"The Official/Unofficial SVT Header Conversion Guide" - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2007, 05:16 PM   #1
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
The Official Unofficial SVT Header Conversion Guide
Well, I've noticed that a lot of questions concerning the SVT header conversion are coming up. I was in the same boat last summer when I wanted to do the swap, so my goal is to make writeup that can (hopefully) answer all of the necessary questions...so here it goes.
A Little Into-The SVT header is (IMO) the best long tube header for a Zetec Focus. It came stock on all SVT's, and is made of stainless steel (however, due to the quality of stainless, there is typically some surface rust on them). The SVT header also relocates the catalytic converter to a 'normal' position under the engine, whereas the regular Zetec has the cat on the front of the engine.
SVT Header
What to expect-On a car with normal mods, such as an intake system and a cat-back exhuast system, gains should be somewhere around 8-10whp. This will obviously vary slightly, depending upon what you choose to use as a cat (more on this later).
NECESSARY Parts-Here is what is absolutely necessary to do the swap to a regualar focus.
-SVT header
-SVT flexpipe (stock Zetec will NOT work)
-SVT oill dipstick (stock Zetec will NOT work, it is in the way of the header)
-One of the following: SVT catalytic converter, high flow SVT cat, or an ORP (again, more on this later)
-Gaskets (header/head, header/cat, cat/flex, flex/catback)
-Bolts/washers for the header to head, header to cat/orp, cat/orp to flex, flex to catback.
Recommended/Optional Parts-These are parts that you may want to get, but there are ways to get around it.
-SVT Power Steering Line-The stock Zetec line runs too close to the header for it to safely be used. There have been many people how have used their stock line, which has gotten too hot, and exploded. However, you can get away with using the stock line by bending it slightly out of the way, and having some sort of a coating on the header to keep heat down (ex.-header wrap).
The PS line is the black tube that runs above the header, and then goes down next to it on the left side. You can see that it is wrapped in an insulator (the alluminum looking tubing over it), and that it is also bent slightly so that it does not touch the header.
-Cat or ORP?
Here is where you need to make your major decision. The stock catalytic converter is not compatable with the SVT header, as it mounts in an entirely seperate location. Each of the pieces you can use (SVT cat, high flow cat or ORP) have their benefits. The stock SVT cat will definately allow you to pass emissions and will also keep the noise level to a minimum. The off road pipe (ORP), which is basically a piece of pipe that eliminates the catalytic convereter, is not emissions legal, and can get you a ticket. However, it will yield the largest performance gains. But, it is loud, has a high air pollution level, and will present issues if you live in an area where emissions testing is done. The high flow cat has the best of both worlds. It keeps the car quiet, gives it great gains and is legal, but relatively expensive.
SVT Catalytic Converter-The ORP will look very similar, just without the bulge in the middle of the pipe
-MIL Eliminator
This part is only necessary if you decide to use the off road pipe, and do not plan on getting your car tuned (with something like the xCal2). What it does is basically 'turn off' the rear oxygen sensor, tricking the computer into thinking that the emissions system is functioning properly. Another option is to leave the rear o2 sensor active, and just live with the check engine light on your dash, as there really shouldn't be any performance problems... only that annoying light. However, if your car is going to be tuned, the xCal2, for example, can simply disable the rear oxygen sensor, rendering MIL eliminators relatively useless.
- Oxygen Sensor Removal Tool
If you intend on reusing your oxygen harness, you will need to buy one of these special tools. It is basically a socket that allows you go unbolt the sensor from the pipe. They can be found at just about any part store. If you are not using your oxygen sensor again, you could go without this tool and just leave the sensor in the old pipe.
-Oxygen Sensor Extention Harnesses
These are entirely optional. If you decide to use the rear oxygen sensor, you need someway to hook it up, as the stock wiring is not long enough (because the cat was relocated by using the SVT header). You can either buy these little extentions that plug into the stock plug and have another plug on the other end that will reach the sensor in its new location. Or...you can cut the stock connector off, use some extra wiring you have lying around, connecting one end to the stock harness and the onther to the wiring on the sensor.
Notes about the EGR System...
Just a little heads up here. If you buy a used header from an SVT focus, there are no provisions for the EGR tube from the factory manifold. Your options are to either have an EGR bung welded into the header, or just not attach it, and plug the tube (you'll get a check engine light for eternity). This CEL can be disabled with the xCal2 by turning off the EGR system (if you plan on getting a tune eventually, that way you can avoid spending extra money having a bung welded in). Or, if you buy the Ford Racing kit or the one from McNews, those headers do have provisions for the EGR, and my above advice can be disregarded, but I did need to mention this.
A Little Note on Header Wrap...
Header wrap, or header tape as I've also heard it called, is a great way to keep exhaust temperature inside the header instead of under the hood where the air should be cold. Keeping the heat in can help expel the heat faster and theoretically increase power. It sort of has gotten a bad rap (no pun intended...) because it can seal in moisture underneath it, and cause rust. However, the SVT header is stainless, so rusting through sholdn't be much of a concern. Also, there is a spray on silicone coating available that will help to waterproof the header wrap. If you plan on using header wrap and the silicone coating, make sure you do it before the header is on the car, because it would be nearly impossible to do once intalled.
As far as purchasing all of the parts. First decide on what you want to do, and what you need to buy. Then, check out the parts section of this site, as you can locate a lot of stuff used and get great deals on it (thats where my header and ORP came from). If you want to buy new, you can check out places like McNews (www.mcnewsautomotive.com) or CFM (www.c-f-m.com). I know that McNews sells a kit that will give you just about everything you need, but the price can be hard to swallow (it was for me...that's why I went used). Remember, if you buy the header used, you will have to either disable the EGR system, live with a check engine light or have a bung welded in. If you buy the kit new, you don't need to worry about this.
Process-I think that sums up all of the parts that you need or may want to buy in advance. The process for installing the header is relatively straightforward, but can be time consuming due to rusty bolts that are unwilling to break free withough breaking the heads off (this is why I recommended buying all new hardware).
The process of installing the header is as follows (I'm doing this from memory, so it could be a little off)...
1) Disconnect battery and any wiring from the exhaust (o2 sensors)
2) Disconnect the catback system from the flexpipe.
3) Unbolt flexpipe and remove it
4) Remove factory heat shielding from the stock manifold
5) Unbolt stock cat from manifold and remove it
6) Unbolt stock manifold from head and remove
7) Install the SVT header on the studs with a new washer, and bolt it on lightly
8) Install ORP/cat with new gasket, and leave the bolts loose
9) Install SVT flexpipe with new gasket, again leaving the bolts only hand tight
10) Here is where the only snag will come in. The SVT flexpipe does not exactly line up with a ZX3 catback. Therefore, the flange will have to be drilled out until the bolt holes line up. Then, use new bolts with washers to mate the flexpipe to the catback.
11) Check that the pipes all line up correctly and tighten all of the bolts to their specified torque.
12) Check the PS line for clearance with the header. Slightly bend it out of the way and try to insulate it somehow. Or, install the SVT line.
13) Reconnect battery, start the car and check for leaks. In order to minimize the risk of a leak between the header and manifold, you should start the car and allow it to get up to run for increasing amounts of time, then shut it off and allow to cool. This SHOULD stop any leaks from showing up.
The final product should look something like what I have on my car below. By the way, my car has a SVT header (bought used), SVT ORP and flex with a Borla ZX3 catback. It is loud, but I haven't gotten pulled over for it or anything. There is a definate increase in power tha really wakes up the car compared to stock.
That should be everything. Go out and enjoy your new-found power and sound!!! Hopefully this will answer the most common questions that show up concerning this swap. I know I scoured the forums to answer all of my questions when I did it, so I thought one thread that has the information could be helpful. Let me know if I missed something or messed something up and I'll change it.
Last edited by svtguy88; 03-06-2007 at 05:48 PM. Reason: Fixing some formatting stuff...again
svtguy88 is offline
Old 03-06-2007, 07:39 PM   #2
homegrown2nr
homegrown2nr's Avatar
Fan#: 28279
What I Drive: 2010 F150 SuperCrew XLT
FF Reputation: 1 homegrown2nr Good Standing Member
Buy-Sell-Trade Rating: (13)
Good job dude. TO the "stickies"!
Looking for the following: XCal2, 2xDiablosport MAFia, 2x Quality BOV & Wastegate, Steeda Tri-Ax Shifter 00-02, 24mm RSB, Rear SVT Brake Kit, Driver side VF, and more ... PM ME!
homegrown2nr is offline
Old 03-06-2007, 08:46 PM   #3
BlackJack03
BlackJack03's Avatar
Fan#: 43232
What I Drive: 04 EAP ZX5 SVTF
FF Reputation: 31 BlackJack03 Great Standing Member
Yes, I agree--this should be stickied, unless it already has been somewhere else.
BlackJack03 is offline
Old 03-06-2007, 09:00 PM   #4
lildisco
RespectMyAuthoritah!
lildisco's Avatar
Fan#: 5761
What I Drive: 06 Mazda6i, 08 Mazda CX7 GT AWD
Points 30,711, Level 100
Points: 30,711, Level: 100 Points: 30,711, Level: 100 Points: 30,711, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 47 lildisco Great Standing Member
Buy-Sell-Trade Rating: (8)
It's done did
Here's my thread about it
http://www.focusfanatics.com/forum/showthread.php?t=100346
I'm trying to get a better how-to put together as well
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat."
06 Spring Into Focus Best Sedan/Wagon Winner
03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT
lildisco is online now
Old 03-06-2007, 10:41 PM   #5
svtguy88
svtguy88's Avatar
Fan#: 13476
Thanks guys....so now that it's stickied, could a mod change the title so 'unnoficial' is spelled right....stupid typos..lol.
I figured it was time to try to put a thread together that answered most of the questions and concerns with the SVT header.
svtguy88 is offline
Old 03-10-2007, 02:45 AM   #6
theonly287
SUPER FAST
theonly287's Avatar
Fan#: 35996
What I Drive: 2001 Oxford White SVT Wannabe
FF Reputation: 1 theonly287 Good Standing Member
Buy-Sell-Trade Rating: (6)
thank you for doing the write up it has cleared away any questions ive had plus i might go crazy if i see another SVT header question in tech chat...:)
over 1,500 invested in the motor and only 130whp
I <3 my SVT wannabe
theonly287 is offline
Old 03-13-2007, 01:36 PM   #7
pbcracker101
Fan#: 42488
What I Drive: 2000 green kona ZX3
FF Reputation: 1 pbcracker101 Good Standing Member
so this means.. there is no possible way that i can bolt the svt header onto my zetec exhaust w/out buying the new cat or ORP?
volant CAI, HKS catback exhaust, msd ignition coil, moog sway bar links, kyb grt-2's, msd blaster coils, Fr UDP, FFR 17" wheels
pbcracker101 is offline
Old 03-13-2007, 03:35 PM   #8
lildisco
lildisco's Avatar
Fan#: 5761
Forum Activity 4%
Originally Posted by Pkmgarf View Post
[CENTER][B][I][U]-Cat or ORP?
You can see if you can find a Stock SVT Cat or find a Used R/T Highflow or ORP used made for the SVT Header Conversion.
Old 03-13-2007, 11:07 PM   #9
mpcv2000
mpcv2000's Avatar
Fan#: 23629
What I Drive: 01 SE + 1989 RX7
FF Reputation: 19 mpcv2000 Great Standing Member
Here's how it looks : SVT header kit with 2.25" Random Technology "RT" hiflow-Cat and Flex . Just came in today ( March 13 2007 ) .
This is 10 days after and a ceramic bath...
On the car :
Martin !
mpcv2000 is offline
Old 03-14-2007, 06:54 AM   #10
melbzetec
melbzetec's Avatar
Fan#: 10307
What I Drive: 2003 Machine Silver Zetec
FF Reputation: 2 melbzetec Good Standing Member
Just a side note: If your Focus emanates from Europe, you will not have an EGR tube, and therefore could use a stock SVT (ST170) header. I bought the header adapted for Zetec from the US (ie with provision for an EGR tube), only to find I had to blank off the EGR socket in the new header. (My Focus is Australian delivery, manufactured in Germany)
FR Head milled .040". FR Stage 2 cams, Pipercross Viper intake, Ford Racing long header, RT Hi Flow cat, Herrod Motorsport 2.25" stainless catback, Quaife LSD, Eibach Pro-kit, Wilwood 13" brakes
cardomain.com/ride/2773918/1
melbzetec is offline
Similar Threads
SVT header and EGR valve clayton ZETEC Performance (2000-2004) 4 09-21-2005 12:18 AM
stock header vs. svt header change? jeffrey02 ZETEC Performance (2000-2004) 12 09-14-2005 12:01 PM
OBX Race Header -VS- SVT Header Ledjar ZETEC Performance (2000-2004) 13 04-20-2005 10:18 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
