Broken Cruise Control - Focus Fanatics
Old 01-04-2007, 11:51 AM   #1
SVTF_170
Guest
Fan#:
Posts: n/a
My cruise control hasn't worked on my '02 SVT since I purchased it last summer. Is this a common issue for this car too? My procedure to active the cruise is first turning the system on, (I get no lights saying its on) then I go to a desired freeway speed which is always above 55mph at least, then I click set on the cruise control steering wheel control. Unfortunately it doesn't hold the speed however. I have had several cars with cruise control before and I have never had an issue like this before. Anyone?
Old 01-04-2007, 05:32 PM   #2
nickouellettesvt
nickouellettesvt's Avatar
Fan#: 33575
What I Drive: 2002 focus svt
FF Reputation: 2 nickouellettesvt Good Standing Member
check the plunger on the clutch pedal...right undernieth the dash. There should be a sensor that has a spring loaded plunger to detect if the clutch is depressed or not. Check fuses to see if any are blown. Also check the cable attatched to the Throttle body to see if it came loose(the cable on the inside of the assembly). Just a few things to check first
My formally owned SVT was repoed
nickouellettesvt is offline
Old 01-04-2007, 09:03 PM   #3
Jason2o
Fan#: 36872
What I Drive: 2002 Black w/blue SVTF
FF Reputation: 1 Jason2o Good Standing Member
I have also been told that if your airbag system is not working correctly the CC system will not work. Check to make sure your airbag light illuminates/extinguishes and no-one has tampered with it.
Jason
Jason2o is offline
Old 01-04-2007, 09:08 PM   #4
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
If the factory-installed cruise control system is anything like the retrofit Ford Racing kit for the Zetec, it really has no idea whats going on outside of the brake/clutch pedals' position and what the speed signal wire is feeding it. I would start with the TB cable and then check the wiring at the actuator, get a volt meter and see if you're missing a signal from one of the buttons or if its getting power. Its also possible that the actuator itself is dead...
SkaAddict is offline
Old 01-04-2007, 11:34 PM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: 13 stang
FF Reputation: 90 goinloco1 Excellent Standing Member
clock spring in the steering wheel.
goinloco1 is offline
Old 01-05-2007, 08:59 PM   #6
ModemJunki
ModemJunki's Avatar
Fan#: 10639
What I Drive: '02 Red on Black SVTF - tuned by Hypnotic
FF Reputation: 3 ModemJunki Good Standing Member
Does the horn work?
Keep the revs up!
ModemJunki is offline
Old 01-05-2007, 09:06 PM   #7
SkaAddict
Fan#: 1690
That wouldn't necessarily indicate if the clockspring is the problem or not; its fully possible that the cruise control wiring is broken but not the horn.
I'd also pull the airbag off and check if the cruise control switch plug is plugged into the clockspring. Disconnect the battery, wait 10 minutes and undo the four bolts on the back of the steering wheel to release the airbag. There are two plugs in the clockspring; one is the airbag and the other is the horn/cruise control switches.
Old 01-06-2007, 10:45 PM   #8
SVTF_170
Guest
Fan#:
Posts: n/a
The horn does work guys. Sounds like this might not be such an easy fix. I was under the assumbtion this was other known SVT issue.
Old 01-07-2007, 12:48 AM   #9
SkaAddict
Fan#: 1690
Sounds like its time to break out the voltmeter and start checking wires...
Old 01-07-2007, 12:53 AM   #10
SVTF_170
Guest
Fan#:
Posts: n/a
Your assuming I own a voltmeter too... lol. I am used to changing turbo's and installing boost controlers... lol. This car is going to be a whole new experiance for me. Should be fun. Anyone got any advice on where to purchase a voltmeter and which specific wires to check? Also I am assuming the fuse information is in my owners manual?
Similar Threads
Engine Light zummracer General Technical Chat 18 12-10-2013 09:08 PM
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 09:59 AM
Does your cruise control "hunt" when you engage it? ModemJunki General Technical Chat 9 11-26-2005 09:52 PM
Cruise Control Help!!!! magic2119 DURATEC Performance (2003-2007) 4 02-08-2005 08:44 PM
Cruise Control 2004 SE Wagon a223818 MK1 Interior Mods & Upgrades 0 08-05-2004 08:19 PM
