Engine Light Code P1131 - Focus Fanatics
Old 03-15-2007, 05:59 PM   #1
DerekNJND
Fan#: 42892
FF Reputation: 7 DerekNJND Good Standing Member
OK, had this engine light come on almost 2 weeks ago...
replaced O2 sensor by the exhaust manifold today, no dice. Still got a check engine light on.
I already checked for vacuum leaks, and didnt find any. Anyone wanna give a shove in the right direction here?? I"m pissed, I was 80% sure replacing the sensor would end this....
I'm thinking my MAF next...cleaned or replaced. After that, I'm looking at like 50 possible things, so someone please help if you can!
DerekNJND is offline
Old 03-15-2007, 06:08 PM   #2
justjeffrey
Fan#: 24634
What I Drive: 2000 Black JRSC-BBK'd ZX3
FF Reputation: 1 justjeffrey Good Standing Member
I cant remember - did you swap the DPFE?
-Jeff
I once saw a dude at Wal mart with 5 cans of BONDO. I told him that better be for your F'n science project.
justjeffrey is offline
Old 03-15-2007, 06:11 PM   #3
DerekNJND
Fan#: 42892
NOt sure what you're referring to...DPFE??
If thats some kind of after market modification, then no. This is a plain jane ford focus ZTS...nothing fancy installed or swapped.
Old 03-15-2007, 08:12 PM   #4
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
no, the DPFE is a common prob with the zetec's. if u r looking at the engine on the right hand side u will see the egr valve and right above it is the DPFE.googly moogly woogly!!!!!!!!!!!!!!!!!!!!!!! (the last part was what happens when u let your GF hold your laptop, lol)
zx32nr is offline
Old 03-16-2007, 12:27 AM   #5
DerekNJND
Fan#: 42892
I might have made a bonehead mistake...
I think for this type of check engine light, the light will not go away until you basically reset the engine and remove all codes. After I installed the new O2 sensor, I shouldve unhooked my battery then hooked it up again and driven for a while.
Once the P1131 code is tripped, its not going to "go away" simply by replacing or fixing the problem. The code is stored after the test for O2 sensor switching has failed a certain amount of times. Just installing the new part doesnt erase those failed tests, so the light won't go off. Unhooking the battery cables DOES make the light go away. If it comes back, the O2 sensor wasnt the problem. If it doesnt come back, then it was.
I shouldve done that immediately after installation and I did not.
I'm guessing here, but dpfe is the EGR sensor?? If the light comes back, I'll investigate that among other things like the MAF, exhaust leaks, fuel system, complete air system diagnosis, the list goes on and on.
Old 03-16-2007, 07:18 AM   #6
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
Yes. It senses the differential/delta in pressure across the EGR to determine if it is operating correctly.
penguin is offline
Similar Threads
Check engine light codes & meanings focusin General Technical Chat 59 01-19-2011 03:09 PM
Recurring engine light code after repair... pmac General Technical Chat 6 01-01-2007 06:17 PM
Check engine light on, AGAIN ! seraphim SVT Performance (2002-2004) 8 11-30-2004 04:11 PM
Phooey. Check Engine Light came on today. Thin_J General Technical Chat 0 07-14-2004 08:25 PM
Engine light - No codes? ispy General Technical Chat 19 04-28-2004 01:09 AM
