I feel like i'm gonna lose control - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2007, 07:27 PM   #1
superchop
superchop's Avatar
Fan#: 17483
What I Drive: '02 Sonic Blue SVTF
FF Reputation: 4 superchop Good Standing Member
Buy-Sell-Trade Rating: (6)
What happens is, when i start going past 50mph my car feels kinda wobbly. I'll be driving straight and every once in a while the car will kinda jerk to the sides like it's about to start fishtailing. At first i thought this was due to the wind (since that day it was pretty windy) but it's been happenning almost every time i go over 50 to see it if does the same thing. Also when going at those speeds, if i stepped on the brake (lightly even) it would do the same thing as if i was about to start fishtailing.
The car drives fine with no problems at lower speeds and i don't think my alignment off since the car will go straight if i let go of the steering wheel. My snow tires are Q rated (which i think is good up to 99mph or so) so i can't say for sure that it's cause of that either. So i really have no clue if there's anything wrong or if i'm just paranoid and it's all just in my head.
Beginners can drive fast in a straight line...
Intermediate drivers can master corners...
But truly advanced drivers find their own course and that's how they get ahead.
Ryousuke Takahashi
superchop is offline
Old 03-07-2007, 11:56 PM   #2
cayres
cayres's Avatar
Fan#: 35184
What I Drive: 03 Comp Orange EAP SVT, 06 ZX3 SES
FF Reputation: 8 cayres Good Standing Member
sticky caliper??
cayres is offline
Old 03-08-2007, 01:11 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
It's quite possibly a combination of the snow tires and road conditions. Snow tires tend to be a little squirmy. Combined that with grove or rutted pavement (caused by studded tires or lots of truck traffic on asphalt pavement) the tires will follow the ruts (tramlining). Feels like the car has a mind of its own and yes it can get worse the faster you go. Try finding a nice smooth road and make sure you tires are at the appropriate pressure and see what that does to the handling. If there's no improvement it might be time to start checking tie rod ends, ball joints and other suspension/steering components.
Geezer is offline
Old 03-08-2007, 01:33 PM   #4
mmmoose
Bunneh Fanatic
mmmoose's Avatar
Fan#: 39963
What I Drive: 2008 United Gray VW Rabbit
FF Reputation: 9 mmmoose Good Standing Member
I have the SAME exact problem, and I've already gone through two alignments this year. Admittedly I did have a minor accident involving a cracked front bumper (where I skidded off the road), but it was nothing serious and I had it inspected and fixed up thoroughly by Ford. They only had to replace the end links of my front sway bar and told me I might need an alignment (did that through Sears instead).
Anyway, it's possible that your sway bar(s) may also be need to be re-tightened or have their end links replaced, but considering that this problem is still happening for me I'm not too sure that might be it either. Let us know if you find out what it is, because it's still happening to my Focus. The problem seems to be amplified by a windy environment, but even without wind it still jerks around at higher speeds.
-Moose
mmmoose is offline
Old 03-08-2007, 01:55 PM   #5
Lil_RedZX3
Mtn. Dew
Lil_RedZX3's Avatar
Fan#: 101
What I Drive: 2013 Taffeta White Civic Si
Points 15,704, Level 80
Points: 15,704, Level: 80 Points: 15,704, Level: 80 Points: 15,704, Level: 80
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 45 Lil_RedZX3 Great Standing Member
Has your car been lowered? What are the roads like when it does this? I've had this on 2 Foci in rain, and in snow. Both were lowered. I think it's the rear camber being slightly off.
Also, if you have two good tires, and two that are almost worn out, then put the two good ones on the back.
Lil_RedZX3 is offline
Old 03-08-2007, 06:29 PM   #6
superchop
superchop's Avatar
Fan#: 17483
My car is stock height and all 4 tires are pretty much brand new (no more then probably 700 miles on them) The roads are pretty clean but in both roads that i've noticed this happen were roads that see constant traffic so that might be something else that can be the cause.
I haven't checked my tire pressure yet (can't find my tire gauge...funny how i can't find it when i need it) but when i do around what psi should they be at? Just eyeing them the other day i noticed that the road salt was all in between the edges of the tire...meaning that the inside of the tire was white from the salt and the outside edges didn't seem to be touching the ground.
As for steering and such...I have noticed that as soon as i put on the snow tires the steering in the car has felt a lot more loose and that the tires weren't gripping right. Not something i particularly liked but i just let it go as it being that the tires are brand new and needed to be broken in first. But the truth is that I have no idea exactly how snow tires react mainly cause for the past 2 years i've owned the car i have been running summer tires through summer and winter (only cause i didn't realize they were summer only and i don't recall the dealer telling me anything about it), so i got real used to how those tires acted and reacted in various conditions and the change from one to the other was pretty drastic, at least to me.
Tierods and endlinks...I do remember the dealer replacing one of those things a few months ago before i put on my winter wheels but i don't recall there being any kind of problems with them afterwards (there really wasn't any problem with them from the beginning but the dealer didn't listen to what i said and just repaired what they felt was the problem...)
Ryousuke Takahashi
Old 03-08-2007, 06:33 PM   #7
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
tire inflation... i usuially have mine set between 31-34 in front, and 29-31 in the back
MattZX3 is offline
Old 03-08-2007, 06:46 PM   #8
mmmoose
Bunneh Fanatic
mmmoose's Avatar
Fan#: 39963
The recommended tire pressure should be on a sticker along the driver side door jamb. I think. In my case no matter what tires I had or how the pressure was adjusted, my Focus still has a tendency to move unpredictably at higher speeds. I'll definitely be taking it to the dealership again to have it checked out when I have the time.
-Moose
mmmoose is offline
Old 03-09-2007, 01:29 AM   #9
Captain Moonpie
Focus "Sleeper"
Captain Moonpie's Avatar
Fan#: 41715
What I Drive: 2003 Focus ZX3 deep red
FF Reputation: 13 Captain Moonpie Great Standing Member
The tire pressure on the focus is on the inside of the gas cover. Mine says to have 32 psi all around. But mine is a ZX3, not a svt. I dont know how you could have screwed up the suspension on that thing. I did a sideways slide into the curb at 35 mph and all I did was mess the alignment a little. Oh, and I snapped 2 alloy wheels. Not bend or chip, I snapped them. I keep them as trophies. Good luck with your search for answers.
DRIVE IT LIKE YOU STOLE IT!!!!
WAY too many performance mods to list. Check profile if you wanna know. And yes, I installed all my mods myself in my garage. No special tools.
GET NITROUS PEOPLE!!
Captain Moonpie is offline
Old 03-09-2007, 05:04 AM   #10
BlackJack03
BlackJack03's Avatar
Fan#: 43232
What I Drive: 04 EAP ZX5 SVTF
FF Reputation: 31 BlackJack03 Great Standing Member
Actually I do know what you're talking about. Mine does the exact same thing and it's a SEDAN! I noticed it shortly after I bought it, driving on the freeway--every time I go over a decent-sized bump the rear end moves unexpectedly and unpredictably and yeah, almost feels like it might start fishtailing. It scared me at first but obviously it has never fishtailed haha so I figured it was nothing to really worry about. But I will be lowering my car soon and I am hoping this has some sort of correcting effect on that.
Also I did notice that stock my rear wheels look way more off-camber than my front ones. I don't know which is toe and which is camber but the top is tilted more towards the car than the bottom. Don't know if that has anything to do with it but who knows. Maybe it's the style of suspension on the car that makes it do this...
BlackJack03 is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Control Arm with Poly Bushings Feeler *SOLD* HTP Designer Archive 6 02-18-2007 12:06 AM
Junkyard Speed Control chad_p71 General Technical Chat 1 03-19-2006 04:46 PM
Traction Control J_Mont0117 General Technical Chat 16 05-01-2004 02:18 AM
Need new front lower control arms... gthang Ford Focus & General Car Chat 23 11-19-2003 12:35 PM
