SVT Stage II Cams? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 03-16-2007, 01:10 PM   #1
topherdopher
topherdopher's Avatar
Fan#: 30161
What I Drive: 2005, Strato Blue, Mazda 3 2.3sp
FF Reputation: 1 topherdopher Good Standing Member
Buy-Sell-Trade Rating: (8)
SVT Stage II Cams?
How's it goin?? I'm interested in getting the FRII Cams... but all I've read is people with regular foci getting them. Would you recommend me getting them for the SVT or will they even work with the SVT? I've currently got: SRI, Magnaflow exhaust, ORP, Throttle body, FS Tune. I appreciate ALL of your help in advance!!!
--Topher
Yellow Rose Manager
topherdopher is offline
Old 03-16-2007, 01:24 PM   #2
turbovation
all grown up
turbovation's Avatar
Fan#: 29834
What I Drive: 2006 Toyota tacoma work truck
FF Reputation: 7 turbovation Good Standing Member
I dunno if the SVT would work with them without some new valves and adjustments and such.
this is bob. bob has bitch tits.
turbovation is offline
Old 03-16-2007, 01:24 PM   #3
JShep
Fan#: 35500
What I Drive: 2002 Liqiud Gray ZX3 SC'd
FF Reputation: 1 JShep Good Standing Member
Cams
No they won't work, the cams in the SVT are already top notch and aftermarket ones for it are VERY expensive. Just look to other mods because your cams are already taken care of.
Powerworks!!!
JShep is offline
Old 03-16-2007, 01:26 PM   #4
turbovation
all grown up
Fan#: 29834
SVT = turnkey except tune and HFC...and FI...and maybe slight suspension upgrade
Old 03-16-2007, 01:27 PM   #5
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
FF Reputation: 15 Anaxagoras1986 Great Standing Member
ZXtuner.com offers regrinds of the SVT cams. He was conservatively estimating a 10HP gain with the regrind.
Anaxagoras1986 is offline
Old 03-16-2007, 01:29 PM   #6
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
The stock SVT cams are bigger than even the stgIII's from FRPP.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 03-16-2007, 01:32 PM   #7
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
Hey Mike do you know what the exact specs on the SVT cams are? What clearance are we supposed to have on the lifters on intake and exahust too? I think mine need some shims...
Old 03-16-2007, 01:54 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
SVT cam specs and a bunch of other links are in this recent post in case you missed it yesterday:
http://www.focusfanatics.com/forum/s...65#post1487865
That was a long time ago, and I still don't know if he made any cams.
There certainly were never any dynos posted.
Again, see the above linked post for more info.
WD40 is offline
Old 03-16-2007, 02:02 PM   #9
Anaxagoras1986
Fan#: 34536
What I Drive: SVTF
Doug- I contected him not that long ago and he said he could do still do it. I didn't have the money at the time though. I guess those spare cams will just continue to sit in my basement for a little while longer!
Old 03-16-2007, 02:06 PM   #10
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
This is all i could find: These are spec for the SVT engine
Engine Data Description 2.0L DOHC 16V
Engine management EEC V/SEFI
Firing order 1-3-4-2
Bore 84.8 mm
Stroke 88.0 mm
Number of main bearings 5
Cubic capacity (cm 3 ) 1,988
Compression ratio 10.2:1
Maximun engine power 170 hp
Maximum engine speed 7,000 rpm
Maximum engine torque at 5,500 rpm 198 lb ft
Engine Oil Viscosity/ambient temperature Description Specification
Recommended engine oil
SAE 5W-30 / below -20°C to over +40°C Engine oil GF3 WSS-M2C915-A
If engine oils of this specification are not available, engine oils of specification API SH/EC, ACEA A2/B2 or ACEA A3/B3 may also be used.
Capacities Litres
Engine oil, initial fill including filter 4.35
Engine oil, oil change including filter 4.25
Engine oil, oil change excluding filter 3.75
Lubricants, Fluids, Sealers and Adhesives Item Specification
Sealant, camshaft bearing caps WSK-M2G348-A5
Sealant, cylinder block mating faces (Hylosil 502) WSK-M4G320-A
Sealant, cylinder block mating faces (Loctite Ultrablack) (alternative) WSE-M4G320-A2
Sealant, crankshaft position sensor ESW-1C155-A
Sealant, crankshaft position sensor (alternative) WSD-M1C-226-A
Sealant, oil pan WSE-M4G323-A6
Thread locking compound SDM-M4G9107-A
Spark plug thread lubricant (Never Seeze) WSD-M13P8-A1
Lubricant, injection nozzle O-rings WSEM-2C903-A1
Silicone grease for spark plug connector seal A696-M1C171-AA
High-temperature grease for clutch disc engagement splines ESD-M1C220-A
Cylinder Block Description mm
Cylinder bore diameter, class 1. 84.800 - 84.810
Cylinder bore diameter, class 2. 84.810 - 84.820
Cylinder bore diameter, class 3. 84.820 - 84.830
Inner diameter, main bearing shells installed 58.011 - 58.038
Inner diameter, main bearing shells installed (main bearing shells with stepped sizes) 58.008 - 58.031
Main bearing radial clearance 0.011 - 0.058
Main bearing radial clearance (main bearing shells with stepped sizes) 0.020 - 0.042
Main bearing parent bore 62.287 - 62.300
Pistons Description mm
Piston diameter, class 1. 84.770 - 84.780
Piston diameter, class 2. 84.780 - 84.790
Piston diameter, class 3. 84.790 - 84.800
Piston clearance in cylinder bore 0.010 - 0.030
Piston ring gaps (installed)
- upper compression ring 0.300 - 0.500
- lower compression ring 0.300 - 0.500
- oil scraper ring 0.400 - 1.400
Ring gap position: The piston ring gaps must be distributed evenly around the circumference of the piston This also applies to the oil scraper ring elements. Align the ring gaps at 120 degrees to each other.
Crankshaft Description mm
Main bearing journal diameter 57.980- 58.000
Crankshaft end play 0.090 - 0.260
Connecting rod bearing journal diameter 46.890 - 46.910
Cylinder Block and Lower Crankcase Spacers Description mm
Required spacer thickness if there is a gap between the cylinder block and the lower crankcase of:
0.26 mm - 0.50 mm 0.25
0.51 mm - 0.75 mm 0.50
Connecting Rod Connecting rod mm
Big end bore diameter 49.890 - 49.910
Small end bore diameter 19.951 - 19.981
Inner diameter, connecting rod bearing shells installed 46.926 - 46.960
Radial connecting rod bearing clearance 0.016 - 0.070
Axial connecting rod bearing clearance 0.090 - 0.320
Piston Pin Description mm
Piston pin length 55.800 - 56.200
Piston pin diameter, white 19.997 - 20.000
Piston pin diameter, red 20.625 - 20.628
Piston pin clearance in piston 0.010 - 0.019
Piston pin clearance in connecting rod 0.016 - 0.049
Camshaft Description mm
Bearing journal diameter 25.960 - 25.980
Camshaft bearing radial clearance 0.020 - 0.070
Camshaft end float 0.080 - 0.220
Valves Valves mm
Intake valve clearance in the valve guide 0.017 - 0.064
Exhaust valve clearance in the valve guide 0.017 - 0.064
Intake valve clearance (at 20°C ± 5°C) 0.110 -0.180
Exhaust valve clearance (at 20°C ± 5°C) 0.270 - 0.340
Cylinder Head Cylinder head
Maximum distortion (mating surface) 0.1 mm
Height of mating surface 1.76mm - 2.12 mm
Peak-to-valley height of mating surface (reference length 2.5 mm vertical to groove direction) R 3z = 6.0 μm
Oil pressure at 800 rpm - 850 rpm 1.3 bar - 2.5 bar
Oil pressure at 4000 rpm 3.7 bar - 5.5 bar
Torque Specifications Description Nm lb-ft lb-in
Hose clamps 4 — 35
Intake manifold studs 5 — 44
Intake manifold bolts and nuts 18 13 —
Heat shield to exhaust manifold 10 — 89
Exhaust manifold studs 5 — 44
Exhaust manifold nuts 16 12 —
Exhaust manifold bolts 18 13 —
Catalytic converter to exhaust manifold 48 35 —
Catalytic converter to exhaust 47 35 —
Generator to bracket 25 18 —
Generator bracket to upper cylinder block bolts 25 18 —
Generator bracket to lower cylinder block bolts 65 48 —
Transmission flange bolts 47 35 —
Starter motor to transmission 35 26 —
Flywheel bolts 112 83 —
Clutch pressure plate 29 21 —
Engine roll restrictor to transmission 48 35 —
Engine roll restrictor to subframe 48 35 —
Engine rear mount to body 48 35 —
Engine rear mount (nut on transmission mount bracket) 133 98 —
Engine front mount to engine 80 59 —
Engine front mount to body 48 35 —
Power steering pump bracket 48 35 —
Cylinder head a) — —
Camshaft bearing cap 15 11 —
Cylinder head cover a) — —
Spark plugs 15 11 —
Timing belt tensioner 25 18 —
Camshaft timing belt pulley 68 50 —
Camshaft VCT unit 120 89 —
Camshaft VCT unit plug 38 25 —
Upper timing belt cover 8 — 71
Ignition coil (EI) bracket to cylinder head 21 15 —
Thermostat housing 20 15 —
Fuel rail 10 — 89
Engine rear lifting eye 20 15 —
Engine rear lifting eye studs 7 — 62
Engine front lifting eye 35 26 —
Engine oil drain plug 25 18 —
Oil pressure switch 27 20 —
Cylinder block oil gallery blanking plugs 23 17 —
Heater pipe bracket to oil pan 10 — 89
Oil pan to lower crankcase a) — —
Lower crankcase to cylinder block 30 22 —
Oil pump a) — —
Oil intake pipe to oil pump 10 — 89
Main bearing cap bolts a) — —
Connecting rod bearing cap bolts a) — —
Coolant pump 20 15 —
Rear crankshaft oil seal carrier 20 15 —
Drive belt idler pulley 40 30 —
Crankcase ventilation pipe bracket 23 17 —
Crankcase ventilation 10 — 89
Coolant pump pulley 24 18 —
Crankshaft belt pulley 115 85 —
Crankshaft position sensor bracket 21 15 —
Crankshaft position sensor to bracket 8 — 71
Upper strut mount nuts 30 22 —
Timing belt idler pulley 38 25 —
Knock sensor 20 15 —
a) Refer to the procedure in this section.
SVT Squad #25
Call me Mike......
Similar Threads
FRPP Stage 2 cams vs. SCT XCal2 zslaton ZETEC Performance (2000-2004) 24 04-26-2007 01:59 AM
F/S Ford racing Stage 2 cams and cam gears *SOLD* my_darkred_zx3 Archive 12 01-23-2006 03:59 PM
Best cams? y2kpedo ZETEC Performance (2000-2004) 16 05-04-2005 09:26 AM
Mopar power that Ford needs to imitate hbm1 General Forced Induction 72 09-20-2004 04:57 PM
Crower Stage 2 cams frogg5872 Archive 3 08-30-2004 09:15 PM
