Electric Trunk Release Issues - Focus Fanatics
Old 03-26-2007, 09:54 AM   #1
Flashheart
Fan#: 45417
What I Drive: 2005 Red ZX4
FF Reputation: 1 Flashheart Good Standing Member
Hi
My Girls trunk has taken on the nasty habit of releasing itself - while driving (she states when braking) and other intermittent times. I have not noticed it as I am never in the car - but yesteday when washing the car - the thing was unlocking like mad.
I did see there was a thread out there where the guy's focus was popping the trunk when braking - but there was no resolution on the thread.
My initial item - I disconnected the electric release at the trunk - after verifying her key did indeed work. Now my thoughts - as it seemed to release a lot when I hosed down the drivers door - is that where the locking module is? Or it could have been residual water getting to the back end of the car. Either way - looking for some input....
I do not have a manual nor a wiring diagram to check locations.
Thanks!
Flashheart is offline
Old 03-26-2007, 10:04 AM   #2
StealthGray
StealthGray's Avatar
Fan#: 19017
What I Drive: '04 Liquid Gray ZX3
FF Reputation: 12 StealthGray Great Standing Member
Buy-Sell-Trade Rating: (6)
My bet is that the trunk release and the brake lights are wired through the same harness and that you have a short somewhere around the drivers door. I don't know exactly where the wiring runs, but checking under the door sill plate is a good place to start.
Of course the unlocking when you're washing around the door may be a coincidence, especially with the whole car wet. Also check the wiring inside the trunk, especially in areas where a heavy or large load may have pinched the wires.
You know what a learning experience is? A learning experience is one of those things that says, 'You know that thing you just did? Don't do that.' - Douglas Adams
StealthGray is offline
Old 03-26-2007, 10:18 AM   #3
Flashheart
Fan#: 45417
I will check those items - but was curious about whether the lock module is in the door - as I checked and there was no water at the sill plate....but I would rather take the sill plate off than the door panel. I will definitely check the trunk wiring.
Any more help - greatly appreciated - as in if anyone has a wiring diagram ;)
Old 03-26-2007, 10:22 AM   #4
StealthGray
Fan#: 19017
Hmm, another thought, while you're poking around in the trunk check the grounds. It doesn't sound like a grounding problem, but then again grounding problems can do some REALLY strange things...
Old 03-26-2007, 10:44 PM   #5
hosmerunited
Fan#: 41415
FF Reputation: 5 hosmerunited Good Standing Member
check the harness in the back. i have a o1 se wagon and was having issues of blowing the fuse for the trunk release and the lock and unlock. while checking this out me and a buddy came across the wiring harness that goes from the car to the trunk door area had several major splits in the wire coating and 1 wire was actually cut and another 2 were starting to melt other wire coatings.
mike
hosmerunited is offline
Old 11-29-2007, 01:12 PM   #6
ZetecKing
Fan#: 50011
What I Drive: 2001 black/blue flake ZX3
FF Reputation: 3 ZetecKing Good Standing Member
Yeap had same problem and I changed the harness and it fixed my problem it took 30 mins to change the harness not hard I have two more harnesses
ZETEC CREW #207
ZetecKing is offline
Similar Threads
Trunk release blows fuse...everytime Be4life182 General Technical Chat 15 08-01-2013 02:27 AM
Auto Trunk Release Trouble cds General Technical Chat 7 05-23-2007 06:33 PM
Just arrived with a broken trunk release Bub General Technical Chat 5 07-24-2005 11:25 PM
Trunk Release dre1283 MK1 Interior Mods & Upgrades 6 11-12-2004 10:48 AM
Trunk Release dre1283 General Technical Chat 9 11-09-2004 10:18 PM
