Recurring engine light code after repair... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-23-2006, 12:03 PM   #1
pmac
pmac's Avatar
Fan#: 42209
FF Reputation: 1 pmac Good Standing Member
Hi all...
I have a 2001 ZX3, about 130000 miles. Couple days ago engine light comes on, I brought it to a dealer, diagnoses engine code P0372, "Coil B Circuit Failure". They put in a ignition coil assembly (pn XS8Z-12029-AD). Car runs fine for a day or so, then the light comes back on.
I take the car to Autozone to get the code read (dealer that did the work is 50 miles away near where I work), the code is P0352 (Ignition coil B primary/secondary failure).
Could the part that was put in be bad? Or could there be some other issue causing this error? The guy at Autozone didn't have any suggestions beyond the ignition coil assembly. Is there any real difference between codes P0372 and P0352?
Thanks....
pmac is offline
Old 12-23-2006, 02:08 PM   #2
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
Originally Posted by pmac View Post
Hi all...
Thanks....
Make sure that the coil connections are clean and secure.
BornAgainFordOwner is offline
Old 12-23-2006, 02:30 PM   #3
pmac
pmac's Avatar
Fan#: 42209
Thanks, I will...
Actually, I also noticed that the B plug wire is cracked right at the flat end where it attaches to the plug.... it doesn't look like the crack goes down to the wire itself, but replacing the wires might not hurt, I guess (they've never been changed).
I also see, going thru my service records, that the ignition coil was replaced 2 years ago too, and I was only charged 1 hr of labor that time, as opposed to 2 this time by the same dealer. Another reason I should learn to do more of this myself..
pmac is offline
Old 12-23-2006, 04:56 PM   #4
pmac
pmac's Avatar
Fan#: 42209
Well, I changed the plug wires and it didn't make a difference. The engine ran rough, but while driving it around it would start running normally (smooth, normal power) and then rough again, alternating.
So I left the engine running, opened the hood, and noticed if I moved the 3-wire harness attached to the ignition coil left to right and back again, the engine responded to that. I guess maybe there's a bad wire in there? Is that part easily replaced?
Thanks again....
pmac is offline
Old 12-26-2006, 06:32 PM   #5
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
pmac,
Solder your new pigtail in if at all possible. On older copper, it makes a much longer-lasting repair. Regardless of whether you crimp or solder, be sure to seal the repair with heat-shrink tubing to make it weather proof.
Good luck with completing the repair.
- drjkel
drjkel is offline
Old 01-01-2007, 07:14 PM   #6
pmac
pmac's Avatar
Fan#: 42209
Originally Posted by drjkel View Post
pmac,
- drjkel
Got the pigtail soldered in, works great, thanks again....
..... can anyone tell me how to get the engine light to go out now?
Thanks!
pmac is offline
Old 01-01-2007, 07:17 PM   #7
pspringe
pspringe's Avatar
Fan#: 17992
What I Drive: 95 Metro, 03 Sonic Blue SVT
FF Reputation: 5 pspringe Good Standing Member
Disconnet the battery.
Hofstadter's Law
"It always takes longer than you expect, even when you take into account Hofstadter's Law."
Kariertes Hemd und Samenstau, ich studier' Maschienenbau.
pspringe is offline
Similar Threads
Check engine light codes & meanings focusin General Technical Chat 59 01-19-2011 04:09 PM
My Dealership Can't Fix My Check Engine Light I Sell 'Em General Technical Chat 11 08-17-2005 02:54 PM
Check engine light on, AGAIN ! seraphim SVT Performance (2002-2004) 8 11-30-2004 05:11 PM
? About a Check Engine Light Cthulhu Ford Focus & General Car Chat 8 11-12-2003 02:07 AM
