Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 09-06-2004, 10:42 PM   #51
YellaPZEV
Fan#: 1741
What I Drive: 2003 Egg Yolk Yellow 2.3L ZX3
FF Reputation: 1 YellaPZEV Good Standing Member
0301steeda has the venom 1000 installed and loves it...still need to go down the street one day and check that one out.
If it's too loud...you're too old.
YellaPZEV is offline
Old 09-14-2004, 12:53 PM   #52
SilverBullet
SilverBullet's Avatar
Fan#: 2384
What I Drive: 2002 Silver ZX3
FF Reputation: 1 SilverBullet Good Standing Member
Do I need to Change Pistons, sleeves, rods etc... if i get 75 shot or factory will be fine?
Also planing on ported head and camshafts to go with that.
SilverBullet is offline
Old 09-14-2004, 01:00 PM   #53
viney266
Moderator
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
FF Reputation: 112 viney266 Excellent Standing Memberviney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
50 will be fine, and 75 will be fine for a long while, but it will add some wear to parts... just make sure you can get enough fuel with the 75 shot.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 09-14-2004, 02:11 PM   #54
SilverBullet
Fan#: 2384
What size injectors would you recomend and do i have to get custum cheap w/ that?
Old 09-14-2004, 03:23 PM   #55
viney266
Moderator
viney266's Avatar
Fan#: 93
With a wet kit you will not need to change the injectors ... the nitrous kit supplies its own fuel...no chip needed either.
viney266 is offline
Old 09-14-2004, 05:03 PM   #56
SilverBullet
Fan#: 2384
How can you make sure you get enouth fuel on a 75 shot wet system without changing the injectors? is the fuel in the system ajustable?
Thanks Viney!
This thread is realy helpfull!!
Old 09-15-2004, 09:21 AM   #57
viney266
Moderator
viney266's Avatar
Fan#: 93
Put a fuel pressure safety switch on the car when you install the nitrous, if the fuel drops below a safe level it will cut everything off and save the motor. My car would only spray about 2-3 seconds with a 75 shot before activating the safety switch, some others have not had this problem. So as long as the switch is inline just try it..If it trips maybe a fuel rail or a better fuel pump might be needed, but probably not.
I pull my fuel for my nitrous jet out the test port on the end of the fuel rail and that may be why I get the prob with a 75 where a 50 is no prob..if you pull fuel from the line before the rail you may be fine ( by putting a "T" in the fuel line)..Try the 50 shot first then the 75 and see how it works out. as long as the fuel cut-off switch is there you will be okay..
viney266 is offline
Old 09-17-2004, 03:14 PM   #58
SilverBullet
Fan#: 2384
Thanks again Viney, I Don't think I could find more info any where else, you have answerd all my questions w/ great responce.
Thanks!!
Old 09-18-2004, 10:09 AM   #59
viney266
Moderator
viney266's Avatar
Fan#: 93
You are welcome...glad to help...
viney266 is offline
Old 09-18-2004, 07:09 PM   #60
slammedfoci
slammedfoci's Avatar
Fan#: 2137
What I Drive: 2000 Bright Amber Metallic ZX3
FF Reputation: 1 slammedfoci Good Standing Member
Man, this has got to be the most helpful thread on here. I have learned alot about juce and i want some very bad. What do you thinkabout the NX Stage 1 EFI system? Would i need to get the GEN X 2 Nitrous upgrade system with it to be safe???
Thanks viney for the tread.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover
EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights
INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed
slammedfoci is offline
Similar Threads
Dyno'd with the nitrous, I've got questions! [DYNO CHART] _spyder General Forced Induction 31 07-25-2010 12:22 PM
assistance with nitrous installation need4morespeed General Forced Induction 24 06-16-2010 01:58 PM
Turbo focus with nitrous? Kfokus General Forced Induction 6 09-23-2009 07:02 AM
Nitrous tune for SVT questions opyaFSVT Focus-Power Tuning 16 09-17-2008 11:42 PM
Nitrous Questions on SVT motor machslammer General Forced Induction 4 03-20-2006 10:49 AM
