Old 03-22-2007, 08:33 AM   #1
police_inspector
Fan#: 45260
FF Reputation: 1 police_inspector Good Standing Member
Zetec 1.6 engine problems?
Hi all
Need some advice,
I have a ford focus zetec 1.6 T reg
Been away for 4 weeks and car has been stilling on the drive during this time.
Now the focus doesn’t drive the way it should.
Fuel consumption has gone up and the engine feels gutless below 3000rpm.
Sometimes when I cold start the car, there is a slight smell of petrol in the air (this has only happen twice). The car starts first time, it will idle around 1200rpm until the engine is warm, at which point it will idle around 700rpm.
I have changed the spark plugs and the leads.
I have had the exhaust check by kwik fit under guarantee. They say it’s not the exhaust that is the problem.
Any advice on what the problem might be and will it be expensive to solve?
Thanks
police_inspector is offline
Fan#: 1
Old 03-22-2007, 09:12 AM   #2
whyme
Fan#: 41543
What I Drive: 2006 tureador red ZX3
FF Reputation: 1 whyme Good Standing Member
cars dont like to sit, change the oil the plugs and try to run the problem out. condesation builds up in the engine and fule system also, id run some dry gas to sap up any water in the lines. if this doesnt help within a week of normal driving then id look into checking and cleaning various sensors in the engine.
whyme is offline
Old 03-27-2007, 03:17 PM   #3
police_inspector
Fan#: 45260
idle rpm speed
Thanks
Im having the focus serviced this weekend. Is there anything I should advise them to have a look concerning this problem?
Also is it normal for the car to idle around 1400rpm when the engine is started cold? During this period I can actually drive the car when in gear without actually touching the accelerator.
After a few minutes of warming the car will then idle around 700pm.
The focus always starts first time with no problems.
Old 03-27-2007, 10:16 PM   #4
DerekNJND
Fan#: 42892
FF Reputation: 7 DerekNJND Good Standing Member
Originally Posted by police_inspector View Post
Thanks
There are alot of things that determine how fast/slow your vehicle will idle upon startup. 1400 rpm seems high to me but doesnt necessarily indicate a "problem."
I mean its really tough to guess here, theres alot of things that control your idle speed. Timing, crankshaft, various sensors, Fuel inj. system, air intake, vacuum, the list goes on and on and on.
DerekNJND is offline
Similar Threads
Engine Swat: Zetec for SVT Zetec Kwizatz-Haderah General Technical Chat 25 02-12-2007 12:06 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 11:06 AM
Zetec 1.6 or 1.8: how to tell? daveking General Technical Chat 4 11-08-2004 03:53 PM
Turbo for 1.6 Zetec jjayokocha General Forced Induction 0 11-05-2004 04:00 PM
Oem Zetec Engine Parts FocusOnMySpi Archive 1 03-14-2004 11:52 PM
