Heads and Cams Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2007, 01:17 PM   #1
Kwizatz-Haderah
Fan#: 43128
FF Reputation: 1 Kwizatz-Haderah Good Standing Member
What types of performance gains can be expect for adding CNC/port heads?
And can anyone reccomend a head and cam combo for me?
Thanks
Red 01' ZX3, Eibach Pro-System, NeoDesign "Not OldSchool" body kit soon to come.
4.6 2v Powered 1965 Cobra Replica, comp cams, forged internals, ported heads, 1.7 Kenne Bell @ 10psi
Kwizatz-Haderah is offline
Old 02-07-2007, 06:33 AM   #2
Yel900rr
Fan#: 2792
FF Reputation: 15 Yel900rr Great Standing Member
I would use the Ford Racing head without a doubt. Put cams that fit the RPM range of where you want your power to be. I like the FR 2 cams for daily drivers and all around performance without having to rev it to make power. I have tested practically every cam grind. These cams give the best torque curve.
Yel900rr is offline
Old 02-07-2007, 10:30 AM   #3
Burnin_ruberv8
Fan#: 24686
What I Drive: MK2: 1600cc Black ATX Hatch
FF Reputation: 1 Burnin_ruberv8 Good Standing Member
FR2's are good daily used cams with decent duration to produce torque that last untill you rev limiter for stock applications... but what i don't understand is why even the FR3's don't have positive overlap?, is it because the engine doesn't like overlap or is it like this with F/I in consideration?, so why there's no Positive but negitive overlap with those FR's?
Burnin_ruberv8 is offline
Old 02-16-2007, 08:37 AM   #4
Zx3'dUrSvt
Fan#: 40333
What I Drive: '01 zx3
FF Reputation: 1 Zx3'dUrSvt Good Standing Member
definately go with the FR head, best bang for the buck. and like Ray said the cams should be picked out for your desired powerband, but if you go with a high revving cam, you'll need to upgrade the valvetrain so there isn't any valve float or clearance problems
<160 whp > <140 wtq> N/A... stock bottom end
Zx3'dUrSvt is offline
Old 03-13-2007, 05:39 PM   #5
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 5,460, Level 47
Points: 5,460, Level: 47 Points: 5,460, Level: 47 Points: 5,460, Level: 47
Level Up 55% Completed
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
fr stage 3 cams.......are they good for turbo applications? why or why not?
700whpfocus is offline
Old 03-14-2007, 06:46 AM   #6
Yel900rr
Fan#: 2792
Haven't tried them with a turbo setup. With the overlap dialed out they might be OK.
Yel900rr is offline
Old 03-14-2007, 11:58 PM   #7
melbzetec
melbzetec's Avatar
Fan#: 10307
What I Drive: 2003 Machine Silver Zetec
FF Reputation: 2 melbzetec Good Standing Member
Ray, I know your recommendation on cams is Ford Racing Stage2 for daily drivers.
What additional performance advantage do you get if you add both the FR2 cams and FR Cylinder head ?
My specific concern is: will I be sacrificing low end torque with this combination?
ps Currently have Pipercross Viper induction, Pipercross intake pipe from MAF to throttle body, Ford Racing longtube header, RT high flow cat, 2.25 flex. 2.25" catback. Focus is 5 speed manual
FR Head milled .040". FR Stage 2 cams, Pipercross Viper intake, Ford Racing long header, RT Hi Flow cat, Herrod Motorsport 2.25" stainless catback, Quaife LSD, Eibach Pro-kit, Wilwood 13" brakes
cardomain.com/ride/2773918/1
melbzetec is offline
Old 03-15-2007, 07:06 AM   #8
Yel900rr
Fan#: 2792
With those cams you will not sacrifice any bottomend. The FR head milled .040 with FR 2 cams were making about 150 to 155 whp and 140 to 145 wtq. The range is from 2 to 6700.
Yel900rr is offline
Old 03-15-2007, 05:26 PM   #9
700whpfocus
Fan#: 40899
how about fr stage 3 cams? any specs on them? how is the idle? tried it with a turbo application? anyone
Old 03-15-2007, 08:38 PM   #10
Yel900rr
Fan#: 2792
Never tried stage 3 cams with turbo.
Yel900rr is offline
Similar Threads
GP: Crane Cams Durtec & Zetec Cams nthcoastcom Archive 40 10-25-2007 10:17 AM
for sale cams, throttle body, sct chip jjaaccdie1 Archive 2 10-02-2005 03:08 AM
cams question zx3duffman ZETEC Performance (2000-2004) 4 08-08-2005 06:13 PM
For Sale: Cylinder heads, blocks and misc... Mr.Pressurized Archive 12 06-30-2005 11:38 PM
buildup question... ouikikazz ZETEC Performance (2000-2004) 2 10-06-2004 09:44 AM
