SVT Stage II Cams? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-16-2007, 03:08 PM   #11
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Doug- I contected him not that long ago and he said he could do still do it.
I'd be curious to know if anyone has installed them yet.
10-15hp for the money (cams/install/parts/shims/tuning/etc) was not worth it for 99% of the people out there.
WD40 is offline
Old 03-16-2007, 03:09 PM   #12
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
FF Reputation: 15 Anaxagoras1986 Great Standing Member
Mike I think your torque figure is WAY off! lol
CODESVT had them in his car. He said they were very strong and improved the midrange torque by a fair amount. His engine also blew up although that was because of the crappy eagle rods, not the cams...
Anaxagoras1986 is offline
Old 03-16-2007, 03:14 PM   #13
WD40
The Librarian
WD40's Avatar
Fan#: 5157
This is all i could find: These are spec for the SVT engine
Wow...that's a lot of specs! Where'd you find them?
The torque specs are exceptionally handy.
There's at least two errors I see right away:
1) Maximum engine speed 7,000 rpm <<<Should be 7,200
2) Maximum engine torque at 5,500 rpm 198 lb ft <<<Pardon me?! I'd KILL for that torque!!
Again, here's the cam specs from the earlier linked post:
From this thread:
http://www.focusfanatics.com/forum/s...ad.php?t=66366
Originally Posted by zetecinside View Post
This is what I found on the cat cams web site....
O.E.M.
ADMISSION ÉCHAPPEMENT
jeu [j] 0.25mm 0.25mm
ouverture [0.1mm+j] 277° 265°
ouverture [1.0mm+j] 230° 220°
levée soup. [j=0] 10.95mm 9.85mm ACCESOIRES NÉCESSAIRES
levée câme - -
calage levée maxi 145° 112° poussoirs: O.E.M.
temps ouverture [1.0mm+j] -30/80° 42/-2° coupelles: O.E.M.
levée au PMH [j=0] 0.25mm 1.05mm ressorts: O.E.M.
Originally Posted by WD40 View Post
^^^ Good find! ^^^
So, in English terms:
Int: Lift = .431 / Duration = 230° @ 1.0mm (.040")
Exh: Lift = .388 / Duration = 220° @ 1.0mm (.040")
"Advertised" duration is I-277° / E-265°.
I forgot to add those when I ran the numbers,
but that's mainly because it's much more accurate to list duration at a given lift.
In this case, .040". (most will list at .050")
WD40 is offline
Old 03-16-2007, 03:14 PM   #14
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
Thats directly from Ford, not me. I believe they maeasure that differently than say we would on a dyno.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 03-16-2007, 03:15 PM   #15
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
Remember i work for Ford Doug, lol. Thats directly from the workshop manual.
SVT Squad #25
Call me Mike......
Old 03-16-2007, 03:25 PM   #16
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
I recall a spec from Ford stating something around 145ft lbs....
Old 03-16-2007, 03:32 PM   #17
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Yeah, from the SVT Brochure:
170hp @ 7,000
145 lb-ft @5,500
Well, the horsepower matches, but that torque up near 200 has got to be a misprint.
And, I knew you worked for Ford.
Again, thanks for all the specs.
When I get some time, I'd like to put all the torque specs in a "sticky".
WD40 is offline
Old 03-16-2007, 03:37 PM   #18
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
It would be AWESOME if the SVT could muster nearlt 200ftlbs. That would totally cure the rediculous 1st gear problem!
Old 03-16-2007, 08:34 PM   #19
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I think someone is full of SHIT..... heres why...
1) On the SVT the cam position sensor is on the intake cam not the exhaust cam like on the Zetec. Without the cam position sensor your VCT will NOT function properly and the car will absolutly bake the engine from the inside out.
2) smaller cams are not going to give you more power.
Eagle rods are not crappy.. if he had problems its more than likely tune related.. you just dont bust a forged rod on a LOW power application.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 03-16-2007, 09:17 PM   #20
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
What are you talking about with Cam sensors? These are REGRINDS of SVT cams, not standard non-vct Zetec stuff. The heal was reground down and the profile was changed to increase duration and lift. And his was a boosted machine- not NA.
Eagle rods seem to be OK when you put ARPs in them (is there any other way?) because they have very small connecting rod bolts. They are actually smaller than the stock SVT rod bolts if memory serves.
Similar Threads
FRPP Stage 2 cams vs. SCT XCal2 zslaton ZETEC Performance (2000-2004) 24 04-26-2007 02:59 AM
F/S Ford racing Stage 2 cams and cam gears *SOLD* my_darkred_zx3 Archive 12 01-23-2006 04:59 PM
Best cams? y2kpedo ZETEC Performance (2000-2004) 16 05-04-2005 10:26 AM
Mopar power that Ford needs to imitate hbm1 General Forced Induction 72 09-20-2004 05:57 PM
Crower Stage 2 cams frogg5872 Archive 3 08-30-2004 10:15 PM
