| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#1 | ||||
Inner Tie rod Question
I hear a news from my mechanic that I need a new inner tie rod, since the wheel has play if shaken from left and right.
My question is, are there any aftermarket inner tie rod I should get? Or where is the best place to get the inner tie rod for cheap? |
Remove Advertisements |
Fan#: 1
#2 | ||||
I'd get a second opinion. I'm assuming your 04 does not have a sh__ load of miles on it. Inner tie rods rarely wear out. Its normally the outter ones that go first. Rarely do you need something much more than a stock replacement one. Check out Bat Inc.
#4 | ||||
50K is not a s__t load in my opinion. We have over 50 K on ours and have had no such problems. That however, does not mean that there could be a bad apple in the bunch. I'd still get a second opinion. The parts are not expensive but after they add labor and a alignment it can get pricey.
#5 | ||||
I don't think there is any inner tie rods that are aftermarket.
But Advanced Auto has cheap one's for $15.00. Hope you have one near you, that's where I got mine, because Napa is expensive and AutZone didn't carry them. Good luck. |
#6 | ||||
Well the 50k miles was kinda aggressive driving. Drag and canyons hear and there, also it's been lowered and height adjusted a lot. Anyways, how can i tell if it's the inner tie rod, or outer tie rod, or even the rack and pinion?
#7 | ||||
Chances are its probably not the rack, but rather a tie rod. Most likely its an outer tie rod, they usually go before the inners do. |
#8 | ||||
how much can you move it? do you get any vibrations or anything...Which side of the car is it on?
My focus has roughly 60k miles on it, and i thought possibly something along those lines...Turned out to be the right wheel bearing. Go for a quality part over the cheaper...
Addicted to Volvo SEDAN REVOLUTION #14 |
#9 | ||||
I was wondering if these are any good?
http://cgi.ebay.com/ebaymotors/2000-...spagenameZWD1V They're way cheaper than the dealership, and i can't really find the MOOG anywhere local or online, and yes i checked autozone. I bought the outer ends today along with the inner, and the Outer tie rod end: $36 Inner tie rod: $28 But I wont be doing the labor until next week so I can return and buy them online cheaper. Also does the 00-03 tie rod differ with the 04? |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Inner Tie Rod Socket and Spark Plug Question | Oni | General Technical Chat | 16 | 05-11-2006 01:36 PM |
| Inner tie rod question | scargo | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 3 | 02-20-2006 08:00 PM |
| bent tie rod | magic2119 | General Technical Chat | 1 | 12-07-2005 09:20 PM |
| Bent inner tie rod | QuikHAtCH | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 0 | 11-25-2005 01:30 PM |
| replacing tie rod??? | black2k | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 4 | 06-10-2005 05:30 PM |
