rough idle..just put on TB - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-05-2004, 09:20 PM   #1
crobro24
crobro24's Avatar
Fan#: 1684
What I Drive: 2003 Focus zx5
FF Reputation: 1 crobro24 Good Standing Member
Guys need help 2003 5speed zx5...just put on the TB
followed all procedures disconnected the battery......turned it on i got some funky idle
drove around with it followed instructions...i keep gettin funky idle plus after a while idles get lower and lower till it starts to sputter help please!
runs fine noticed improvent
HELP
crobro24 is offline
Old 04-05-2004, 09:23 PM   #2
yellowbean00
Fan#: 1163
What I Drive: 05 Dodge Comm. Edition SRT-4 #4 of 200
FF Reputation: 1 yellowbean00 Good Standing Member
everyone is gonna tell u to use the search button because this topic has been discussed over and over again......heres a hint check your TPS (throttle postion sensor).
yellowbean00 is offline
Old 04-05-2004, 09:36 PM   #3
crobro24
crobro24's Avatar
Fan#: 1684
TPS is fine its in its spot
idle rough thou at low rpms
crobro24 is offline
Old 04-05-2004, 09:50 PM   #4
yellowbean00
Fan#: 1163
u sure u had the tps in the right spot because there are different rotations on the tps on 5 spd or automatic if that does not work check your idle screw it could be out of wack.
Old 04-05-2004, 11:33 PM   #5
EuroZX3
EuroZX3's Avatar
Fan#: 39
What I Drive: 05 Black Scion TC
FF Reputation: 1 EuroZX3 Good Standing Member
Buy-Sell-Trade Rating: (7)
adjust the idle screw. should barely make contact with the plate
Originally posted by darkpuppet
needs more cowbell
EuroZX3 is offline
Old 04-06-2004, 08:47 AM   #6
2000kona
Fan#: 2743
FF Reputation: 1 2000kona Good Standing Member
take a 3mm allen wrench and turn the idle screw till u hear the rpm's come up the let it set for a munite, then back it off and keep checking ur tach till it is at about 800 rpm when idling.
anthony
2000kona is offline
Old 04-06-2004, 10:03 AM   #7
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Which TB did you install ?
Stock or aftermarket 65mm TB ?
Just reading.....
microtonal is offline
Old 04-06-2004, 05:27 PM   #8
BlkZX3
Fan#: 473
What I Drive: El Huevo Negro
FF Reputation: 1 BlkZX3 Good Standing Member
Thats what mine did when I forgot to re-connect the MAF, belive it or not the car still runs, I assume you've checked that though.
BlkZX3 is offline
Old 04-06-2004, 05:36 PM   #9
crobro24
crobro24's Avatar
Fan#: 1684
well took it out FC TB put old one back in yah screws that hold the plate where the cables go in came out which is retarded.......hanging rpms dont know why..also are u sure that for a 2003 mtx its the 2003 atx TPS screws
thanx
crobro24 is offline
Old 04-06-2004, 10:45 PM   #10
crobro24
crobro24's Avatar
Fan#: 1684
also the bracket that comes with the TB for the cables its kinda offset on mine like i got no play from it just wondering if anyone else has that problem..and it looks like ill be waiting a bit to re-install it. Pretty sure it was a leak causing the hanging RPM's..if anyones had problems with it would u let me know this way i can look out for that stuff!
THanx
crobro24 is offline
Similar Threads
Rough Idle ChaosWarlord26 General Technical Chat 28 12-15-2014 06:10 PM
SVTF with rough idle at startup, ticking sound, etc HELP! Killercanary General Technical Chat 1 04-16-2010 06:33 PM
hfc causing rough idle BgJeff23B SVT Performance (2002-2004) 7 04-03-2010 12:56 PM
yet another rough idle thread (with occasional stalling/dying) dj elite General Technical Chat 9 01-14-2009 03:32 PM
Rough Idle, Loss of power at high RPMs snowsk8erjg General Technical Chat 4 05-12-2006 08:41 PM
