HOW TO: Install Electric OIL Pressure and Water Temp Gauges on 2.0L - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-31-2006, 09:49 PM   #1
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
HOW TO: Install Electric OIL Pressure and Water Temp Gauges on 2.0L :UPDATED:
hey all... i installed these tonight at work... i will post a BIG write up and pictures tomorrow, on new years day when i wake up. i just wanted to post this first, to give those certain individuals who have been waiting for this...
:EDITED UPDATE!:
Ok. i will be adding pictures as soon as i get time to do so... but i thought i would write up what there is to install these things....
ill start with the Oil Pressure gauge...
First starting with removing the oil filter plate and gasket, i believe the four bolts were 10mm each, a deep well and short socket are both handy here to get around everything... then after that remove the stock sensor from its place and clean the threads so there wont be any crap being pushed back into the oil filter housing... and the 2 parts i got from PepBoys to hook up the sensor for the autometer and the stock sensor were: 1/4inch NPT Nipple, part number 43252, and the 1/4inch NPT female Tee part number 43018, hook the nipple to one of the sides, then install the autometer adapter and sender in the bottom portion of the Tee, and then the stock sensor on the end of the tee. i used a few wraps of teflon tape on all threads for this. then after your done making a mess with oil spilling out of the filter like i did... so ahead and put the gasket and filter mount back into place loosely installing each of the 4 bolts you removed, then go in a zig zag pattern to tighten them back up... then all you have to do it run the wire from the sender to the gauge. i chose NOT to drill a hole in my fire wall, so i looked else where, and this is the spot where i ran both of my wires... i taped the wires and put wire loom around them to hide and protect them. but towards the bottom hinge on the drivers door there is a quarter side plug it'll probably be painted body color. you can pop it out from inside behind the kick panel to the left of the clutch pedal. i drilled a 3/8inch hole into this plug and then reinstalled the plug then ran my wiring and loom through it.
for the water temp gauge i put autometers sender adapter http://www.autometer.com/cat_accesso...il.aspx?vid=51 i cut the radiator hose in half in and installed the adapter in the upper radiator hose, i cut out a small section in the middle because the autometer piece will add length to the tubing... and then i attached a ground wire as indicated to the adapter so the sender will have a ground, then teflon'd the sender and installed it, then ran the wiring into the cabin with my oil pressure gauge wire.
after that, just follow autometer's instructions on which wires need to be hooked up where... remember test lights are your friend... i work with 12v ALOT at work. and my 45$ test light is great... its really sharp so you dont have to push hard at all to pierce a wire and see if its got power.
i would show you a picture of my wiring behind my gauges but everyone will think im mad for what i did... i used all red wires except black for the ground, Winnebago uses ALL yellow wires in their motor homes except white for ground, so i carried this idea from them and used it in this install. i just carefully marked which wires were which, and all was well...
again i will be takin pictures as soon as i can!
thanks, please post any questions you may have!
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 01-01-2007, 12:07 AM   #2
Cajun Boy876
Cajun Boy876's Avatar
Fan#: 32579
What I Drive: 2004 Silver ZTS
FF Reputation: 6 Cajun Boy876 Good Standing Member
That would be greatly appreciated. I wonder how much different it would be for a 2.3 duratec 04
Cajun Boy876 is offline
Old 01-01-2007, 12:10 AM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Should not be different at all.
Egz is offline
Old 01-01-2007, 12:22 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Thank goodness you did electric gauges. People who use mechanical gauges in daily drivers are insane.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-01-2007, 12:43 AM   #5
honhon
Fan#: 24778
i know people will be in this thread alot.. especially to find what size the fittings are for the oil pressure sensor...
honhon is offline
Old 01-10-2007, 10:14 PM   #6
05zx4st
Fan#: 13439
What I Drive: 2005 infra-red zx4 st
FF Reputation: 1 05zx4st Good Standing Member
Buy-Sell-Trade Rating: (4)
so,yeah
any info yet?
ST CREW #10
ECMOTORSPORTS.com
153whp,155wtq=9.65@74
XXXwhp,XXwtq=9.4@80 on n2o,spraying at 40mph+
totalled
05zx4st is offline
Old 01-11-2007, 12:16 PM   #7
honhon
Fan#: 24778
sorry...been busy with work, i will try and get time this weekend to take pictures and update everything in full detail.
honhon is offline
Old 01-11-2007, 06:20 PM   #8
mbx5brian
mbx5brian's Avatar
Fan#: 31419
What I Drive: 2006 ZX4 TURBO
FF Reputation: 3 mbx5brian Good Standing Member
great thanks for the info
FOCUS SPORT STAGE 2
UPGRADE ATX BY LENTECH
DURATEC 38 TEAM
mbx5brian is offline
Old 01-19-2007, 12:51 PM   #9
05zx4st
Fan#: 13439
anything?
ST CREW #10
ECMOTORSPORTS.com
totalled
05zx4st is offline
Old 01-19-2007, 02:09 PM   #10
bryfsvt
Fan#: 33542
FF Reputation: 7 bryfsvt Good Standing Member
06-ST: Not your typical focus
-14.2 @ 101.50 on stage1
bryfsvt is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
HELP ASAP: water and oil gauges Dark006 MK1 Interior Mods & Upgrades 1 12-24-2006 11:30 PM
Aussie Cleaning whippet_zetec Auto Washing, Detailing & Paint Protection 1 09-28-2004 08:32 AM
help with water temp gauges fastfocus General Technical Chat 0 08-30-2004 06:29 PM
