuations seen by the battery and alternator would be a prudent move.
penguin is offline
Old 03-30-2007, 10:41 PM   #10
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,712, Level 78
Points: 14,712, Level: 78 Points: 14,712, Level: 78 Points: 14,712, Level: 78
Level Up 66% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 90 goinloco1 Excellent Standing Member
first thing is the stock alternator was never meant for that high of current demands, it will put out about 110 amps, but this is for battery charging and not meant to be continuous.
todays alternators are made to maintain a batteries charge and run low amp stock accesories.
a cap isnt going to do crap, a second battery or an actual alternator built for this purpose is what you need.
goinloco1 is offline
Similar Threads
You're doing it wrong! AKA Rice Reports(Post autofails here!) mattsstang87 Ford Focus & General Car Chat 15262 01-26-2015 11:04 PM
How to buy a used car you already found (a bit long) Jojos ZTS Focus Ford Focus & General Car Chat 2 04-03-2006 08:16 AM
Car won’t start. Dashes on Odometer. Computer problem? foctacular General Technical Chat 2 11-04-2005 05:52 PM
Prospective Buyer: Basic Newb Questions Hamada Ford Focus & General Car Chat 14 12-01-2003 03:43 PM
