Anyone road racing the duratec 2.3 out there - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-21-2007, 08:33 PM   #1
carrerars
Fan#: 43088
FF Reputation: 1 carrerars Good Standing Member
Any one racing the 2.3 Duratec Cosworth engine 250 HP.
How about one naturally aspirated between 250-280 HP range, this
is the range that World Challenge Touring is allowing the cars to run
with. Rules say OE: pistons, rods, and crank. Stock ratio on the
rocker arms. Intake and exhaust ports max port 25.4 mm measured down
from the center of port opening. Valve guide may be machined as port
of the porting.
If I had a 2.3 Duratec within 250-280 HP range I would consider doing
it.
Regards,
John Hsu
carrerars is offline
Old 01-21-2007, 08:49 PM   #2
2nd_to_none
Fan#: 30252
What I Drive: 05' silver ZX3
FF Reputation: 1 2nd_to_none Good Standing Member
it will never happen with these motors. turboed they get to like 210-220 whp. full cossie set up well get them to 230 but they dont have stage 3 out yet so no chance of you getting to 250-280 with OE internals
FS cai, FC tb, 2.25'' borla cat-back, wanye tune, 17'' pacer rims
D20
-Dusting ricers since 2005
"i'd put it in her butt"
-wayne
2nd_to_none is offline
Old 01-21-2007, 09:45 PM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
OE pistons, rods, and crank will really limit you. You'll be lucky to get 200 whp N/A without changing those. The 250hp Cosworth engine even chages those, so I don't see how that would be legal for WC.
Plus, I haven't seen anyone with a Cosworth built engine in a Focus on here. Big bucks.
Egz is offline
Old 01-21-2007, 10:58 PM   #4
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
Points 5,927, Level 49
Points: 5,927, Level: 49 Points: 5,927, Level: 49 Points: 5,927, Level: 49
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 17 wickedgreyzx3 Great Standing Member
cosworth sells crate motors for 300hp
and yes it can happen becuase ford atlatntic series runs these 2.3 s
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 01-21-2007, 11:21 PM   #5
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Yes, and what is the spec list on those engines? He states that for WC, you must run OEM pistons, rods, and crank. Those Cosworth built engines for the Atlantic series I doubt use those OEM parts.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 01-22-2007, 12:50 AM   #6
carrerars
Fan#: 43088
Cool, did not know they used a Duratec in the Forumla Atlantic series thats very interesting. The Cosworth with 250 Hp is $12,500 without the ECU, I'm guessing a Formula Atlantic motor is over $20,000.
AS for the OEM stuff it can be lightened, shot pinned for additional strength, and modifying the top of the pistons, question is how much Horse Power and abuse can the OEM handle, I would like it to be a 40-60 hour race motor. WC rules also state that it can't rev over 8500 RPM. Motor can have a 3 stage dry sump one pressure and two scavange. If the Formula Atlantic motor's head is within the specs of WC it would be interesting to see how much HP it would be. WC uses Sunoco race gas I don't know what octane level it is.
The 2.0 Zytec motor I have in it now supposedly puts out 200 HP at the crank from what the previous owner had said. I'm going to dyno it, also
using a Motec M4 ECU, aluminum flywheel, LS1 coils, aluminum pullys, cold
air intake, barrel style intake manifold, headers, straight exhaust pipe, and adjustable fuel pressure regulator. Will the headers, intake manifold, flywheel,
bolt on to a 2.3 Duratec? Anyone using a Mountune Duratec motor, could
be another option.
Regards,
John H.
Old 01-22-2007, 08:49 AM   #7
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Assuming this is in a Focus, no, a Zetec header, intake manifold, and flywheel will not bolt to a Duratec. However, Cosworth makes a really nice header and roller thottle assembly.
The weakest part of the engine is reportablely the rods. And some engine builders recommend not taking the stock crankshaft past 7500 RPM.
Talk to Walter Marcy at Marcy Motorsports. He's built a fair amount of high HP engines, and know where some of the speed bumps are.
I find it interesting that they let you do a lot of exotic tuning, but limit you to OEM pistons, rods, and crank. Do you have a link to the rules?
Egz is offline
Old 01-22-2007, 09:40 AM   #8
BadIdea
Fan#: 6470
What I Drive: 02 Silver SVT 08 Tundra CrewMax
FF Reputation: 1 BadIdea Good Standing Member
I would call/e-mail Leo Capaldi with any questions. He still has his world challenge car. I can't imagine anything being OEM (maybe dimensions) with the motor's costing north of 20k.
BadIdea is offline
Old 01-22-2007, 09:45 AM   #9
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Ah, good idea. Forgot about his setup.
Egz is offline
Old 01-24-2007, 12:22 AM   #10
aero_student
Fan#: 1979
What I Drive: '03 Focus ZX3 PZEV
FF Reputation: 1 aero_student Good Standing Member
As far as streetable real world stuff goes marcy motorsport has some pretty wild stuff.
He currently holds the duratec na focus record at 221whp and will be shattering that in the next few months.
MarcyMotorsport:CAI, balanced 11.6:1 motor with ranger crank, cosworth flywheel, tumble flap delete, supertec valve springs, crane cams, clutch master stg I clutch, protoype MarcyMotorsport 2.5" exhaust, FC throttlebody, Quaife, svt bumpers and brakes, full energy bushings, etc.
aero_student is offline
Similar Threads
Duratec 2.3 cheap upgrades *natdaddy1 DURATEC Performance (2003-2007) 34 03-02-2006 03:02 PM
HiBoost Built 2.3 Duratec @ 496whp w00w00 General Forced Induction 25 02-17-2006 06:39 PM
Honda road racing vid lanting90 Video Showroom 10 01-11-2006 07:17 PM
2.3 Duratec swap CatMostFeared Focus-Power Tuning 3 12-08-2005 07:39 AM
duratec 2.3 catback & more questions ssovel DURATEC Performance (2003-2007) 7 07-29-2005 08:41 PM
