Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus Technical Chat
Ford Focus Technical Chat This section is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls.
Thread Tools Search this Thread Display Modes
Old 03-28-2007, 10:55 PM   #1
2002_zts
2002_zts's Avatar
Fan#: 40104
What I Drive: 2002 CD silver Mach edition ZTS
FF Reputation: 1 2002_zts Good Standing Member
Unhappy AC and interior fan problems
Well I am having a batch of problems with my car right now and was wondering if anybody could help out.
On the 11th my battery and alternator went out and were replaced at a cost of over $400.
Yesterday (25th) I washed my car.
Now my horn sounds as if it is muffled or full of water which I could care less about since I never use it.
What really bothers me is that my interior fan is not working any more. It worked fine (i think) this morning.
The problem is that I can press the AC button and turn the controller to positions 1-3 and the AC light stays on, but the fan will not come on. In position 4 the fan starts to blow at full force, but the AC light goes out. I have the same problems with the fan blowing without the AC on as well.
Now what could be the problem with my car? I really enjoy driving my 2002 Focus . It only has 69000 miles (just clocked at 4AM) on it. I would hate to have things keep going wrong on it. But, it seems par for course with Ford, that once things start going bad, everything starts going out.
Don't get me wrong, I love my Fords, and have always drivin Fords, as well as did my parents while I was growing up. But a Charger or Magnum is looking like it may want to be parked in my driveway more than the Focus.
Let me know what you think the problems may be, and where I should look to examine these new problems with the interior air.
Thanks
jeff
[B]2002 ZTS MACH edition[/B]
MODS: FFRP Multimatic Suspension, SVT front bumper w/ fogs, ROUSH front bumper/sideskirts (awaiting paint), TBS, Modified intake FUTURE MODS: ROUSH hood scoop, Window tint, Saleen TSW or 04 SVT rims
2002_zts is offline   Reply With Quote
Old 03-29-2007, 05:59 AM   #2
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS
FF Reputation: 9 drjkel Good Standing Member
It sounds suspiciously like your heater blower resistor assembly is bad. This assembly is used to reduce the fan motor speed on lower settings and is bypassed on the highest fan speed. Usually the thermal limiter on the assembly goes open. A new part retails from Ford for $15.51 and is easily replaced. The following thread shows where it is located:
http://www.focusfanatics.com/forum/s...d.php?t=106631
It can be easily troubleshot with a volt-ohm meter once removed. You must have continuity through the thermal limiter (silver "bullet") on the top or it is defective. Coincidentally, I just had this happen on my 2001 ZTS last week also after washing it.
Let the forum know how you make out. Good luck.
- drjkel
drjkel is offline   Reply With Quote
Old 03-29-2007, 07:32 PM   #3
2002_zts
2002_zts's Avatar
Fan#: 40104
Thats what it was.
i also found this post that really helped too. http://www.focusfanatics.com/forum/s...threadid=24988
You will need:
A. The new resistor pack.
B. An 8mm socket and suitable handle.
C. A flashlight (optional).
Step by step:
1. Open the glovebox, and empty it.
2. Squeeze the sides of the glovebox and drop it down.
3. Locate the resistor pack just to the left of the blower.
4. Squeeze the tab on the connector to the resistor pack and remove connector.
5. Remove the 8mm hex-head screw holding the resistor pack. Once loosened, it can be unscrewed by hand (don't drop the screw!). I found it easier to come from the bottom of the glovebox. Just pull the carpet/liner to the side from the left corner near the floor vents.
6. Lift the resistor pack from the bottom, it swings up and out.
Installation is the reverse of removal. Don't overtighten that screw!
Took me all of 30 min to do including the drive to the dealership to get the part and to take pictures while changing the part.
Now I just need to figure out what these wires are for.
Old 12-18-2008, 03:44 PM   #4
sebaland
Fan#: 28390
FF Reputation: 1 sebaland Good Standing Member
Thanks!
sebaland is offline   Reply With Quote
Old 07-27-2009, 04:26 PM   #5
BigEd
Fan#: 38134
FF Reputation: 1 BigEd Good Standing Member
Have you had this car since new?
If not, then the possibility of keyless entry, remote start, or some other alarms system is possible, or a connection for an aftermarket stereo component.
I had a speaker to preamp adapter behind the factory radio in my 00 zx3 and then rca wires to the 2 15's subs and 600 watt amp in the hatch area. I actually had the shelf that connected to the hatch set so it would cover it completely when dropped and you never knew that setup was in the rear until I turned it on. I had people tell me they could hear me from 2-3 blocks away and it sounded excellent then.....
BigEd is offline   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
