Rough Idle and SES Codes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-15-2007, 01:50 PM   #1
chkpnt
Fan#: 42901
FF Reputation: 1 chkpnt Good Standing Member
I am trying to diagnose and fix a problem with my girlfriend’s automatic 2000 Focus SE. The car has an active service engine light and is throwing two codes. Related (or not) the car also has an extremely poor idle. It drives fine but when at idle it will “bounce” and nearly die. Could my trouble codes have anything to do with the rough idle? Where should I look for the problem? I have done some poking around and found what the trouble codes mean on this web site: http://www.obd-codes.com/trouble_codes/ford/. Here are what they mean and what I have done so far to remedy the issue(s).
Codes:
1405 – Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
I checked the lines going from a solenoid (?) on the fire wall to the transaxle. Somebody had used fuel line which had disintegrated entirely from the inside and were almost entirely clogged. I replace this will proper silicon line but it still gives me the code. Are the lines I replaced the correct lines in regards to the error code (I can take pictures if that would help)? Could this have anything to do with the rough idle?
1409 – EGR Vacuum Regulator circuit malfunction
I am 99.9% sure this is due to an exhaust leak… There is ERG line going into the exhaust manifold and the gasket at that flag has blown out. I’m going to fix this and suspect the 1409 code will go away.
So far I have been unable to eliminate the rough idle. Any help would be very much appreciated. Thanks!
chkpnt is offline
Old 08-24-2007, 05:30 PM   #2
josejsanchez
MW2 NE1?
josejsanchez's Avatar
Fan#: 45194
What I Drive: 04 cd silver svtf
FF Reputation: 3 josejsanchez Good Standing Member
change the sensor... new wires and plugs could help, clogged air filter new fuel filter maybe,, really need to something about the exhaust leak
#910 OF #1978
just call me beaver
josejsanchez is offline
Old 08-25-2007, 01:06 AM   #3
hockey2826
hockey2826's Avatar
Fan#: 36684
What I Drive: 2004 blue svt
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 hockey2826 Good Standing Member
the 1409 wont be fixed by the exhaust leak, It means that the wires going to the egr vacuum regulator are either disconneted or have an open circuit or the regulator is internally open or shorted. If you can find your EGR valve, find the green vacuum line that plugs into the top of it and follow it back to the regulator and make sure the electrical connector is plugged in. If it is you have some issues. But I would replace the DPFE first and see if that takes care of both of them for some reason. stranger things have happend with DPFE's. Good luck.
hockey2826 is offline
Old 08-25-2007, 01:14 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,507, Level 100
Points: 138,507, Level: 100 Points: 138,507, Level: 100 Points: 138,507, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
yeah change the DPFE its is more than likley bad they go out like bad fashion on our cars.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Similar Threads
2005 ZES Rolling Idle, Lack of Power jeeden General Technical Chat 2 08-29-2005 05:11 PM
"My" 2005 ZX5 SES Review trixwagen Ford Focus & General Car Chat 7 08-23-2005 06:34 AM
